Old 09-29-2013, 08:46 PM   #1
LateNate OP
Oddometer: 325
Oil leak, where's it from?
Spotted a little puddle under her this morning. Where do you think its coming from?
DSC_0120
DSC_0117
DSC_0116
Counter shaft seal?
TAT
LateNate is offline   Reply With Quote
Old 09-29-2013, 09:21 PM   #2
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 805
Hard to tell with out pulling stuff off bike. C/S seal?
Clean it up and ride and look for source.
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 09-29-2013, 09:32 PM   #3
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,055
Gear position indicator most likely, the o ring shrinks up a bit over time and it weeps slowly.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Old 09-30-2013, 04:22 AM   #4
Orangecicle
Orangecicle's Avatar
Oddometer: 2,464
Gear position sensor. +1. This just happen to me.
The sensor is held in place by two allen-head bolts, and it has an O-ring for a seal. After 40,000 miles on my bike, the two allen-head bolts that hold the sensor in place loosened and allowed it to start leaking. I ordered a new O-ring, but then I didn't want to wait for the O-ring to show up, so I just covered the old O-ring in axle grease and put it back in. I put a little red Loctite on the two bolts. No leaks since.
The sensor is not under pressure, so it is OK to run the bike for a time with this leak. It's just annoying to have your Adventure piddling every time you stop like an old Triumph. Just get it taken care of before your bolts fall out.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 09-30-2013, 10:03 PM   #5
LateNate OP
Oddometer: 325
Awesome guys, thanks. Will look into those.
TAT
Old 09-30-2013, 10:44 PM   #6
Pete640
I hate sand.......
Pete640's Avatar
Oddometer: 1,714
Shaft seal ring.. Part 32 here:
http://www.boltonmotorcycles.com/find/fiche/211786
Pete
Tuetleshell5@icloud.com
For those who sit at home and dream-let them...Meoni
Pete640 is offline   Reply With Quote
Old 09-30-2013, 11:06 PM   #7
what car??
down the road
Oddometer: 370
Yup replaced it the other day for $.38 and about 10 minutes. Clean her up, no need to remove skid plate), lay her on her side (I've heard you can lose oil otherwise), remove side stand bracket, hell for that matter I guess you don't need the bracket, (please inform me if I'm wrong) (helpful to have the CJ Designs side stand, couple of reasons, one takes the side stand totally away from the engine case, and more bomber than the competitions supposed side stand relocators!), remove the two bolts , remove the "O" ring, install new "O" ring, replace sensor and bolts, test ride and place on sidestand to see if she's still leaking. Oh, and have a good micro in your newly non leaking ride...
Cheers
what car?? is offline   Reply With Quote
Old 10-02-2013, 05:04 AM   #8
duroturk
duroturk's Avatar
Oddometer: 262
Gear position sensor most probably.
I had the same problem with my 990 Adv and I was kinda lazy to remove the sidestand relocator etc. I left it alone and it stopped itself. :) It has been 10k more since then, no leaks.
Then it happened to my other bike 950 SM. I watched it for a while with praying to stop itself. And voila! Seems like it has stopped too.
Nurettin
duroturk is offline   Reply With Quote
Old 10-02-2013, 08:36 PM   #9
LateNate OP
Oddometer: 325
Thanks again
Good info guys, oh and the beers are always flowing!
TAT
Times are GMT -7.   It's 11:24 PM.
