Old 10-04-2013, 09:11 PM   #1
kiw OP
kiw's Avatar
Oddometer: 80
Canisterectomy attempt ktm 950
Hi all,
I opened up my bike today to change an intake vent tube a bought a while ago, but I realized it was useless if I removed the SAS and EPC system, which I did. SO I took most of the crap out and plugged the rest. I figured I'll by the vaccum caps and the plates later, see if the bike runs better.
I fire, the bike cranks, but it wont start.
Any ideas?
I followed 2 procedures from ktm.info, which are actually different.
http://www.ktm950.info/how/Orange%20...pc_removal.htm
http://www.ktm950.info/how/Orange%20...terectomy.html
Until then, Im on my bicycle ....
kiw is offline   Reply With Quote
Old 10-05-2013, 11:20 AM   #2
renogeorge
Oddometer: 1,393
Hard to tell from info provided.
Maybe a fuel line problem--kinked under air box?? Problem with quick disconnect? can you hear the fuel pump operate?
If you haven't installed SAS block off plates, did you plug the lines from the SAS connections at the heads?
Vacuum line issues can also cause problems. Did you plug or cap the taps from the manifolds?
Carb vent hoses run down and out the bottom of the air box into the V between the cylinders? Lengths per TSB
Good luck.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 10-07-2013, 06:29 PM   #3
PABiker
Anywhere but here
Oddometer: 3,913
Did you remember to open the fuel taps and left tank petcock?
'03 Suzuki DL1000 V-Strom
'12 Suzuki DR650SE
'10 Husaberg FE450 Plated
PABiker is offline   Reply With Quote
Old 10-09-2013, 04:04 AM   #4
Blackalac
Oddometer: 79
I think you will find a unsealed vacuum hose. I had the same situation.
If I recall it is the one that goes to the canister
Blackalac is offline   Reply With Quote
Times are GMT -7.   It's 01:13 PM.
