Old 09-29-2013, 06:22 AM   #1
sakinjp OP
Oddometer: 1
oil in compression chamber
1971 R75/5 bmw I have oil fouling up my spark plug on one side keeping that side from firing. How do i fix this? Its the right side and parked on center stand I believe this engine not orginal has 35000 I rode it with this engine a couple of years before it started acting up. I have never set the valves and don't remember if I have had anyone do it.
sakinjp screwed with this post 09-29-2013 at 05:03 PM
sakinjp is offline   Reply With Quote
Old 09-29-2013, 07:08 AM   #2
ozmoses
Ride On
ozmoses's Avatar
Oddometer: 4,091
Type 247 motor?
Breather valve working?
Valve job?
Opinions are like internet connections- everybody has one.
ozmoses is offline   Reply With Quote
Old 09-29-2013, 08:59 AM   #3
Kai Ju
Kai Ju's Avatar
Oddometer: 1,891
or as disston would say: Brand, model, mileage ?
I'm adding brand since I don't know whether this is even a BMW...
Kai Ju is offline   Reply With Quote
Old 09-29-2013, 12:30 PM   #4
190e
Oddometer: 748
Which side is fouling on your R75/5 the left or right?
Reason for asking is the engine breather on your bike dumps crankcase ventilation vapour into the right hand carb only so if it is the right it might be a breather problem. Could be other things like excess crankcase pressure due to piston blow by or worn valve guides.
190e is offline   Reply With Quote
Old 09-29-2013, 12:32 PM   #5
Plaka
Brevis illi vita est
Oddometer: 4,609
left side?
Running the same plugs as always? What plug are you running? (the brand and plug number)
Doing a lot of short trips?
Change type/brand of oil recently?
Miles on the bike?
Set the valves recently?
Old 09-29-2013, 12:49 PM   #6
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,768
...and if the bike was parked on the side stand, oil will sometimes get past the rings on the left side and smoke on start up.
Big Bamboo is online now   Reply With Quote
Old 09-29-2013, 01:38 PM   #7
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,723
If it is not the breather system and the bike is not being parked on the side stand then you are going to have to do a compression or a leak down test.
A lot of times it is the breather or parking. So, pray tell, what side is being fouled?
And try to answer some of the other obnoxious questions we ask too. A couple of them at least.
---Albert Einstein
Old 09-29-2013, 02:07 PM   #8
Jon-Lars
Jon-Lars
Jon-Lars's Avatar
Oddometer: 547
Drop off your bike and your credit card here:
https://itunes.apple.com/us/app/airh...386508280?mt=8
Cheers, Jon-Lars Sorenson
Beverly, WA
http://www.facebook.com/BMWR90S
Jon-Lars is offline   Reply With Quote
Times are GMT -7.   It's 06:01 PM.
