Old 06-16-2014, 03:07 PM   #211
JustinP OP
JustinP's Avatar
Oddometer: 1,995
Originally Posted by racedawg View Post
Justin,
I just received a set of the of the XM- L lights. Above you describe wiring them with a relay using the high beam switch. Do you have a diagram of that not using the dimmer?
Thank you,
Racedawg
I don't have a specific diagram drawn up for that at the moment, but it's pretty easy to explain. You can refer to the relay portion of the visual here: http://ledrider.com/wp-content/uploa...ingDiagram.jpg
-- Grab an SPST relay from Radio Shack or the auto parts store.
-- Pin 86 on the relay taps into the stock highbeam wire. You can add a switch between the highbeam wire and pin 86 on the relay if you wish to be able to fully disable the aux lights. Putting a small fuse here (1 or 2 amps) is a good idea, as a short in your aux wiring has the potential to take out the main headlight fuse.
-- Pin 85 on the relay connects to ground.
-- Pin 30 on the relay attaches to battery 12v positive (we suggest a 10 amp fuse here).
-- Pin 87 on the relay supplies power to the positive wires on the lights (red or brown depending on model).
-- Negative wire from lights (black or blue depending on model) goes to ground.
If that's not clear, let me know, and I'll fire up the circuit designer :)
FAST: 2004 non-ABS "Silver Bullet" FJR - FASTER: 2008 Touring/Endurance Hayabusa - SLOW: 1997 R1100GS
Quality LED Lighting - ADV Discount inside:) - LEDRider LED motorcycle lights
JustinP is online now   Reply With Quote
Old 06-17-2014, 11:28 AM   #212
racedawg
Have bike will travel
racedawg's Avatar
Oddometer: 268
Justin,
That should do the trick.
Thank you,
04 KTM 400 EXC plate /
09 KTM 950 SE
racedawg is offline   Reply With Quote
Old 06-17-2014, 09:11 PM   #213
JustinP OP
JustinP's Avatar
Oddometer: 1,995
Justin,
Thank you,
No problem - let me know if you need anything else!
Old 06-18-2014, 05:22 AM   #214
cory1848
Oddometer: 314
Just finishing my install last night. Still have to set angles of them but so far so good. Wiring was a bitch to find out where to hide everything. Will work for my upcoming trip but after that may have to rethink the wiring. Not as clean as I would like it. I really like how the dimmer works. Lights look great and very happy. Havent test rode yet to see the output it adds but I am sure it will be plentiful. Pics to follow.
Current ride: 2013 Yamaha Super Tenere
Past rides: 2013 Triumph Tiger 800XC, 1997 Honda Goldwing SE, 2003 Kawasaki Ninja 6RR, 1997 Suzuki TL1000S, 1995 Suzuki Katana 600, 1985 Suzuki GS550EF, 1980 Suzuki GS250T
cory1848 is offline   Reply With Quote
Old 06-18-2014, 08:23 PM   #215
JustinP OP
JustinP's Avatar
Oddometer: 1,995
Just a heads up: Operations will be on hold from tomorrow through Monday. Off for a weekend rally in Nevada. Any orders from now until then won't ship until Tuesday.
We've got some cool new products coming out in the next few weeks when we return. Check out our Facebook page for more info: https://www.facebook.com/ledmotorcyclelights
Old 06-27-2014, 01:30 PM   #216
Wanderer7
long time rider
Wanderer7's Avatar
Oddometer: 104
I can attest that the LR4's have excellent lighting, as well as Justin being an outstanding person to do business with and I recommend him to anyone! I also recommend that the dimmer be implemented with the LR4's to make them useful for different situations.
I took some pictures a little while back with a pair of them installed on my DR along with the comparison to my DDM 55w 5000k HID headlight.
(The following pics aren't the best in terms of actual lighting because in person everything is brighter and this was from a phone camera)
This is the HID alone on low beam:
This is the HID on high beam:
A pair of LR4's by themselves with the HID OFF:
HID on low beam with the LR4's ON:
HID on high beam with the LR4's ON:
Current: 2001 KTM 300 EXC
- '83 250 EXC, '96 CR250, '82 XR500R, '07 XR650R, '93 KLX650R, '87 FZ700, '03 DR650SE
Wanderer7 screwed with this post 06-27-2014 at 01:42 PM
Wanderer7 is offline   Reply With Quote
Old 07-01-2014, 08:01 AM   #217
JustinP OP
JustinP's Avatar
Oddometer: 1,995
FYI folks - we added our new 2000 Lumen, 20 watt lights to the site yesterday. These are part of our rugged Pro Series lights, and have the following features:
Completely Modular Design (connect multiple lights together)
4 Cree XTE LEDs
Custom Engineered Reflector for 10 Degree Spot or 30 degree flood
2000+ Lumens
1.67 Amps @ 12 Volt DC (~20 watts)
9-32 Volts DC Input
IPX68 Waterproof
100% Aluminum Housing
Thermal Protection
Dow specialty silicon filled housing
Shatter proof, Scratch Resistant Ultra Clear PC lenses
UV Resistant Polyester Powercoat
Waterproof Deutsch Connectors
Electronically Protected against RFI/EMC interference
3 inch Length/Width, 2.7 Inch Depth
Offroad Use Only
2 Year Warranty
Spot: http://ledrider.com/shop/?model_number=LRM20-S
Flood: http://ledrider.com/shop/?model_number=LRM20-F
Pricing is $75 each before ADV15 discount :)
JustinP screwed with this post 07-07-2014 at 09:32 PM
Old 07-07-2014, 09:41 PM   #218
JustinP OP
JustinP's Avatar
Oddometer: 1,995
It's been a while since we've run a special on our super popular LR4's, and y'all know I love specials. So here's the "Because it's July" Special LR4 deal :)
LR4's are reduced to $75 each: http://ledrider.com/shop/?model_number=LR4
That's $150 a set BEFORE you apply the ADV15 coupon!
Limited time, stock is limited. We'll run this special until on hand stock runs out, and honor any orders at this pricing that come in before we pull the special from our next shipment. You will not find a better deal on quality LED lighting, backed by LEDRider's NO BS customer service.
Old 07-08-2014, 09:56 AM   #219
Wings
marmaduked
Wings's Avatar
Oddometer: 14,606
Smoking deal! Need to put a set on the Fizzer. And I still need to put lights on the cj Bet you could steer me the right way for that too? Roomies 9fiddy needs a set too
Originally Posted by adv397 View Post
they are upside down under the ice you tard
Wings is offline   Reply With Quote
Old 07-08-2014, 10:33 AM   #220
DiVango
DiVango's Avatar
Oddometer: 67
Perfect Timing! Just ordered a set for my Tiger.
'03 KDX 220
'16 Yamaha Wolverine R-Spec
DiVango is offline   Reply With Quote
Old 07-08-2014, 07:29 PM   #221
JustinP OP
JustinP's Avatar
Oddometer: 1,995
Shoot me a message - I've got lights that would work great on the Jeep, and even have a harness that would fit :)
Old 07-09-2014, 09:12 PM   #222
Wings
marmaduked
Wings's Avatar
Oddometer: 14,606
Awesome! pm on the way
Old 07-10-2014, 02:08 PM   #223
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,043
Ordered up a couple of your lr4's
Great prices, I hope your mounts hold up better then
one of your competitors. They appear beefier.
Any chance you could list the weights of your lights.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 07-10-2014, 07:24 PM   #224
JustinP OP
JustinP's Avatar
Oddometer: 1,995
Max
Hi Max - the weight on the lights is about 13 ounces each. As to the mounts, they have been very sturdy and we've not had any issues reported. Here's some pictures of the LR4's used as sliders in an accident (customer's bike).
https://scontent-a-sjc.xx.fbcdn.net/...31406832_o.jpg
https://scontent-b-sjc.xx.fbcdn.net/...11105487_o.jpg
https://fbcdn-sphotos-d-a.akamaihd.n...89587561_o.jpg
The mounts did not break, they just twisted on the brackets. The lights themselves held up amazingly well, except the wires sliding along the pavement. Rider is OK, which is most important.
I'm pretty sure if the mounts stood up to that, you won't need to worry about that with regular usage :)
Old 07-30-2014, 09:19 AM   #225
yourdrunkdad
I just wanna ride!!
yourdrunkdad's Avatar
Oddometer: 246
pm sent.
For being a people person, I really don't like very many people.
yourdrunkdad is offline   Reply With Quote
Times are GMT -7.   It's 05:11 AM.
