Old 09-27-2013, 03:04 AM   #1
Rockwell OP
Rockwell's Avatar
Oddometer: 665
Copper Bits In Oil
We've stopped in Vienna at LukasM's place to visit and do a bunch of maintenance on the motorcycle.
I did an oil change and we noticed small copper bits in the oil. What could this be from and should we be overly concerned?
Cropped, 100% zoom, sharpened:
not all those who wander are lost | two earthlings ride around the world
Home | Photo Blog | The Route | The Bike | About Us | Participate!
Rockwell is offline   Reply With Quote
Old 09-27-2013, 04:03 AM   #2
Katoom72
Katoom72's Avatar
Oddometer: 886
Looks like a bearing starting to fail...
I hope i'm wrong tho... But copper in the oil useually means bearing failure.
Edit: generator could be a cause aswell...hope it's that instead of the bearing shell
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 screwed with this post 09-27-2013 at 04:14 AM
Katoom72 is offline   Reply With Quote
Old 09-27-2013, 04:38 AM   #3
charlie264
charlie264's Avatar
Oddometer: 8,311
Pull genny cover, see if a bolt has backed out.
charlie264 is online now   Reply With Quote
Old 09-27-2013, 05:03 AM   #4
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,178
Originally Posted by charlie264 View Post
pull genny cover, see if a bolt has backed out.
+1
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 09-27-2013, 05:14 AM   #5
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
+2
If a bolt is on its way out you will soon be very stranded.
Cant say for sure if laying it down is needed to not have to drain the oil, I laid it down when looking over the balance shaft seal.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is online now   Reply With Quote
Old 09-27-2013, 05:23 AM   #6
keener
Speed changes you.
keener's Avatar
Oddometer: 931
I suspect the generstor as well.
No need to lay the bike down. Put it on center stand and lean it to the right and put a piece of plywood or something under the left leg of the stand.
04 ADV 950
keener is offline   Reply With Quote
Old 09-27-2013, 09:26 AM   #7
Rockwell OP
Rockwell's Avatar
Oddometer: 665
I'll check the generator. I've never seen inside the generator, so I don't fully understand what the problem would be. If a bolt backs out, which part is copper. The windings?
I'm worried that it might be a bearing. I posted a few months ago (HERE) about some jerkiness I've been experiencing. Some suggested the twitchy throttle, but I know it isn't that since I had never experienced this kind of jerkiness before. I stopped at a ktm dealership while we were still in Canada, and the mechanic said that he'd bet his last beer that it was a loose link in my chain. He tugged on the chain at the rear sprocket and there was a bit of play.
I'm thinking that if there are bits of copper in the oil (which suggests a possible failed bearing), and I have been experiencing jerkiness, that it might very well be the bearing?
Old 09-27-2013, 09:50 AM   #8
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,307
Originally Posted by maugustyn View Post
Hey everyone. Assuming I am doing this correctly, I wanted to get back to all of you and let you know how things turned out. As you can see from the pics, not well...
Apparently, the flywheel/clutch starter bolts started to back out around 48,300 miles on the bike....noticed and put back in by a shop that replaced the torque limiter...shop to remain nameless...bike died at 49,900 miles...
The bike was not repairable nor could parts get in fast enough. As a result, she/aka the bike, stayed with MotoVirginia in Charllotesville for a week while I, sadly, rented a coffin.
MotoVirginia saw no locktite on any of the the bolts :-( Along with the stator, the rotor was shot as well.....
I am told that I am lucky that the bike/engine did not seize up on me. Big shout out to Dirk, Donnie and Widget at MotoVirginia in Charllotesville, VA. Very helpful. Very friendly. Very reasonably priced.
Also, a nameless shout out to the shop that did the torque limiter work around 48,300 miles. The day I finally made it back, they gave me a check that covered all of the repair bills, 2 nights of hotel while stuck in VA and the rental car up and back from VA. Almost $1800. They did the right thing and I am deeply grateful. The parts are going back to KTM to see if there may have been a factory problem.
So today's lesson, always locktite (with the red stuff) your flywheel/clutch starter bolts. Or make sure your mechanic does.
Note: The post I quoted mentions using Loctite. Be sure it is Loctite 648.
From the H.O.W.
Freewheel bolts: There have been several cases of one or more of the bolts holding the freewheel assembly to the generator rotor loosening up, and in a few cases backing out far enough to make contact with the stator. This has resulted in damage to the stator, and in at least one case, the sheering off of one of the bolts. A Tech Bulletin was issued on October 16, 2004 that addresses this issue. Since it is such a critical item, it is suggested that ALL 950/990 owners check their bikes as instructed in the TB. Note: Be sure to use Locktite 648 as instructed. We have had failures caused by using lesser products in this instance.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 09-27-2013 at 10:02 AM
MortimerSickle is online now   Reply With Quote
Old 09-27-2013, 10:49 AM   #9
dwj - Donnie
dwj - Donnie's Avatar
Location: Traveling on the Moto or Escuitla, Chiapas, Mexico
Oddometer: 14,588
Sorry to hear this! Got my fingers crossed for y'all!
Donnie
Donnie - Retired & Riding - 2010 990ADV - 45,050 Miles - 2 Continents - 10 Countries
Return to Panama - SPOT
dwj - Donnie is offline   Reply With Quote
Old 09-28-2013, 12:36 AM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,981
As you can see in these photos
A new seal is needed when opening the generator cover, as it will probably get damaged.
Cheers.
Old 09-28-2013, 01:25 AM   #11
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
Cheers.
At least on my 2004 there NOT a paper gasket sealing the generator cover and I reused mine several times before changing it, not cause of leaks but to be safe.
/Johan
Old 09-28-2013, 01:40 AM   #12
MortimerSickle
Semi-Adventurer
Oddometer: 12,307
/Johan
IIRC my early '04 had a metal gasket. I reused it without leakage.
G.H.W.S. 1878-1962
Old 09-28-2013, 09:12 AM   #13
sstewart
sstewart's Avatar
Oddometer: 1,056
Stator
Been there,done that. Took about 7 oil changes to get it out. Good luck!
sstewart is offline   Reply With Quote
Old 09-28-2013, 10:19 AM   #14
Rockwell OP
Rockwell's Avatar
Oddometer: 665
Opened the cover to look at the stator. Everything appeared to be fine.
We were able to reuse the gasket as it stayed in tact when removing the cover.
We're going to do another oil change in a few days and try to filter the oil to see what's in it. Hope it's not a problem with a bearing. According to Lukas, everything in the engine sounds normal.
Old 09-28-2013, 10:49 AM   #15
charlie264
charlie264's Avatar
Oddometer: 8,311
That's good news. Were there bits on the screens.
Times are GMT -7.   It's 11:31 AM.
