Old 10-01-2013, 07:03 PM   #16
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,099
Redline super cool for me !
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 10-01-2013, 08:29 PM   #17
woodchuckexc
Oddometer: 801
Originally Posted by EastSideSM View Post
eh. I use it and have used others including Harley branded coolant. I don't think it really makes a big difference. I think the fan switch that kicks the fan on sooner makes a bigger difference than the brand of coolant.
Last I checked Harleys were aircooled. How'd that work out for you?lol
woodchuckexc is offline   Reply With Quote
Old 10-01-2013, 10:07 PM   #18
Dan950ser
NW Shredder
Oddometer: 484
Pretty sure Harley had that thing called a vrod that was water cooled.
2015 KTM 690 Enduro R, 2007 KTM 990 SuperDuperEnduroR For Sale http://www.advrider.com/forums/showthread.php?t=1046431, 2014 KTM 250 XC-W
Dan950ser is online now   Reply With Quote
Old 10-02-2013, 05:20 PM   #19
gpthis
Oddometer: 196
Watch out if your space is not heated.. EI can slush up in the winter, not sure if it will freeze solid. Just say'n..........
lol
gpthis is offline   Reply With Quote
Old 10-02-2013, 06:23 PM   #20
bykpimp
Live and let ride
bykpimp's Avatar
Oddometer: 1,408
Think V-Rod
" I can't fix your motorcycle over the phone or internet" Spanky
bykpimp is offline   Reply With Quote
Old 10-03-2013, 02:49 PM   #21
agent86pc
Oddometer: 32
Ice
I used engine ice in my previous exc 530 & 570 berg & while it's a good product I am not sure it does anything better or extra that a cheaper product may do. Basically if you have a over heating issue caused by whatever then engine ice is not going to fix it. Although some people claim it will help a engine run cooler when actually plain water is said to be the most efficient at exchanging heat but has obvious limitations in other areas.
Artificial intelligence is no match for natural stupidity .
agent86pc is offline   Reply With Quote
Old 10-07-2013, 11:55 AM   #22
EastSideSM
Isn't that dangerous?
Oddometer: 1,490
Pretty damn good actually. How does being a total douche work out for you?
Last time I checked, Harley made a bike called a V-rod that is liquid cooled, but I am guessing the last time you checked up on Harleys was sometime prior to that model being made (2001 was the first year they were made in case you needed another point of reference). Maybe that suggests you should either freshen up your motorcycle knowledge more frequently or maybe just keep your snarky, ignorant comments to yourself.
EastSideSM: '06 950SM Black
EastSideSM is offline   Reply With Quote
Old 10-07-2013, 12:44 PM   #23
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
I run Engine Ice in my 300 XCW and my 990 R. I can tell a difference, especially with the 300. It also helps with the big twin as she runs hot in the first place. Runs cooler for sure.
Tip: to gain the max cooling performance from Engine Ice it is important NOT to just drain your old coolant and then dump in Engine Ice. You should thoroughly flush the system with a 50/50 mix of distilled water and white vinegar. Run the engine twice with this mixture, then drain. Then after that flush with distilled water only until the vinegar smell is gone from the water draining out. Then fill with Engine Ice.
Times are GMT -7.   It's 05:01 PM.
