Old 10-03-2013, 03:34 PM   #1
Two Moto Kiwis OP
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,883
Regased And Rebushed Rear 950 SM Shock But Still Knocks???
Anyone got any good ideas?, not spending any more money on it now but the bloody thing still knocks between compression and rebound stroke and things that knock or clack wear out.
It has me beat, there is nothing else to do to it so I am stumped.
Ocers with good knowledge on these please chime in.
Thanks Andi
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 10-03-2013, 09:19 PM   #2
DirtyADV
DirtyADV's Avatar
Oddometer: 2,285
Swing arm bearings? Loose spokes on the rear wheel?
Just spitballing, well just woke and mouth is super dry so doubt I could actually spit.
Or are you sure its in the shock?
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 10-04-2013, 05:34 AM   #3
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,883
/Johan
Heya Johan
Thanks for those, will check again but they all seem to be ok.
When I grab the back of the bike and push down it goes down almost quiet but when is starts to rebound there is a clunk, it gets worse when cold.
So when we start cold in the morning saying on a boney shingle road it knocks and chatters to the point I can feel it through the pegs, as everything warms up the noise get lesser.
Trying everything that can move and tying them up with cable tie everything points to the shock.
When someone bounces the bake end and you put you finger on to the reservoir you can feel a clunk but can't feel where it is coming from.
I am stumped and I don't wonna spend more on the shock, we have paid twice to have it regased and reolied, second time was because it was still knocking and I thought it had not been done properly.
In Bogota they have an actual injection machine so as high tech as the US.
So what else can it be...it is annoys me feeling and hearing it knowing we have a long way to go yet.
Old 10-04-2013, 09:17 PM   #4
David37
David37's Avatar
Oddometer: 400
Typically, when you feel a knocking in the shock it is either bottoming out or topping out. To measure the shock travel, install a zip tie on the shock shaft to see if you're bottoming out. Topping out is when there is not enough rebound and when the shock fully extends it tops out.
If you feel a knocking in your shock and its not topping or bottoming out, IMO you might have a bent shock shaft or a damaged shock piston. When you had your shock serviced, did the shop completely take apart the shock and inspect all the internals?
I would also check the bearings and bushings on the top and bottom eye lets of the shock to see if that could be the source of your knocking.
David37 is offline   Reply With Quote
Old 10-05-2013, 01:42 PM   #5
PowerCell
Manufacture
PowerCell's Avatar
Oddometer: 2,395
It sounds like the reservoir piston height was not set properly. It will require a full bleed along with setting the piston height and re-gassing...
~ Ken
www.powercellperformance.com
PowerCell is offline   Reply With Quote
Old 10-05-2013, 03:05 PM   #6
Two Moto Kiwis OP
Homeless Somewhere
Oddometer: 3,883
Hmmm it is a mid stroke knock, checked all bushes etc, no movement anywhere
Originally Posted by PowerCell View Post
It sounds like the reservoir piston height was not set properly. It will require a full bleed along with setting the piston height and re-gassing....
Heya Ken, the machine shop in Bogota has the injection machine and bleeder so it is supposed to have been done properly.
Interested in the piston height setting, the company that did everything in Medellin said everything was done but we still have the knock, we have paid to have it done twice, I am 100% sure it is in the reservior too.
Two questions,
Where would I find info on the piston height?
Will this knocking stuff things?
Cheers Ken, appreciate your help.
Times are GMT -7.   It's 09:04 AM.
