Old 10-01-2013, 09:53 AM   #1
Trailride802 OP
Oddometer: 2
Question 78 dt 250 front end and suspension swap
Hey guys I have a 1978 yamaha dt 250. I'm looking to raise the whole bike And give it a little more modern look so I'm wondering how to swap front ends with a newer/taller bike and what kind of rear monoshock I could replace the stock with to raise it a bit.
Thanks guys!
Trailride802
Trailride802 is offline   Reply With Quote
Old 10-01-2013, 05:14 PM   #2
joexr
Oddometer: 3,773
I put a CR250 front end on a DT400 I had and spaced the spring on the rear shock with a piece of PVC pipe to raise and stiffen it.
Old 10-02-2013, 03:03 AM   #3
tHEtREV
Captain Awesome
tHEtREV's Avatar
Oddometer: 7,728
There are a few lists floating around custom bike sites that have a lot of old Jap bike steering stem bearing sizes like this one.
http://hondachopper.yuku.com/topic/33230#.UkvuMxCyPfM
Scroll down and find your bike, and you will find others that share the same bearings, in your case,
Upper: 25 x 43 x 11
Lower: 30 x 48 x 12
Yamaha DT50B, DT50MX, DT50U/W/A (88-90)
Yamaha RD50MX (82), RX50K/L/MK (83-84)
Yamaha YSR50T-E (87-93)
Yamaha YZ50G (80)
Yamaha JT1/JT2/JT2MX (71-72)
Yamaha RD60/A/B (73-75)
Yamaha YZ60H/J/KM (81-83)
Yamaha DT80LC H/J/K (81-83), DT80MX
Yamaha GT80A-G (74-80), GT1/GTMX80 (73), GTMXA/MXB/MXC 80 (77-79), MX80G/H/J (80-82)
Yamaha RD80LC/MX(82)
Yamaha TY80A/B Trials (74-75)
Yamaha YZ80A-K (74-83)
Yamaha HT1/HT1B/HT1BM90 (70-71)
Yamaha AG100B
Yamaha DT100A-K (74-83)
Yamaha LT2/LT2M/LT2MX/LT3100 (72-73)
Yamaha MX100A/B (74-75)
Yamaha MX100F/H/J/K (79-83)
Yamaha RS100B/C (75-76)
Yamaha RT100A (90)
Yamaha YZ100C/D/E/F/G/H (76-81)
Yamaha AT1/AT1B/AT1C/ AT1E/AT1M/AT1MBAT1MX/AT2/AT2M/AT2MX/AT3/ 125 All (69-73)
Yamaha DT125 All (74-81), DT125LC (82)
Yamaha IT125G/H (80-81)
Yamaha MX125A/B/C (74-76)
Yamaha XT125J/K/KC (82-83)
Yamaha YT125N (85)
Yamaha YZ125A/B/C/X (74-76)
Yamaha AG175B
Yamaha CT1/CT2/CT3 175 All (69-73)
Yamaha DT175A-H (74-81)
Yamaha MX175A/B (74-75)
Yamaha MX175G/H/J (79-81)
Yamaha TY175B/C (75-76)
Yamaha YT175J/K Atv(82-83)
Yamaha YZ175C (76)
Yamaha SR185H/J (81-82)
Yamaha AG200
Yamaha BW200N/S/ES/ET/ EU (85-88)
Yamaha TW200 (87-92)
Yamaha TYM200EX/EL (83-84)
Yamaha XT200J/K/KC (82-83)
Yamaha YTM200K/EK (83), YTM200K/L (83-84)
Yamaha YTM225DXK (83)
Yamaha DT1/DT1B/DT1CMX/DT1MX/DT1S/ DT1C/DT1E/DT2/ DT2MX/DT250A-F/DT3 250 (68-79)
Yamaha MX250A/B (73-75)
Yamaha TT/XT250G/H/J (80-82)
Yamaha TY250A/C/D (74-77)
Yamaha XT250G/H/J/K/KC (80-83)
Yamaha XT250W (89)
Yamaha YZ250A/B/C (74-87)
Yamaha DT360A/B (74-75),
Yamaha MX360/A (73-74)
Yamaha RT1/RT1B/RTM/RT1MX360 (70-71)
Yamaha RT2/RT3/RT2MX360 (72-73)
Yamaha YZ360A/B (74-75)
Yamaha DT400B/C/D/E (75-78)
Yamaha IT400C (76)
Yamaha MX400B/C (75-76)
Yamaha YZ400B/C (75-76)
Yamaha SC500/A (73-74)
Yamaha SR500E/F/G/H (78-81)
Yamaha TT/XT500C-H (76-81)
Or find another set that has the same inner or outer bearing circumference and you could use a mixture of bearings to fit it.
This does not allow for different length stems though...
tEAM iDIOT.
A KDX is way cooler than what ever you ride...
tHEtREV is offline   Reply With Quote
Old 10-21-2013, 10:19 AM   #4
Trailride802 OP
Oddometer: 2
Wow thank you! are those the only ones that would fit if I pressed out the ste
Old 10-21-2013, 10:57 AM   #5
gloud
Oddometer: 158
You can use a set of forks off an RT180 they are a little longer and definatly ride better. Bolt right up.
gloud is offline   Reply With Quote
Times are GMT -7.   It's 01:02 PM.
