Old 09-24-2013, 05:10 PM   #1
hammick OP
hammick's Avatar
Oddometer: 2,078
Led light strip on R1200GS LC
I know some people have thrown lamp faults when tapping into their brake or tail light wires. I want to put a small led strip into my GIVI top box brake light kit. These use very little power (see below to link). Looking to skip running a relay if possible. I tapped the tail and brake wires on my 2011 GSA which had led rear lights and didn't have any lamp errors (different canbus system I know).
http://www.ebay.com/itm/Waterproof-S...-/221242479044
2015 R1200 GSA; 2015 R1200R; 2014 FE501
hammick is offline   Reply With Quote
Old 09-24-2013, 07:05 PM   #2
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,440
There is no reason this should cause an issue.
Jim
JimVonBaden is online now   Reply With Quote
Old 09-24-2013, 07:29 PM   #3
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,530
Not certain I completely understand. I did place a strip inside my Givi top box so I could see the contents at night. I did not want the hassle of tapping into the harness nor connect/disconnect. I used a small project box with a 9V battery and a switch. That was 2 years ago; same battery.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 09-24-2013, 09:15 PM   #4
Gruesome
Alter Heizer
Gruesome's Avatar
Oddometer: 979
From the eBay seller pic they are three 3528 LEDs in series with a single 150 Ohm resistor. That should give you about (13.5-3*3.3) Volt / 150 Ohm = 20-23 mA or 0.25 to 0.3 Watt per 3-LED subunit. (That about agrees with the 25 mA per subunit (1A per meter) in the description.) So even if you put 30 LEDs worth (ten one inch substrips), you're still only at 2.5 to 3 Watt, less than a tail or parking light.
Gruesome is offline   Reply With Quote
Old 09-24-2013, 10:55 PM   #5
LaurelPerryOnLand
Oddometer: 3,482
Consider this?
http://www.youtube.com/watch?v=i0wr84qMsGA
LaurelPerryOnLand is offline   Reply With Quote
Times are GMT -7.   It's 07:09 PM.
