Old 09-28-2013, 02:46 PM   #1
MymoJoe OP
Ride Ride Ride
MymoJoe's Avatar
Oddometer: 2,946
changing from standard height to S spec
I might have chance to change the standard 220mm 05 suspension for a full 265mm S suspension.
I figure the brake line will need replacing, anything else?
speedo cable?
Simpson Trip 2008
http://www.advrider.com/forums/showt...33#post7397233
Life should NOT be a journey to the grave with the intention of arriving safely in a well-preserved body, but rather to skid in sideways, body thoroughly used up, totally worn out and screaming "WOO HOO - what a ride!"
MymoJoe is offline   Reply With Quote
Old 09-28-2013, 03:27 PM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,373
speedo cable?
Speedo cable should be plenty long enough.
If you swap with another bike maybe change the entire front brake assembly, think it can be unbolted as is and swap all of it master cylinder and calipers.
But changing brake fluid might be good to do at some point also so maybe keeping your own trusted stoppers is better and just swap hoses.
Stands, both side and center are different.
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 09-28-2013, 06:59 PM   #3
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,103
I changed from standard to s
Brake lines were fine
I changed my kickstand and center stand
Cj makes a kickstand that you twist to make longer.
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 09-28-2013, 07:37 PM   #4
DrKayak
Retro Rider
Oddometer: 796
Same here........ I just change the stands. I went with stands from a 990R which are taller than S height stands. Like the side stand a lot the bike does not lean way over. The Center stand is so tall it's hard to get the bike up on it.. no big deal.... I'm strong.
DrKayak is offline   Reply With Quote
Old 09-29-2013, 05:16 AM   #5
mdfehrmann
mdfehrmann's Avatar
Oddometer: 338
I'm running ROX risers and different bars I found the brake line too short
when I changed to the 265 travel.
Matthew
Only when you take 520lbs of motorcycle and snake it through the woods as slow as you can, will you begin to learn just how much you never knew about motorcycling. -Dieseljo-
2006 KTM 950 ADV S - 2004 Sherco 2.9
http://www.mdfeditions.com/
http://www.cjdesignsllc.com/
mdfehrmann is offline   Reply With Quote
Times are GMT -7.   It's 04:00 AM.
