Old 09-28-2013, 08:58 PM   #16
Katoom72
Katoom72's Avatar
Oddometer: 895
How do you ITG/Rottwieler owners direct the bowl vents? Same way like the box is on?
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 09-28-2013, 09:57 PM   #17
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,809
Yep, same 10"/11" vent hoses.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 09-28-2013, 11:33 PM   #18
buzybraza
buzybraza's Avatar
Oddometer: 378
I'm loving the no airbox setup for the LC8 engine because of better power/throttle response and ease of access!!!
buzybraza is offline   Reply With Quote
Old 09-29-2013, 03:51 PM   #19
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,423
165/168 mains, 45 pilots, 4mm floats, 1.25 turns on the screws, Factory Pro needles set to the 3rd clip. I could maybe go fatter but I like the 40mpg.
The 4mm float height leans everything out and is critical and key.
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 09-30-2013, 07:37 AM   #20
SpeedyR
SE in the SE
Oddometer: 889
I"m about the same as Chuck Racer- I think I did a bit bigger on my main (168/170 or 170/172? pretty sure the latter), 45 pilots, 4mm floats (or at leat what I think was 4mm as the floats were uneven side to side), FP needles at the middle slot (3rd), and not sure about the turns on the flex jet screws as it ran fine the way it was so I didn't screw with it more..
700' elevation, ATL. dual akros.
SpeedyR is offline   Reply With Quote
Old 09-30-2013, 07:48 AM   #21
txbear55
Oddometer: 267
Has anyone experienced a tendency for easier water access to intake without the enclosed airbox and snorkel?
txbear55 is offline   Reply With Quote
Old 09-30-2013, 11:33 AM   #22
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 784
I've run ITG on dirt sprint cars for several years, they get caked with mud, like 1" thick,, often slimy wet mud.. Never found the water to penetrate.. Even hit it with a pressure washer once on accident,, thought I'd be pulling the heads.. But nothing went through.. I'm sure if I had kept at it it woulda been bad..
Keep em oiled good and they stop a lot!
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 09-30-2013, 02:34 PM   #23
SpeedyR
SE in the SE
Oddometer: 889
not to crazy with water but I've had mine in water a bit over 2' deep and no issues. i was concerned but so far nothing has gotten past it. My concern now would be falling over in the water and having the motor running. but IMHO you would have issues with the stock airbox in that situation as well. so i worry about that 2% of the ride but 98% of the time it's full of win.
Old 09-30-2013, 06:40 PM   #24
Orangecicle
On a "Quest"
Orangecicle's Avatar
Oddometer: 2,961
Oooooooh yeaaaaaaah!
Orangecicle is offline   Reply With Quote
Old 10-01-2013, 02:18 AM   #25
Orangecicle
On a "Quest"
Oddometer: 2,961
Dave
What oil do most people use? I've used UNI oil before with UNI filter material, but it was a bit of a pain.
Old 10-01-2013, 08:02 AM   #26
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,809
No-Toil filter oil and filter cleaner.
07 Yamaha R6
01 Kawasaki KE100
74 Honda MR50
Old 10-01-2013, 08:21 AM   #27
mousitsas
mousitsas's Avatar
Oddometer: 2,876
Sportingwood told me once he also uses UNI oil. I hope I'm correct because I cannot find said pm right now.
Old 10-01-2013, 05:25 PM   #28
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
The ITG distributor that I deal with told me specifically to avoid NoToil. Higher alcohol content in the oil can cause accelerated deterioration and the cleaner is known to, at least to my man at ITG, dissolve the glue that holds the thing together. Personally, I've always had good luck with NoToil products but I won't use them or recommend anyone to use them on their ITG's. I generally use UNI or PJ1 spray and wash in a 5 gallon bucket of warm dish soapy water. Also, I have a new product that I am using in addition to that which really cleans out the oil quick without harming the foam which will be available soon.
I am really glad to see so many of you guys happy with the kit, really appreciate it!
Sporting Wood is offline   Reply With Quote
Old 10-01-2013, 08:34 PM   #29
mousitsas
mousitsas's Avatar
Oddometer: 2,876
A fine product at a fine price
Old 10-01-2013, 09:05 PM   #30
pdxmotorhead
Oddometer: 784
+1 The Notoil works for the Non Glued foam, but its not recommended for a couple of the dirt filters either.. I use Dish Soap / Dawn and a bucket of warm water.. Make sure not to use any type with anti bacterial agents,, its bad for plastics.
The outer skins make a HUGE difference, you can use a couple and just peel off like tear-offs. More than 2 though seems to choke things a bit..
Cheers
Dave
Times are GMT -7.   It's 06:16 PM.
