Old 10-13-2013, 08:43 AM   #1
JACIII OP
JACIII's Avatar
Oddometer: 360
Heat controller power outlet position
Where do you guys mount your power cable outlet from the battery? I ziptied my last one tightly to the frame tube on the left side near the front of the seat thinking it would isolate it from wear. Didn't work out as within a couple months it was toast.
Tips appreciated.
JACIII
(Terminal Case)
2001 R1150gs 2007 KLX250s
"You can ignore reality, but you can't ignore the consequences of ignoring reality." - Ayn Rand
JACIII is offline   Reply With Quote
Old 10-13-2013, 09:08 AM   #2
iride4u
iride4u's Avatar
Oddometer: 321
The key is to not pinch the wires.
This is on the GSW.
A better solution on the GTL but the caps keep breaking with the cold weather and you need to buy a whole socket.
2013 R1200GS LC red
2012 K1600GTL blue
iride4u is offline   Reply With Quote
Old 10-13-2013, 09:11 AM   #3
JACIII OP
JACIII's Avatar
Oddometer: 360
Thumb
I see what you did there. Nice. very similar to my failed attempt but more well thought out.
Thanks a bunch. Headed for the barn now!
JACIII
(Terminal Case)
Old 10-13-2013, 12:01 PM   #4
mefly2
mefly2's Avatar
Oddometer: 1,210
Look for the spring loaded outlets (~$20) ... the plastic retainers always break off in the cold. It is easy to fab a bracket out of a piece of angle aluminum available at your local hardware store .YMMV
----------------> jer-
30+ years with RTs...then to F/GS; now *Finally*
the BMW: R1200GSW, factory low seat & lower crash bars;
Touratech: Upper Crash Bars, big foot, pannier rack, ZegaPro panniers;
Fuzeblock, Rigid Dually D2 + yellow covers; Wunderlich bar risers w/ Q-adjust
mefly2 is offline   Reply With Quote
Old 10-13-2013, 06:42 PM   #5
JACIII OP
JACIII's Avatar
Oddometer: 360
Will look for those.
JACIII
(Terminal Case)
Times are GMT -7.   It's 08:29 AM.
