Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 09-27-2013, 05:27 PM   #1
Weldit OP
Weldit's Avatar
Oddometer: 336
1190 windscreen mounted to 990 ????
has any body that has both the new 1190 and a 990 looked at mounting the new 1190
windscreen with or without the quick adjustment brackets on a 990 adventure ?
I have looked at all the aftermarket screens for the 990 and they all seem to stay
with the straight up or "rally style" which we all know is not a good design for road use
the new 1190 screens seem to have addressed this with a much more swept back
shape to have a smother air flow.
'11 Dakar 990
Weldit is offline   Reply With Quote
Old 09-30-2013, 11:11 PM   #2
what car??
down the road
Oddometer: 372
"which we all know is not a good design for road use"
HA!! Speak ONLY for yourself there fellow! I have no issues with the 990 windscreen!! I am sure I am not the only one who thinks that. If you want to achieve what the 1190 has that's fine, but DO NOT categorize "which we all know is not a good design for road use" for WE ALL KNOW. I guess since you already have experience with the 1190 windscreen you should be able to come up with something that should work for you. Good luck with your project.
what car?? is offline   Reply With Quote
Old 10-01-2013, 12:42 AM   #3
Tancakar
Tancakar's Avatar
Oddometer: 367
:) I though 990 was briliant well at least that's what I heard in here:)
Also heard that -2012-2013 990 got big problems with front end very wobbly over 60 mph.
Tancakar is offline   Reply With Quote
Old 10-01-2013, 09:15 AM   #4
ColoradoBigfoot
ColoradoBigfoot's Avatar
Oddometer: 119
Pretty fired-up about that windscreen huh?
Because you have no issues does not mean it's a good or optimal design.
I see a lot of pictures on this site of 990's that have after market windscreens so something is not totally satisfying w/ the stock one.
ColoradoBigfoot is offline   Reply With Quote
Old 10-01-2013, 05:04 PM   #5
NKL
Oddometer: 180
Where did you hear that then?
NKL is offline   Reply With Quote
Old 10-01-2013, 05:16 PM   #6
Weldit OP
Weldit's Avatar
Oddometer: 336
cool your jets Buddy ! for I am not alone on this !
take a look at this :Windscreen Disgust ...... again - ADVrider
just one thread of hundreds (105 pages in this one) on this windscreen issue !
If I had "experience with the 1190 screen" I would rig something up BUT
there are NO 1190 bikes in the USA or Canada till 2014.
That is why I was putting it out there : for someone with access to 990 & 1190
'11 Dakar 990
Old 10-02-2013, 03:32 AM   #7
agent86pc
Oddometer: 31
990 screening
The wind buffeting is my only real complaint with the 990, everything else is pretty cool. Fitting a 1190 screen if possible could be the answer to this buffeting, perhaps.
Artificial intelligence is no match for natural stupidity .
agent86pc is offline   Reply With Quote
Old 10-02-2013, 06:56 AM   #8
ADVill
Oddometer: 608
I think anyone over 5'8" tall will have problems with the stock 990 wind..shield. Just sayin.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 10-02-2013, 07:33 AM   #9
GJ990
GJ990's Avatar
Oddometer: 288
I don't.
990 Baja
GJ990 is offline   Reply With Quote
Old 10-02-2013, 07:35 AM   #10
GJ990
GJ990's Avatar
Oddometer: 288
You might be refering to the D908 equiped Baja. It's the knobbies, nothing else. Mine is worn down and the headshake is long gone.
990 Baja
Old 10-02-2013, 08:58 AM   #11
Maoule
Maoule's Avatar
Oddometer: 454
Before you spend a lot of effort and/or money on your windscreen, if you have a DS helmet with a beak, take it off and see if the buffeting goes away. If it does, then you need to stiffen up the beak. It worked wonders for my buffetting issues.
Maoule is offline   Reply With Quote
Old 10-02-2013, 09:18 AM   #12
Dearnla
Dearnla's Avatar
Oddometer: 161
Don't think the 1190 screen is the cure. I get buffeted by it, low, high, forward or back.
Putting the option taller screen has helped, as it's taller AND wider at the top. That solves the buffeting for me, although wind noise is still present.
I'm 6'1" and have the seat on the low setting.
KTM1190 ADV
Honda VFR1200FD
Honda CB900F2
Dearnla is offline   Reply With Quote
Old 10-02-2013, 08:40 PM   #13
Sumi
Sumi's Avatar
Oddometer: 1,796
+1. also a helmet with a visor makes it worse.
Old 10-03-2013, 09:11 AM   #14
ADVill
Oddometer: 608
I'll take my visor off and see if it helps although if I lift my head it does not tug one bit but that has nothing to do with buffeting.
'00 520 EXC
'14 500 XCW
Old 10-03-2013, 09:36 AM   #15
el queso
toda su base
el queso's Avatar
Oddometer: 689
Originally Posted by GJ990 View Post
I don't.
Me neither. I'm good with the stock windscreen.
el queso is offline   Reply With Quote
Times are GMT -7.   It's 06:36 AM.
