Old 09-30-2013, 05:31 PM   #1
O Team OP
Oddometer: 76
990R Windscreen bolts/nuts????
I bought a used 2011 990R that came with only zip ties holding on the windscreen. I need to buy 6 bolt/nut sets to replace the zip ties, but I'm not sure if the standard after-market M5 bolts with wellnuts are what are required, since I never got to see anything installed except for the current zip tie set up.
Will the standard after-market M5 bolts & wellnuts work for me? Or do I need some fancy KTM bolts/nuts?
2011 KTM 990R
O Team is offline   Reply With Quote
Old 09-30-2013, 06:21 PM   #2
CRW
I dont want a pickle
CRW's Avatar
Oddometer: 802
Pretty sure you are going to need factory replacement. As the nut side is molded into rubber and serves as a friction fit.
06 KTM 950 ADV
2006 KTM 450 EXC
DMC FRAMED XR125
CRW is offline   Reply With Quote
Old 09-30-2013, 06:40 PM   #3
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,088
It uses a standard rubber wellnut that many bike windscreen use, not sure if its 5mm though. Fitment sucks on every screen i have seen, so if putting it on while the backing is attached to the bike, expect a fight.
Sheep Shagger is offline   Reply With Quote
Old 09-30-2013, 06:50 PM   #4
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,327
Just order a set of OEM bolts and rubber nuts.
Over the last several KTMWorld or KTMTwins orders, I've order a completes set of these, extra rubber, spacer and bolts for the tanks. Extra small bolt and washer/spacer for the upper tank cover, bolt clips for the lower tank bolts and extra bolts and a few odds and ends for other areas.
It seams on this bike, I'm always loosing bolts, washers or nuts/spacers, so now I've built up a supply of extras for most all parts that have to come off for general maintance.
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 09-30-2013, 06:54 PM   #5
laramie LC4
crash test dummy!
laramie LC4's Avatar
Oddometer: 2,368
yup, you need the special blind plugs.
Part Number:60008008050
Description:BLIND PLUG-IN NUT M5 WN 16A 03
Retail:$3.09
Part Number:0019050201
Description:COUNTERSUNK SCREW ISA25 M5X20
Retail:$1.49
Part Number:60008046000
Description:SPECIAL WASHER D=12MM 03
Retail:$3.09
kinda of ridiculous but you need 6 of each...
sorry,
laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW.
'12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
laramie LC4 is offline   Reply With Quote
Old 09-30-2013, 08:12 PM   #6
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,050
Yep, just a wellnut. I'd probably just buy KTM's wellnuts, but where I lose the screws and washers (little plastic bits, it would probably kill me to pay $3 for them), I just use buttonhead screws, stainless or black oxide.
Zak
ktm
old bmw
others
slackmeyer is online now   Reply With Quote
Times are GMT -7.   It's 03:34 PM.
