Old 10-05-2013, 12:16 PM   #1
roger 04 rt OP
roger 04 rt's Avatar
Oddometer: 2,296
Starter or Battery 2004 R1150
I've been working my way through trying to figure out why my '04RT has gotten progressively slower starting over the past year--on the first cold start of the day. I've tested every aspect of the fuel system from the strainer to the injectors and verified the HES. The battery seems fine and the starter turns over quickly (I think since I've got no comparison). Throttle bodies are balanced and it idles well.
With two new stick coils (and the replacement of all four plugs), my '04RT is running like great. And it starts fine ... other than that first start of the day, which takes 4-5 seconds.
Yesterday I decided to take some data on the first start with the GS-911 via bluetooth to my phone. With it connected to the 911, the samples are logged every half second (400 mS) versus every second (800 mS) to the PC i usually use, nearly twice as fast.
Looking at the battery voltage in the log, here's what I saw:
12.19 V, 0 rpm
12.11, 0
12.11, 0
6.82, 0
10.24, 350 rpm
10.89, 350
10.73, 200 rpm
11.05, 1400
13.73, 1500
My battery appears to be in good health (a one year old PC680, it will crank the bike for a long time with a bright headlight) and the starter seems to turn over fine. But looking at the voltage dip I decided to try jumping from my car with its motor running.
This morning I pulled the left-side panel, got good jumper connections all around--ground to the bike's battery and +12V to the starter lug. Set up logging and pressed the starter button ... er, er, vroom. According to the log (and my ears) the bike started in 1 second.
Here was the voltage log:
13.98 V, 0 rpm
9.99, 0
11.46, 300
11.95, 1350
13.9, 1400
14.06, 1450
Last winter, I pulled my starter because of a high drain on the battery and very hard starting every so often. The planetary gear cover had fallen onto the armature. Based on the test today, I'm leaning toward replacing the starter. My reasoning is the cables and connections look good, and even with the jumper cable to the starter lug the voltage dipped from 14V to 10V.
I'm thinking that without the jumper cable connected, the dip to 7-9 volts when the starter is pressed is upsetting the Motronic, or coils, or injectors.
Starter or battery, which do you think?
RB
roger 04 rt is offline   Reply With Quote
Old 10-06-2013, 03:26 PM   #2
PETDOC
User Awaiting Email Confirmation
Oddometer: 1,212
Don't know, but my '04 1150 GS had a starter magnet loosen up and produced very intermittent low voltage when starting. It worked fine for 2-3 weeks then wouldn't turn over until the 2nd or 3rd push on the starter button. The low voltage zeroed out my clock. Apparently the 2004 starters have a problem with magnets letting go.
PETDOC is offline   Reply With Quote
Old 10-06-2013, 03:43 PM   #3
mouthfulloflake
Not afraid
mouthfulloflake's Avatar
Oddometer: 17,741
Mine fragmented a magnet too, stopped the started cold, and I was stranded.
If you have never been through the starter, its pretty easy to remove, take apart and clean.
On a GS at least, not sure about the tupperware on your prettier bike.
Oh wait, you know this already.
Smoke em if you got em, and drink your glasses to the bottom...-Will Whitmore
Charter member: T.O. club.
mouthfulloflake screwed with this post 10-06-2013 at 04:09 PM
mouthfulloflake is offline   Reply With Quote
Old 10-06-2013, 03:54 PM   #4
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,566
Roger, I would start by reconditioning the starter. No actually I would start by measuring resistances of the starter's windings and commutator then recondition based on what you found with the VOM.
def is online now   Reply With Quote
Old 10-06-2013, 03:59 PM   #5
def
def's Avatar
Oddometer: 10,566
12.19 V, 0 rpm
12.11, 0
12.11, 0
6.82, 0
10.24, 350 rpm
10.89, 350
10.73, 200 rpm
11.05, 1400
13.73, 1500
13.98 V, 0 rpm
9.99, 0
11.46, 300
11.95, 1350
13.9, 1400
14.06, 1450
RB
I wonder if the high current solenoid contacts need some service?
Old 10-06-2013, 08:26 PM   #6
roger 04 rt OP
Oddometer: 2,296
Thanks everyone. I've gotten some good Feedback here and from a couple guys on the battery voltage data. I'm going to make some more checks and report back.
I've had the starter apart for cleaning, solenoid hang--and for planetary gear cover after it dropped onto the armature. Depending on the battery tests I may go for a new starter.
RB
Old 10-06-2013, 09:26 PM   #7
BluByU
BluByU's Avatar
Oddometer: 497
I had almost the same readings, replaced the starter, all cool now.
Yes, do tare down the starter, would like to hear what you find (got a starter in a box and would love to make it worth keeping)
BluByU is offline   Reply With Quote
Old 10-07-2013, 07:11 AM   #8
roger 04 rt OP
Oddometer: 2,296
A PM pointed me to pc680 technical data. Apparently the odyssey batteries are supposed to be charged at a MINIMUM of 6/7 amps at 14.2-15.0 volts.
I've looked through all my logs and the regulator never gets to 14.2 volts and is usually between 13.7 and 14.1. My charger, a battery tender jr., for trickle charge doesn't put out much current.
After a day and a half of rest, the voltage is 12.9v that seems okay.
With the headlight low beam on the voltage drops to and stays at 12.1 volts for 15 minutes.
Could my continual charging of the battery for a year and a half at lower than spec have affected the battery such that it drops to 7v during starting?
RB
Old 10-07-2013, 08:32 AM   #9
def
def's Avatar
Oddometer: 10,566
RB
Suggestions;
1- You might want to measure the internal battery resistance.
2- A call to the battery manufacturer might reveal some interesting details.
3- Might a subsitution of the PC680 with the car battery (I would use jumper cables instead of removing the battery from the donor vehicle, engine off and the automobile neg terminal disconnected) reveal some interesting data at cold start.
Old 10-07-2013, 08:39 AM   #10
larryboy
Chopper Rider
larryboy's Avatar
Oddometer: 15,038
I had one of those PC batteries in my Buell, it just never started with authority like stock or the Deka I replaced the Odyssey with.
However, on my 1150 the starting was getting slower and screechy, replaced the starter and the tiny Lithium Ion is back to cranking it with authority.
I'd replace both the starter and battery on your bike.
larryboy is online now   Reply With Quote
Old 10-07-2013, 08:39 AM   #11
Ravenslair
Oddometer: 487
This thread reminds me that I should pull my 04's starter and clean it up and take a look to make sure is all well in there.
Ravenslair is offline   Reply With Quote
Old 10-07-2013, 08:43 AM   #12
def
def's Avatar
Oddometer: 10,566
RB
My electrical system on my '01 GS seems to be rather gentle regarding voltage and charging current. I say this based upon little scientific evidence and the fact that all the fuses are OE and I have burned out only one bulb on the bike in its lifetime, the low beam H1 OE bulb. As such, I would say that the PC680 would likely benefit from some rather high discharges and charge cycles such as you suggest, 6-7 amps at 15.0 VDC. But, the manufacturer would be a better source for such a discussion rather than my unscientific and lay knowledge of the PC680 AGM battery which I too have used on my GS for the last 5 years.
Old 10-07-2013, 08:57 AM   #13
mouthfulloflake
Not afraid
Oddometer: 17,741
Like I had previously mentioned Roger, I used those batteries ( pc625 actually) for years in \watercraft, they didnt bring htem up to 14.2+ volts either.
i think the 680 is simply not enough battery for the oilheads based on LarryBoys feedback.
I put one of those pc625 batteries in my gs when I bought it in 2009, originally purchased the battery in 2005.
removed it from service earlier this year , was still cranking fine, but starting to roll over slow on cold ( under 50F) mornings.
the 625 has more cca than the 680 I think.
Old 10-07-2013, 10:23 AM   #14
def
def's Avatar
Oddometer: 10,566
The PC680 is rated at 170 CCAs
The PC625 is rated at 200 CCAs.
That difference may or may not be significant. I think starter motor maintenance may be more of a factor in long cranks for cold starts.
There are dimensional differences that may preclude the 625 from being used in some BMW R models.
Interestingly, I reviewed the battery charger recommended by Odyssey for both the PC680 and the PC625. The charger looks suspiciously like the Schumacher 600A charger I use routinely for all my battery charging.
Old 10-07-2013, 10:40 AM   #15
mouthfulloflake
Not afraid
Oddometer: 17,741
yes, the charger looks similar, but apparently is not, given the different charging abilitis.
I can tell you the look alike charger can not get a pc625 above 14.2 volts in any of its normal charge modes.
you may be right about the slight difference in the CCA though, but that slight difference with some slight degradation of the chemical process might have put Roger where he is now, who knows.
and yes, I had to modify my battery tray to fit the 625
http://www.advrider.com/forums/showp...9&postcount=31
Times are GMT -7.   It's 09:20 AM.
