Old 09-27-2013, 09:16 AM   #31
Shred Head Fred
Captain Amstel
Shred Head Fred's Avatar
Oddometer: 57
Originally Posted by mwood7800 View Post
Fd oil does not contact the bearing if its going south why would it make any difference. Most fd failures are outer bearing so no mater how many times you change your oil it doesn't make any difference
I have to agree on this one, from what I've seen the bearing is isolated.
"I feel sorry for the people that don't drink because that's the best they're gonna feel all day"
Dean Martin
Shred Head Fred is offline   Reply With Quote
Old 09-27-2013, 09:43 AM   #32
ROAD DAMAGE
Oddometer: 1,050
rotor bolt heads
I know this may be a long shot but take a peek at your brake rotor bolt heads and see if one has/is developing a bright spot?
Then it's probably either a rotor bolt backing out ....... or FD bearing failing. Better hope for the bolt!
BTW, I ride a 07' GSA too that has over 100K on it ............... and I've never had ONE problem with it. Not one. I just service it and ride it. And a LOT of those miles are off-road. I thought I was having some FD problems at one point and it turned out to be a bad rear wheel. I just refuse to believe my FD or drive shaft are going to fail just because I've got "over 60K" on the bike.
Good Luck!
Rob
Formerly known as: Routt County Rob
ROAD DAMAGE screwed with this post 09-27-2013 at 09:53 AM
ROAD DAMAGE is offline   Reply With Quote
Old 09-27-2013, 10:28 AM   #33
GrouchyGeezer
GrouchyGeezer's Avatar
Oddometer: 859
The range of "information" one can obtain on ADVrider is absolutely stunning!
GrouchyGeezer is offline   Reply With Quote
Old 09-27-2013, 07:10 PM   #34
trc.rhubarb OP
trc.rhubarb's Avatar
Oddometer: 2,010
Rob
No shiny parts... nothing touching.
It's such an odd sound, at this point I hope its a bearing. I don't want to be on the hook for something dumb that I overlooked so I keep poking at it and looking again and again.
Still sounds like creaking to me but gets louder with more weight on the rear wheel.
2007 BMW GS Adventure / 2000 Ducati 900ss / 2010 Harley Ultra Limited / 1975 BMW R90/6 / 2006 DRZ400S
Follow me here
trc.rhubarb is offline   Reply With Quote
Old 09-28-2013, 03:08 AM   #35
Chat Lunatique
ACK
Chat Lunatique's Avatar
Oddometer: 1,068
Please make sure you get back to us on this one....I'm dying to see how this ends up!
I do not intend to tiptoe through life, only to arrive safely at death
Chat Lunatique is offline   Reply With Quote
Old 09-28-2013, 05:02 PM   #36
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,424
I'm fascinated as well.
Standing by:
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 09-28-2013, 08:24 PM   #37
trc.rhubarb OP
Oddometer: 2,010
Appointment to drop off is Thursday morning at 9. I hope to know something before the day is out considering they said about 4 hours to do a complete rebuild if needed. Unfortunately, they need to diagnose, then reach out to the warranty company and wait for approval which can be 24-48 hours. Still, I should hear and hopefully can get pictures.
Follow me here
Old 10-03-2013, 07:30 AM   #38
trc.rhubarb OP
Oddometer: 2,010
Today's the day...
They think they can have it finished today providing the FD is actually in rebuildable.condition.
Follow me here
Old 10-03-2013, 07:50 AM   #39
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,353
Originally Posted by trc.rhubarb View Post
Today's the day...
I would insist in seeing the replaced parts.
Take photos.
Jim
Old 10-03-2013, 02:48 PM   #40
trc.rhubarb OP
Oddometer: 2,010
So dropped it off this morning
They called in 2 hours and said the bearing is toast but hadn't broken the seal which is why I had no bits in my oil.
Called again in another hour and said FD is toast and not rebuildable. They will show me when I pick up the bike and said I can have all parts. Waiting on some pictures as well.
They have on in stock but need a seal for something or other so I'll get the bike Saturday morning as I'm working late tomorrow.
Pictures as soon as I have them.
Follow me here
Old 10-03-2013, 03:34 PM   #41
trc.rhubarb OP
Oddometer: 2,010
Picture:
Statement from dealer:
Requesting authorization for replacement of a complete final drive assy for a 2007 BMW R1200GS Adventure.
The bearing of the crown gear failed causing damage to the crown gear. A new bearing will not fit tight due to the damage. A pic is attached showing the damage to the crown gear. You can see where the splines of the hub were damaged from the bearing sliding bvack and forth.
62807Miles
Follow me here
Old 10-03-2013, 04:42 PM   #42
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Is that rust on there?
Jim
Old 10-03-2013, 04:45 PM   #43
trc.rhubarb OP
Oddometer: 2,010
Sure looks like it.
I haven't seen in person, this is from the dealer and what he sent to the warranty company.
I've never had the bike under water but I'm the 3rd owner. I've put almost 30k miles on it since buying it. Always used Mobile 1 GL5, changed every 6k and always came out clean.
Does it make sense it could be rust?
Follow me here
Old 10-03-2013, 04:47 PM   #44
JimVonBaden
"Cool" Aid!
Oddometer: 53,353
Sure looks like it.
Anything is possible. I have seen a rusty FD on an R1200ST, never off road.
Glad you have the warranty!
Jim
Old 10-03-2013, 06:19 PM   #45
trc.rhubarb OP
Oddometer: 2,010
With the limited information you have and the fact that I change the oil every 6k miles, could I have potentially done anything to prevent this? I've never seen water in the oil, so maybe it's just bearing crud/old grease mixed with the gear oil?
Follow me here
Times are GMT -7.   It's 04:57 AM.
