Old 10-07-2013, 07:59 PM   #16
zgfiredude
Oddometer: 835
Chris, The 950 stock fender is closer to the tread of the tire than is that on the 990. Mud packs in there and rips off the 950 fender which due to the cross-over front brake line, is a BAD thing.
I "think" that the 990 mounts are slightly different than that of the 950 (at the fork leg attachment) and therefore, a simple upgrade to the 990 front fender doesn't work.
If you could fab up a simple spacer for the mounting points so that the 950 stock front fender could be raised up for a bit more clearance, I for one would be first to buy a set!
'06 950S Adv, DRZ440E, KLX440R, DRZ250, & F650GS
zgfiredude is offline   Reply With Quote
Old 10-07-2013, 08:18 PM   #17
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Yeah, there's a significant issue running the stock front fender in sticky mud. The solution for the hard-core is the high fender mod; however that comes with some significant trade offs, including extra mud in the radiator, etc, as well as the potential for a face full of mud and water spray at speed. A few have raised the stock fender enough to allow extra mud clearance while keeping the stock fender.
Clearance at full travel must be evaluated carefully for this to work....
SA
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 10-07-2013, 08:20 PM   #18
CPRFAB
Oddometer: 208
What year 950's? Or all? Would this include brake lines? (which we can do)
CPRFAB is offline   Reply With Quote
Old 10-07-2013, 09:04 PM   #19
zgfiredude
Oddometer: 835
I believe that all 950's are the same.
When folks do the high fender mod, they also go to the 990 style of dual long brake lines with the double banjo at the master cylinder rather than down at the caliper (on the 950).
The ultimate I suppose would be to also have a brake line holder/bracket for the new long right side brake line that coordinated with the stock left side mount.
I'd buy a one stop "kit" of brake line, extension brackets, and left brake line mount.......hint, hint!
Old 10-07-2013, 10:54 PM   #20
DesertSurfer OP
Tail sprayin
DesertSurfer's Avatar
Oddometer: 1,393
Hey Chris,
I've got all the specs for you. I can come by and let my bike be the guinea pig for ya. I recently did the brake conversion too so you can see what a kit would require.
'"This whole memory lapse is gett'in to me. Hopefully I think I'll outgrow it."
DesertSurfer is online now   Reply With Quote
Old 10-08-2013, 09:02 AM   #21
CPRFAB
Oddometer: 208
Originally Posted by DesertSurfer View Post
Hey Chris,
Let's do it. Seems like there is interest. Anyone else interested in this??
Chris
Old 10-08-2013, 09:37 AM   #22
DesertSurfer OP
Tail sprayin
Oddometer: 1,393
Maybe it's worth starting a new thread with subject header about low fender riser interest... from CPR?
Old 10-08-2013, 10:17 AM   #23
txbear55
Oddometer: 262
Definitely interested...I have already cracked a mount on my 2011 990. I believe there is a photo from the recent KTM Rally with a ripped off fender as an illustration of the problem.
txbear55 is offline   Reply With Quote
Old 10-08-2013, 11:27 AM   #24
Alleycatdad
Oddometer: 1,439
Yep, it's not only the 950s, although that crossover line makes the potential downside of tearing the fender off a 950 considerably more painful than on a 990.
If you're not reading this ride report (oso loco):
http://advrider.com/forums/showthread.php?t=913598
Go read it.
How it relates to the situation at hand:
http://advrider.com/forums/showpost....&postcount=660
SA
Old 10-08-2013, 11:51 AM   #25
brents347
Trusting my Cape...
brents347's Avatar
Oddometer: 3,735
Here is the one we ran into on the way to the rally.
This was on a 990. Locked up the front wheel (slow speed) and sent the rider down. We removed the fender to get the bike out of the mud.
07 Yamaha R6
07 KTM 950 Super Enduro
04 KTM 250exc- plated two-stroke
01 Kawasaki KE100
74 Honda MR50
brents347 is offline   Reply With Quote
Old 10-08-2013, 02:09 PM   #26
CPRFAB
Oddometer: 208
Okay, this looks like the same as my 2012 R. I have that stuff and will see what I can come up with.
Old 10-08-2013, 03:58 PM   #27
Alleycatdad
Oddometer: 1,439
The 950s aren't the same as the 990s....
SA
Old 10-08-2013, 05:17 PM   #28
Zander
Zander's Avatar
Oddometer: 194
Snap Out bracket ordered !
What a great idea. This is going to be a real time saver.
Thank you Chris.
Beginner's mind !
KTM 950
Zander is offline   Reply With Quote
Times are GMT -7.   It's 10:58 AM.
