Go Back   ADVrider > Bikes > Orange Crush > Ridiculous streetbikes with 6 CPUs and too much horsepower (1050/1190/1290cc)
Old 07-27-2014, 12:53 PM   #61
Jim Colombotos
Jim Colombotos's Avatar
Oddometer: 321
Awe crap lol
Guess I better order some spare filters up
Thx Much
2013 KTM 500 EXC
2009 KTM 990 Standard
2014 1190 R
2015 350 EXC
Jim Colombotos is offline   Reply With Quote
Old 07-28-2014, 07:18 PM   #62
kag
Wander Lust
kag's Avatar
Oddometer: 1,634
Just some fyi
I just sourced O rings for the pump where it fits into the tank. I guess they are tough to come by. Just an fyi, drain the tank while it still sitting on the bike, much easier.
The problem as I see it, the filter is just too small for the amount of fuel it has to filter. I have seen several now with about 8k and they look rough. You actually do not need to pull the tank, just run the fuel down and drain the left tank. Even though its one piece its basically 2 tanks as after it gets about 1/2 on the gauge the fuel is segmented. Just turn the right hand tank off. Once you remove the 4 small screws holding the pump in it should drop out with a little wiggling to loosen the O ring holding it in place.
Now that I know what i am doing on changing this (already made the mistakes) I figure this is a 30 minute job once the fuel is drained..
There is a huge amount of info on the 990 fuel system that many guys have really worked the whole issue and the 1190 system is as far as i can tell the same for all practical purposes. Plus its good reading.
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag screwed with this post 07-28-2014 at 08:22 PM
kag is offline   Reply With Quote
Old 07-29-2014, 01:17 AM   #63
guglemonster
Oddometer: 242
weeeeeeeeeeeeeeellll I'm starting to feel like my mum,
I have being studying this issue from the moment I purchased the 990
now I run my own prefilter (twice the size of the new one, 3 time the size of the old version) and external stell in line fuel filter (automotive BOSCH at the moment) plu permanent sock filter under the fuel cap
we have three issues here
the first one is that a marketing product manager and not a proper engineer had a go at the project of the pump
the most important design aspect of this pump is that there are no plug-in cheap aftermarket spare parts or fuel filter
you have to adapt some other parts with more or less complicated overworking or simply copying the old design, which is flawed
they wanted to keep all spare and cosumables inside their part catalog
period
to do so they had to design something that would never have the chance to be retrofitted with a simple in-line system
the bloody aluminium (now cheap PA ) pump holder, the stupid white PA filter holder, the pain in the back flow design..... all just to avoid competition
BMW on the early 11xx system had a simple in-line fuel filter, same as on many cars, in line bosh pump, easy to replace strainer
you could find it all cheap and as good as the original.
once you got trapped in the proprietary design you're done
not even after finding out that common petrol doesn't cooperate very well with today fuel purity needs and that thier strainer was too easily clogged buy petrol suspended particles could they find a way out
they put a less selective stainer thus putting the small paper jummick in jeopardy and make it clogg faster.
ok, no cavitation for fuel starvation, the first plastic membrane would simply block fuel making the pump die, but filter life is as short as before
petrol is dirty, the more you travel the dirtier it becomes and the design simply makes all the dirt accumulate at the bottom of the tank were the pump must sit in order no to starve or run dry, it would burn in a few seconds due to cavitation or dry run, to high speed and to hot, the petrol is cooling the pump down, that's way is very stupid always to run on reserve just to show that we can, you are shortening the life span of you fuel pump this way
and just to complete the issue this bike drinks like crazy...
keep the dirt out of the tank, the rest is simply useless, there are many product to do so, use them, take your time wile refuelling instead of loosing hours in repleacing fuel filters or pump assembly
change the fuel line-flow, get the bloody paper filter out and install an external aoutomotive fuel filter, cheap, better, bigger, easyer to find a repleace
wash the prefilter (new design) with injector cleaner and petrol (light concentrantion mixture with a 20 minutes bath, repeat 3 baths with clean mixture after blowing it from inside)) and blow it from inside untill you will feel is free enough to run another 5000 miles
the pump will run more free, will work less and you bike will obtain a better fuel "pressure wave"at injector resulting in better throttle response at all rpms.
it's easy and it works
60.000 km done this way, many other 990 adv running with the same priciples, not always with the same products, but this is you way out from the fuel/pump issue :)
same thing for all the ktm, bmw, you name it, 690 included
guglemonster screwed with this post 07-29-2014 at 01:24 AM
guglemonster is offline   Reply With Quote
Old 07-29-2014, 02:39 PM   #64
RobZorba
RobZorba
RobZorba's Avatar
Oddometer: 402
Could you let us know about these mods in more detail? The pump is inside the fuel tank, there's both a paper element and a small in line filter canister inside the pump. How do you remove those and re-assemble the pump so it still works? Any chance of pics?
2014 KTM 1190 Adventure R
Suzuki VStrom 650 ABS, Honda ST1300, Suzuki SV650, Yamaha RD250
RobZorba is offline   Reply With Quote
Old 07-29-2014, 04:29 PM   #65
like2lean
Oddometer: 33
Best idea yet, now if we can find a proper prefilter to replace the crap paper guy....
like2lean is offline   Reply With Quote
Old 07-30-2014, 12:49 AM   #66
guglemonster
Oddometer: 242
the paper is inside the pump, out side there is either e plastyic memabrane (right in the picture) smalle and first design or a Poliester nonwoven mesh (left in the picture bigger new ktm design)
this is the paper filter inside the white cap, it's easy to open with just to small flat screwdrivers
all is with o-rings that you can easy purchase in some good shop, Viton is the best
my design is different, much bigger
we are sewing it mounting than on the old PA skerleton that is inside the old filter system
this is after 12.000 km of dirty petrol fom Albania, Bulgaria, Macedonian and Rumenian of road trip, still perfectly working, most of the dirt got of simply rolling in on the kitchen paper
the new ktm prefilter is washable, the old one not
once you have removed the paper filter and remounted the fuel pump with all the new o-rings and new ore rewashed old (but new design ) ktm original you are ready to place the external aoutomotive in-line filter
until now we used three different positions and types
mazda design is best, but only the original one is of good quality and costs too much, roughly 60 euros
mazda G60220490A
this is the perfect position in case your bike is original, battery and ABS in place
mine is a GM positioned to the left side of the airbox
now I suggest a Bosch steel canister F5969 cod 0450905969, not the MAN version, is cheaper and painted
or if you have a good bush plate
more questions??
guglemonster screwed with this post 07-30-2014 at 07:22 AM
Old 07-30-2014, 05:27 AM   #67
kag
Wander Lust
kag's Avatar
Oddometer: 1,634
larger photos would be nice as the current ones a little tough to see
Old 07-30-2014, 05:49 AM   #68
ebrew
Motorcycle A.D.D.
ebrew's Avatar
Oddometer: 1,401
Yes
Please
ebrew is offline   Reply With Quote
Old 07-30-2014, 06:35 AM   #69
guglemonster
Oddometer: 242
Old 07-30-2014, 06:40 AM   #70
guglemonster
Oddometer: 242
sorry guys, bloody imageshack now wants money to use my own pictures and it is really tough to modify each single picture
give me some minutes please
Old 07-30-2014, 07:23 AM   #71
guglemonster
Oddometer: 242
damn was it long
Old 07-30-2014, 08:07 AM   #72
scudrunner82
human whoopy cushion
scudrunner82's Avatar
Oddometer: 2,132
damn was it long
Cool ideas here, thanks guglemonster
For my upcoming trip across the USA, I'm going to install a TwinAir pre filter in the filler neck, and install new OEM filters in the pump assembly. That should do for a while I think.
Hungry Tenere TripTeam Ghetto Does a Hot Lap of America
350, 450, 848, 900, 1190r
My Youtube channel----- https://www.youtube.com/channel/UCXo...kdER0Y5QfoE9gQ
scudrunner82 is online now   Reply With Quote
Old 07-30-2014, 08:22 AM   #73
guglemonster
Oddometer: 242
no it will not
twinair is a 40 micron monolayer mesh, totally useless for a IE injection ktm original filter set-up
you need to go down to 20 or 0, the rest will only reduce the big particles but will not save the prefilter which could clog durign the trip
if you want oem things, it kills my pride thogh, get a splitstream, it's mostly 25/30 micron with the same design, expensive but should work better
but you shoul look for better products :) and for sure NOT monolayer which works BAD
ciaps
Old 07-30-2014, 08:56 AM   #74
JRod152
will work for tires
JRod152's Avatar
Oddometer: 301
Once you have removed the paper filter and remounted the fuel pump with all the new o-rings and new ore rewashed old (but new design ) ktm original you are ready to place the external aoutomotive in-line filter.
For clarification...
Pre-filtering:
Use Slipstream (not uni) tank cap filters for a first line of defense. Then...
Better: use new KTM design that is bigger & washable
Best: use your washable & reusable larger sewn pre-filter w/ increased surface area. Can this be purchased from you?
Main filter:
Then, you actually remove the paper filter from the system completely & for good. You then put the white canister back together with no filter in in & put it into the tank. Then install & use your suggested external filter before the fuel rail?
Is that correct?
Can you get rid of the white canister all together with some piping & fittings? Might even increase fuel capacity a tad.
"Never let the things you want make you forget the things you have"
JRod152 is online now   Reply With Quote
Old 07-30-2014, 09:40 AM   #75
guglemonster
Oddometer: 242
for clarification
use MY fuel cap filter (Guglatech 0 micron, tough, washable, eternal), they can be mounted on the original fuel cap or on safari screw cap, (they told me I cannot advertise so I do not they can be found in the vendor list)
you can either use the new design and wash it or get my system and change/wash it as you like most, yes, I sell them
you cannot remove the white cap, it's supports the presure regulator and the flow back outside the tank, keep it, it'w hollow and you won't gain much
and yes, outside automotive std steel canister, NEVER NEVER NEVER a plastic one like Aprilia... remember heat and strengh..... you need steel, good quality
like this there is nothing your fuel system will ever be afraid of
in case of small water quantities the big automotive filter will block it, should it be filled up, take it out, reverse- flush it with fresh petrol and mout it back
or better stil change it, 12 euros is no big deal
this system is good for some 40.000 km with NO intervention of any kind, than I always recomend to take down the pump and check, or wash the cap filter... if needed
Times are GMT -7.   It's 04:18 PM.
