Old 10-18-2013, 08:02 PM   #1
smitty141 OP
smitty141's Avatar
Oddometer: 647
Alarm wiring removal??? Anyone???
Has anyone removed the goofy plug and extra wiring to clean up the area around the airbox??
Removing the SAS and canister and was wondering... Not sure if any of those wires are looped back to each other... Would love to just cut them back and add some heat shrink.
Smitty
RIP.. Skinny Dave...RIP.. Chester_______________
2015 KTM 690r Enduro, 2010 BMW 800gs. 2008 Suzuki DRZ400SM, 2004 KTM 450 EXC
smitty141 is offline   Reply With Quote
Old 10-18-2013, 09:33 PM   #2
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,137
Don't bother. You are asking for problems.
"Son, you can't do both"
Old 10-19-2013, 02:28 AM   #3
Peanuts
Peanuts's Avatar
Oddometer: 1,693
Do it!
I can email you a pdf wiring diagram if it helps? PM me your email address.
Peanuts is offline   Reply With Quote
Old 10-19-2013, 12:03 PM   #4
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,594
Smitty
Yes, its possible and I have done it on my 990 harnessed 950 EFI project.... the only thing that needs to be retained is the tie between 3 wires, off hand its the two ORG and the ORG/BLK. Pretty much everything else can be pulled back to the neck area and shortened.... If you want to go further, you might be able to pull them 100% from the harness. However it is a limit return on the investment of time/effort to do so.
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 10-19-2013, 12:31 PM   #5
smitty141 OP
smitty141's Avatar
Oddometer: 647
Im doing a valve check, and a SAS and Canister removal. Also going to throw in a new Wood air filter assm. I just see that 18" of do nothing wiring and thought it would be nice to remove a bit of clutter..
Thanks Smitty
Old 10-19-2013, 12:46 PM   #6
KaytM
Just a fella.
KaytM's Avatar
Oddometer: 202
Thumb
I tried jump starting my bike from a bmw X5 and the alarm box started smoking??
I removed it.
I too would like to get rid of the wiring all together as I'm fitting Safari tanks.
Keep us posted.
2006.5 990 ADVENTURE.
KaytM is offline   Reply With Quote
Old 10-19-2013, 02:06 PM   #7
Peanuts
Peanuts's Avatar
Oddometer: 1,693
The orange wire is from the ignition switch, via the kill switch. It is hot when both the above are in the run position.
The dummy plug (or the alarm if fitted and ready to run) connects this to the orange and white which gives power to the fuel pump relay and power relay.
All the other wires can be cut back and insulated. Or pulled all the way out the harness.
Peanuts screwed with this post 10-20-2013 at 05:16 AM
Old 10-19-2013, 08:12 PM   #8
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Yes take that shit out.
I've removed the alarm wiring back to the wires root on three bikes.
On the same bikes I've also remover the complete abs wiring harness's
and changed the R/R wiring to direct to the battery. Installing a Mosfet
R/R
Be sure to identify the two wires that are connected (with a small jumper
wire) in the alarm plug and connect them to each other permanently!
Might as well bring the low octane wires to a switch up front while your at it.
Twist it or crimp it or solder it, Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Times are GMT -7.   It's 02:55 AM.
