Old 09-25-2013, 01:53 PM   #1
Sabre170 OP
Sabre170's Avatar
Oddometer: 297
Changing tires
Nope, this isn't a thread asking which tire to get.....already bout my tires (got some k70's in my garage waiting for install).
My question may be a very dumb one, however, being a newbie, I want my ignorance to be cleared up.
All my previous motorcycles were tubeless. More so, I was a sport bike rider in my previous life too, thus tire installation perfection was necessary. Any tire change was done at the bike shop. I didn't want to mess with the tubeless install and such.....I'm sure most will agree with my desire to avoid this.
Now, however, I have the difference of having tubed tires. I've changed many of tubed tires on bicycles in my past, but never on a motorcycle....one would think it is a straight forward process.
Is changing a tubed tire truly as intuitive as I want to think it is? I'd hate myself if I took it to the shop and asked a mechanic to swap it if it is uber easy (kinda like asking a mechanic to change a lightbulb).
Is changing a tire and tube truly a user level task? And if so, any special steps, or just treat it like a really big bicycle tire?
Sorry if this is a super dumb question.
Sabre170 is offline   Reply With Quote
Old 09-25-2013, 02:03 PM   #2
MrPulldown
MrPulldown's Avatar
Oddometer: 3,361
Dude it is just like changing a mt bike tire...
...Except WAY HARDERED.
IMO one should change their own tires. Good practice for when you are out in the woods and get a flat. I do. However I do not think anyone will fault you for taking it into a shop. It is not changing light bulb easy.
Do a search on this topic as there are several very well written "how to's" . I however will throw in some advice:
-get good levers with thin edges on the spoons. At least 3 levers. I have one nice one and two cheap ones.
-use lots of lube. I use soapy water, though some will tell you that is a NO NO
-be very careful about where your levers are when you shove them under the rim, DO NOT pinch a tube, very easy to do
-use Heavy duty tubes. Less likely to pinch in install. Makes up for being heavier and harder to stuff.
-Don't worry about scratching your rims, it is bound to happen. If you do, might just have a shop change your tires.
MrPulldown is offline   Reply With Quote
Old 09-25-2013, 02:29 PM   #3
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,803
I think you should change your own tires if you can. I have tried and because of my inherent stupidity or just old age I always fail. I take my BMW Airhead wheels and new tires and new tubes to the local Honda dealer. Where they do it for a reasonable price.
But give it a try. Plenty of videos on YouTube about changing tires.
---Albert Einstein
disston is online now   Reply With Quote
Old 09-25-2013, 02:55 PM   #4
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,840
http://web.eecs.umich.edu/~deroo/bik.../whatwhen.html
Big Bamboo is offline   Reply With Quote
Old 09-25-2013, 03:40 PM   #5
mesher
mesher's Avatar
Oddometer: 82
I changed mine for the first time about a week ago. At the end of it I thought, "okay, I think I've appeased the masochist in me, next time I'll let a shop do it while the hedonist in me goes for a beer".
But it wasn't too bad, it's like an ultra-stiff, ultra thick mtb tire with no flex. I've fitted car tires by hand before and I think the motorcycle tires were more difficult because of how narrow they are, there's not much room to move (like when getting the tube's valve to poke out through the hole).
The toughest part for me was breaking the beads on the old tires, they had been on the rims forever and were really stuck. I eventually used a vise with some strategically placed blocks of wood to apply pressure to the sidewall close to the rim. I put some folded sandpaper between the block and the tire to stop the block from sliding away from the rim as the sidewall collapsed, it worked pretty well.
After that actually getting the tire off is easy, just like a mtb tire. There's a sweet spot with placing the levers, where it's easy to slip it in and easy to pull it over. I only used 2 levers and there wasn't much force involved, it's all technique and lube (I used soapy water, and baby powder to get the tube comfy).
The inside of my rims were really gunked up with old gluey rubber, I cleaned it off with turpentine and a soft wire brush. That's something the shop wouldn't have done and I'm sure it'll pay off if I ever have to break a bead by the roadside.
Use lots of lube when you are trying to get the new bead to seat again, I didn't at first and wasted a lot of effort trying to get the bead to seat properly.
mesher is offline   Reply With Quote
Old 09-25-2013, 04:07 PM   #6
MrPulldown
MrPulldown's Avatar
Oddometer: 3,361
Breaking the bead seems to be a tough thing. I can ususualy get mine to go by stomping on them with big boots. I have used C clamps, hammers, and even the kick stand of a motorcycle (not the one with the wheel off).
Fishing the valve stem though is kind of a bitch too. I have just learned of a valve stem fishing tool.
Here is a thread I started on the location of the bevel washer and two nuts.
Old 09-25-2013, 04:13 PM   #7
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,001
In the ADV "Hall of Wisdom" (which many aren't aware of) there is a great thread on this topic!
http://advwisdom.hogranch.com/Wisdom...0Changing.html
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 09-25-2013, 04:14 PM   #8
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,178
It's all about using the dish effectively, especially w/ new,stiff tires.
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 09-25-2013, 06:38 PM   #9
Sabre170 OP
Sabre170's Avatar
Oddometer: 297
Thanks all. As always, I appreciate the advice. I always enjoy doing stuff myself when able, but also may be worth calling the shop to see what they would charge.....possibly the small fee is worth saving my frustration in advance...
Old 09-25-2013, 07:43 PM   #10
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
The breaking bead....all you need is a 2x4 about 6' long and a small piece of woodscrap, 1x6 or 2x6 whatever about 6" long. Put the small piece against the tire at the rim, use the long one under the bench or even a car as the fulcrum. Push down. Just broke all the beads yesterday on two car tires that were rusted on the wheels after 10 years. Did not take long.
Takes about 10 seconds to break the bead on the R100GS wheels that way. Same with the much more fragile K1200RS wheels.Motion Pro rim protectors and the curved bars to reinstall,Marc Parnes wheel balancer...but Eh! there aren't any shops around here to overcharge me on mounting tires, had to relearn the old tricks.
Have tools, will travel!
Old 09-25-2013, 08:04 PM   #11
B_C_Ries
Oddometer: 3,113
I put the rim inside of the tire first ie: Both sidewalls of the tire are outside of the rim on both sides. Then it is real easy to put the inner tube in place and get the stem through the hole in the rim. Even with stiff sidewalls. Putting the first side of the tire in is usually easy enough. Sometimes getting the last side in gets tricky and the main problem is keeping the bead pressed into the low groove in the center of the rim opposite of where you are working so you can spoon on the last part of the tire onto the rim..
B_C_Ries is online now   Reply With Quote
Old 09-25-2013, 08:24 PM   #12
IronJackWhitton
IronJackWhitton's Avatar
Oddometer: 142
I'm pretty new to this whole bike thing but I just swapped tires out on my T800XC.
It really wasn't that hard. I found that the tube-type tires broke bead pretty easily. Back was much harder than the front.
I used this video:
http://www.youtube.com/watch?v=i31hv...yer_detailpage
And had 3 tire levers (2 6-inch KTM ones and 1- 12 inch one of a brand I can't recall).
It took me nearly 3 days but that was largely due to my lack of preparation -- make sure you read over how to do it for your bike a few times so you know you have the right sockets, wrenches, etc.!
IronJackWhitton is offline   Reply With Quote
Old 09-26-2013, 09:03 AM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
If you really want to learn, just find an old wheel/tire somewhere, preferably with a really old hardened tire on it and practice.My friend has a few of them in his shop, I bet for less than $20.00 he'd let you have one.
The "Motion Pro" rim protectors are great, sold in pairs. I should get another pair, can be hard to move them to reposition the bars so next time I'll set three of them on the wheel. Don't remember where I got my bars, that was a long time ago but they look just like the curved "Motion Pro" bars. Two of them and one of the short BMW straight bar, good lube and on the tires go.
n
Stands are nice but a bolt through the center of the wheel and the bolt it into the work bench does the same job.
Old 09-26-2013, 09:14 AM   #14
east high
east high's Avatar
Oddometer: 955
What's a good brand of spoons?
'71 r75/5
east high is offline   Reply With Quote
Old 09-26-2013, 09:15 AM   #15
B_C_Ries
Oddometer: 3,113
I am going to try using some plastic cut from a 1 gallon milk jug as a rim protector next time I change tires, just to see what happens.
Times are GMT -7.   It's 10:25 AM.
