Old 10-03-2013, 10:25 PM   #1
Hazman27 OP
The Haz
Hazman27's Avatar
Oddometer: 652
easier way 60csx?
So I want to send a gpx file map from central forum to my 60csx, when I open the gpx file may computer says cannot open... God, I just need a 1,2,3,4,5, steps to follow. this is real close to the last time for this.
Hazman27 is offline   Reply With Quote
Old 10-03-2013, 11:07 PM   #2
mcnut
Oddometer: 1,364
Maybe share what software you are trying to open the file with and post a link to the file.
Bruce
mcnut is offline   Reply With Quote
Old 10-04-2013, 09:00 AM   #3
wbbnm
wbbnm's Avatar
Oddometer: 1,981
I would use Mapsource to do this.
If you don't have it try to get it or download Basecamp from Garmin.
Connect your 60csx to the computer via a USB port
(if this is the first time you might have to go thru some driver installation windows.)
Open the file in Mapsource or Basecamp
In Mapsource use the icon showing an arrow to the GPS unit. You might have to hit the Find Device button the first time.
Haven't done it in Basecamp. You use the File\Import into List command to get the file into Basecamp. Then I would right click on the file ("List") and select "Send To" and then select the GPS unit from the resulting list.
You can put the 60 in disc mode and send the gpx file to it, but the unit will not recognize it as having track/route/waypoint information.
You have to use the special transfer protocol in Mapsource and I assume Basecamp.
wbbnm is offline   Reply With Quote
Old 10-04-2013, 11:21 AM   #4
mcnut
Oddometer: 1,364
Not sure this is correct. While I use MapSource and BaseCamp there are many other utilities which can open GPX files and format them for loading to a 60. Maps are another matter.
Bruce
Old 10-04-2013, 02:29 PM   #5
wbbnm
wbbnm's Avatar
Oddometer: 1,981
Bruce
Sorry I should have been clearer. When I said special protocol I was talking about how route/track/waypoint data is sent to the 60. Not about handling the input gpx file.
I was trying to emphasize that you cannot just copy a gpx file to the 60 and expect the 60 to recognize tracks and stuff.
Maybe another term would be better, but I tend to think of the way Mapsource sends track data to this class of GPS units as a special protocol.
Old 10-04-2013, 09:37 PM   #6
Hazman27 OP
The Haz
Hazman27's Avatar
Oddometer: 652
response
OK, Got it, jeezus, my usb to mini usb cord had been nicked, I presume by either one of two boys who like to use it for their Nintendo(s). I have opened, saved, transferred before. It was just not doing right this time, so I had to get out the manual and start all over. process of elimination had me beyond frustration. Now the problem is that city nav is not showing the streets on the gps screen anymore, hmmm.
Lastly, has anyone tried to link two 60s' via mini to mini usb to transfer files?
Old 10-04-2013, 10:50 PM   #7
mcnut
Oddometer: 1,364
I recall Garmin have a Garmin to Garmin interface but have never heard of anyone doing it with a 60/76, Countdown would be the one to ask.
Losing street detail in CN doesn't sound good, check the usual things like zooming out to see the map tiles, checking that CN is set to show and detail level is "Highest".
If I have any question regarding communication I use the tool to "Get Unit ID".
Bruce
Old 10-05-2013, 09:35 AM   #8
Countdown
Oddometer: 5,284
Same answer: it was on lod units via serial port I think and now on new uinits via wireless. Can't transfer between units on 50/76.
When you did download, did you have "Maps" checked? If so I assume it would erase what was there and then download nothing.
Jerry Counts
Countdown is offline   Reply With Quote
HTML code is Off
Times are GMT -7.   It's 12:54 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
