Go Back   ADVrider > Riding > The Perfect Line and Other Riding Myths
Old 10-21-2013, 04:38 PM   #31
snoman002
Oddometer: 142
Each gear.
One, its easier to count, but more than that its feel. Counting is the correct way to do it, knowing which gear to be in for every corner, but for us non-track junkies the gear number isn't as set for each corner and we don't have to try and think 'was it down two here, or three?' on the ever so critical corner entrance. This way we can ride by feel too, not just math. Sure, I've gone one more gear than I should have and ended up with a bike redlined before the corner exit and no more to give, and I've done the other way too and ended up putting out of the corner. But at least I had that feel of the bike and engine before I made that decision. I would rather have that then end up getting a great drive off the last corner and find now the next corner is a bottom of third corner and not a top of second corner like it was last time AFTER I let the clutch out in second (track noobs here remember).
Two, your still letting the engine spin down some in that last gear before you tip in. Blip it and let it spin down while your finishing your braking. You don't blip and downshift exactly to the RPM your going to run the corner with (not us noobs anyways), so get it done early and focus on the more important parts, like smooth throttle application, and entry points, don't try and smash all that in at your most critical moment.
The blip takes a while to learn, but is possible on near every bike. But, increase the displacement and lower the number of cylinders and the margin for error gets smaller. I can blip a 600 inline like nothing, my 1000 CC twin was a bit harder, and my single took a while to learn (yes, I blip an XRL). Just practice blipping it without the brakes, completely slowing down to 1st by engine alone. Once you get that down, work on adding some front brake in, a little at first and then work you way up. But, if you can't blip one gear at a time, what makes you think doing 2 or 3 will be better.
Now, the kicker. Not using the engine to brake is better, and typically faster, from what I have heard.
snoman002 is offline   Reply With Quote
Old 10-21-2013, 09:36 PM   #32
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
Originally Posted by ZiaThunder View Post
In short, you down shift before you roll off. Sounds odd, I know, but it works.
I do something like that, but only on the street, I can't say I've ever tried that at track pace. I basically clutch with the throttle steady and it just sort of "falls" into the right RPM.
Of course I don't usually blip and brake at once in traffic, not enough tension on the brakes to do it smoothly.
Originally Posted by RottenScummyTroll View Post
Show folks something with a clutch and carburetor, and it's like teaching a baboon to use a Macbook.
Tripped1 is offline   Reply With Quote
Old 10-22-2013, 05:20 AM   #33
beendog
Oddometer: 17
This is as good a place as any to pose this question:
Do you have more traction in a turn when you are coasting with the clutch in or when driving the rear with maintenance throttle.
It seems to me that coasting does, because you aren't consuming traction at the rear to overcome wind resistance, but I have been wrong before.
beendog is offline   Reply With Quote
Old 10-22-2013, 06:37 AM   #34
ZiaThunder
Go big or go home
ZiaThunder's Avatar
Oddometer: 655
ooh ooh.... This one is easy.
NEVER coast in a corner. You have a harder time turning in if you are coasting and you have less clearance if you are coasting mid corner.
Much safer to be on the gas.
My scarest moments at the track have been when I've hit a false netural or actuall netural and couldn't get on the gas in the turn. It's the only time I've dragged hard parts in a corner. (well, before I started racing the 250, but that another story)
I know you asked about traction, but if you don't have clearance. Traction doesn't really matter. It's also easier to lose the front coasting, need to get more weight transfered to the back tire, (larger contact patch) as soon as you can.
ZiaThunder screwed with this post 10-22-2013 at 06:39 AM Reason: I can't spell
ZiaThunder is offline   Reply With Quote
Old 10-22-2013, 06:40 AM   #35
ZiaThunder
Go big or go home
ZiaThunder's Avatar
Oddometer: 655
Originally Posted by Tripped1 View Post
... I basically clutch with the throttle steady and it just sort of "falls" into the right RPM....
Exactly! Unless you play with it, it is rather hard to wrap your head around it.
Old 10-22-2013, 06:48 AM   #36
ZiaThunder
Go big or go home
ZiaThunder's Avatar
Oddometer: 655
http://www.youtube.com/watch?feature...&v=CJxzyXFuj9c
an example of what coasting through a corner is like verse what being on the gas is like...
IT's a couple of laps around the local track. You can hear a downshift not blipping in the first 10 sec. The the going to netural, then a couple more corners, then more downshifting.
Old 10-22-2013, 07:42 AM   #37
car94
What's this Box for?
car94's Avatar
Oddometer: 3,885
Thumbs down its spoiled
Never ever ever ever ever ever Short shift
Ride Your Own Ride
car94 is offline   Reply With Quote
Old 10-22-2013, 08:12 AM   #38
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
If I'm coasting through a corner the bike is broken
....and that is why your name is familiar, the 675.net =D
Old 10-22-2013, 08:56 AM   #39
ZiaThunder
Go big or go home
ZiaThunder's Avatar
Oddometer: 655
There are places where it can serve you well. There are a few tracks where short shifting in a couple of the sections can keep you from highsiding yourself to the moon.
Old 10-22-2013, 08:57 AM   #40
ZiaThunder
Go big or go home
ZiaThunder's Avatar
Oddometer: 655
Yup... That would be me. I love racing that 675.
Old 10-22-2013, 04:17 PM   #41
Florida Lime
Florida Lime's Avatar
Location: As stated, and as often as possible -R'ville, N.C.
Oddometer: 2,499
Yes, most people downshift through each gear, one at a time, until they reach the gear desired.
BUT, that is NOT the only way it can be done.
Tom Kipp, AMA privateer and factory rider, used to downshift through to the gear he wanted for that corner, THEN engage with the clutch to power through the corner. It worked very well for him, but I never could get the hang of doing it that way.
'10 Husaberg FE570
'10 BMW R1200GSA "30th anniversary edition"
'14 KTM 1290 Super Duke R
'08 Ducati Hypermotard 1100S -- Going, still for sale.
Florida Lime is offline   Reply With Quote
Old 10-22-2013, 04:20 PM   #42
joexr
Oddometer: 3,773
On a track (road course) that you know well , that's fine , but not for an inexperienced and/or on an unfamilar corner. On dirt if you drop several gears and dump the clutch there's little penalty for skipping the tire across the ground.
joexr screwed with this post 10-22-2013 at 04:26 PM
Old 10-22-2013, 04:46 PM   #43
Florida Lime
Oddometer: 2,499
Most of the posts on this page do reference the track, and since when did "engage the clutch" become "dump the clutch" ?
'10 Husaberg FE570
Old 10-22-2013, 04:55 PM   #44
Tripped1
Likely Lost.
Tripped1's Avatar
Oddometer: 8,108
You have more traction under power, the idea being to get weight onto the fat back tire (this is why sportbikes have a heavy front end bias) when coasting at speed you are loading the hell out of the front and risking a washout.
Fun fact, you actually have more traction with a slight bit of slip happening than you do without it.
Granted all of this primarily applies when you are nearing the limit of traction, and with today's tires that is moving pretty good. I've had my 675 on its front wheel with a 25-30 degree lean on it.
Old 10-22-2013, 05:14 PM   #45
joexr
Oddometer: 3,773
Your not good on dirt , huh?
Times are GMT -7.   It's 12:31 AM.
