Old 10-11-2013, 06:37 PM   #31
Bayner
Oddometer: 1,557
Vapor lock is not nearly as big a problem on a 40 psi system as compared to a carb running at 4. I doubt it'll prove to be problematic.
Bayner is offline   Reply With Quote
Old 10-11-2013, 08:15 PM   #32
ebrabaek
Oddometer: 4,726
Perhaps not, but there is an awful lot of heat coming right off the engine at that spot. Hopefully I am wrong.
Erling
Old 10-13-2013, 04:15 AM   #33
Snowy
Oddometer: 1,722
about 300kms on it, no issue.
The fuel line was just as close without the filter.
Being EFI it circulates fuel through the fuel rail, so temperature rise will be regulated by the volume of the system.
It may well heat it up on a longer trip. But with airflow...dunno...we'll see.
I've had plenty of cars with filters in horrible hot locations that have never played up.
Snowy is offline   Reply With Quote
Old 10-16-2013, 03:57 PM   #34
JRWooden
Oddometer: 4,249
Testing resistance to flow?
Ok ... so fellow ADVRider McCardigan was kind enough to send me his suspected clogged filter..................
Thinking about it, it would be nice to measure "resistance to flow" somehow before doing an autopsy ...
I was thinking about maybe attaching a big funnel to the inlet of the fliter and pouring (say) 1 qt of gasoline into the filter and timing how long it took to get thru the filter ... then try the same trick with a new filter of similar characteristics....
any other thoughts/ideas?
Old 10-16-2013, 05:16 PM   #35
Dorito
Dreamer and Doer
Dorito's Avatar
Oddometer: 5,296
Could you try to pull a vaccum on it using an altercated brake bleeder?
BlastOff Adventures
Nothing (ad)ventured, Nothing Gained
Everything you want is on the other side of fear.
Dorito is offline   Reply With Quote
Old 10-17-2013, 02:38 AM   #36
dpm
Oddometer: 164
Snowy, I'm pretty sure this system does NOT "circulate" the fuel- there's neither pressure regulator valve nor return line on the rail, rather the pump is controlled by feedback from a pressure sensor.
On a flow test JRW, I'd be thinking about utilising the bikes own bits to test- say 10secs open flow with the pump controller overridden
or
what does the pump do at key-on? I've never checked this so maybe someone has the info. Is it run for a specific time to purely test the pump or does it run up to a preset pressure? Either way you could have a quick test of flow vs time and that's a good indication of filter restriction.
dpm is offline   Reply With Quote
Old 10-17-2013, 09:40 AM   #37
MKorn
2whl Addict
MKorn's Avatar
Oddometer: 744
Header wrap
If heat did become an issue, i am willing to bet that some header heat wrap tape would keep the heat off the filter.
Always looking for a place to ride !
13 F800GS
09 Concours 14 ABS (sold)
02 Nighthawk 750 (sold)
06 DRz 400s
MKorn is offline   Reply With Quote
Old 10-18-2013, 11:46 AM   #38
JRWooden
Oddometer: 4,249
or
dpm ... yeah... I like that idea on testing the filter ... a shame I don't have a spare pump ... I probably SHOULD have one anyway right?
And yes.... Joel commented some while back that there is no return line back to the tank the system controls pressure by modulating the fuel pump controller ...
I think the "Key on" setup just runs the pump long enough to pressurize the rail and then shuts off ............
Old 10-18-2013, 03:31 PM   #39
Girthy Knobkers
Girthy Knobkers's Avatar
Oddometer: 523
Used the same filter as the 1150GS. Did this before my Alaska trip. Made it, played around, rode back. Still no problems...
Girthy Knobkers is offline   Reply With Quote
Old 10-18-2013, 05:42 PM   #40
Full Power OP
Oddometer: 1,472
GK:
Did you remove the In -Tank filter before installing the new inline unit ?
Warm enough to RAIN is warm enough to RIDE.
Full Power is offline   Reply With Quote
Old 10-18-2013, 07:46 PM   #41
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,339
Uh, I got 2 spare gas tanks complete now......one spare for each bike. Maybe I should build a filter flushing rig.
I still think the 1150 filters are the way to go if only an adapter was made for the output end so they could remain in the tank. I've changed plenty of those types just on prevention. Our gas doesn't seem to wreck them or I'd be more inspired to look into it further.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 10-19-2013, 02:22 AM   #42
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,663
I'll give the Mahle KL18 a try. Seems to have the right dimensions and is used on Mercedes G series. This only can work . Will be my project during spring :o).
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is online now   Reply With Quote
Old 10-19-2013, 02:45 PM   #43
JRWooden
Oddometer: 4,249
I will probably buy one of ebay... i need a spare, and I can also use it as a test rig and transfer pump till mine craps out...
Loutre: Doesn't the KL18 have male fittings on both ends?
We need the "female" fitting (I don't know what the hell you really call it) on the output side ...
Why BMW did that to us is another question I'd like to understand........
Reaver ... what would your flushing rig look like if you made one?
Old 10-19-2013, 04:54 PM   #44
MikeMike
MikeMike's Avatar
Oddometer: 4,150
I think they call it a bidet.
Old 10-19-2013, 05:13 PM   #45
Reaver
Outta Here
Reaver's Avatar
Oddometer: 3,339
I don't care who you are, that right there is funny!
I'm about to swap out my old assembly with that new one you were drooling over. I have a Jeep fuel pump of the same design (but larger). I figured I'd get a rheostat thing and pump fuel backwards at low pressure into the output barb and see what happens. Blow it all back through the pump without disassembling it. I may wreck it or start the garage on fire but it wouldn't be the first time.
Times are GMT -7.   It's 12:23 PM.
