Old 10-02-2013, 02:07 PM   #1
Dellis OP
Dellis's Avatar
Oddometer: 71
990 Adventure ABS Fault
Was out and about camping at the weekend, all was well on saturday but on sunday the ABS light stayed on after her the usual couple of wheel revolutions and remained on all day. I tested the ABS by locking the rear wheel and sure enough it wasn't working. So this evening I've investigated and found the fault a corroded connection. The connection is under the right hand sump guard plastic side cover, as you take the cover off it's the white two wire connector towards the front of the bike. I've cleaned the connector but think I'll replace it in the near future with a weatherproof one. Ran it up the road and the light went off and I've tested the ABS again with the rear brake and all is now well. Just thought I'd share in case it helps anyone else with a similar fault. Out of interest it's a 2012 model with about 25,000 miles on it ridded year round for pleasure only :)
Dave
Ya bugger...........
Dellis screwed with this post 10-02-2013 at 02:13 PM
Dellis is offline   Reply With Quote
Old 10-02-2013, 02:18 PM   #2
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Could you take a pic of the location?
Thank you!
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 10-02-2013, 02:23 PM   #3
Dellis OP
Dellis's Avatar
Oddometer: 71
Will do but not tonight I'm having a beer to celebrate a lucky find :)
Dave
Old 10-02-2013, 02:24 PM   #4
bikyto
bikyto's Avatar
Oddometer: 2,190
Dave
Old 10-02-2013, 02:30 PM   #5
Dellis OP
Dellis's Avatar
Oddometer: 71
Found a pic on Google it's the white connector that is separated on this pic just to the lower right of the starter relay.
Hope that helps.
Dave
Old 10-02-2013, 02:37 PM   #6
bikyto
bikyto's Avatar
Oddometer: 2,190
Yep, that will do! Thanks for posting this.
Old 10-03-2013, 01:14 AM   #7
extremusski
Oddometer: 22
Abs
Hello.
You are lucky about ABS. My light was on, and after i verified the connections everything was well. I was at the ktm dealer and they put the tester on it and they told my the ABS unit not respond.
Now i try to find an ABS unit on sale, because the price of a new one its about 1800 $
Cheers.
extremusski is offline   Reply With Quote
Old 10-03-2013, 09:45 AM   #8
KMC1
There is no spoon.
Oddometer: 2,561
Check with Modulemasters in Idaho. They have been doing rebuilds on the BMW ABS pumps for a while, and I've heard good things. I am not sure they can do the KTM pumps however.
HTH
Obama says adding $4 trillion to debt is unpatriotic: http://www.youtube.com/watch?v=1kuTG19Cu_Q&sns=em
An Overview of the United States National Debt: http://www.davemanuel.com/us-national-debt-clock.php
KMC1 is offline   Reply With Quote
Old 10-03-2013, 10:16 AM   #9
Jody H
Oddometer: 397
Originally Posted by extremusski View Post
Hello.
Cheers.
On my '07 I removed the ABS completely. I think everything is in a box in my attic, if so i'll make you a heck of a deal on it.
What parts do you need?
PM me.
'07 Aprilia Tuono
'07 Aprilia RXV 4.5
'07 KTM 990 Adventure
'09 Aprilia Mana
Jody H is offline   Reply With Quote
Old 10-03-2013, 11:04 AM   #10
Renierd
Renierd
Oddometer: 47
Had the same issue with mine just after I bought it, but the speedo also didn't work, turned out to be the regulator that packed up. Not sure if yours has the same problem.
Sent from my iPad using Tapatalk - now Free
Renierd is offline   Reply With Quote
Times are GMT -7.   It's 11:02 PM.
