Old 09-24-2013, 09:43 AM   #1
whereisgibson OP
Oddometer: 183
Squeaky clutch lever
So my local KTM garage can't reproduce this, yet I can pretty much every time. What do I tell them to look for? Bike's got 43000 miles.
Bike in gear, clutch in (as if waiting at stop lights), an audible squeaking noise and a sensation of sticking/releasing when actuating the lever both in and out.
Happens less / barely if the bike is in neutral.
Fluids all fine. Actual operation of the clutch is fine. I'm just wondering if this is a warning. Sound appears to be coming from the left hand. I personally think it's the seal on the master cyclinder but I'm told it's fine...
In a perfect world I'd strip it all myself etc etc, but I don't have the time or space.
whereisgibson is offline   Reply With Quote
Old 09-24-2013, 09:57 AM   #2
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,946
To remove and refit the clutch plates all you need is the 8mm socket on the T-Handle from the stock toolkit. It will take you half an hour max. Put the bike on the sidestand and you wont even need to drain any fluids.
Does it do it when hot or only cold.
Sent from my GT-I9305T using Tapatalk 2
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 09-24-2013, 12:45 PM   #3
whereisgibson OP
Oddometer: 183
Temperature doesn't make any difference...
Old 09-27-2013, 12:04 PM   #4
whereisgibson OP
Oddometer: 183
Bump...
Old 09-27-2013, 01:13 PM   #5
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,946
Pull the plates.
Old 09-27-2013, 04:51 PM   #6
Weldit
Weldit's Avatar
Oddometer: 336
try a bit of lube on the lever pivot bolt - may be dry and gummed up ?
my clutch on 530 exc was squeaking every time you pulled lever
a bit of grease and all good now
is the sound coming from the handle bar area or the motor ?
'11 Dakar 990
Weldit is offline   Reply With Quote
Times are GMT -7.   It's 06:46 PM.
