Old 10-14-2013, 04:18 PM   #1
Gustavo.Ramos OP
Gustavo.Ramos's Avatar
Oddometer: 922
Eek Strange looking intake
Got intrigued today when looking down at a mates KTM 990 (2006), the rear cylinder intake looked quite ugly, greasy/sooted.. plugs look fine, no complaints about driveability. He was dazzled, but i believe he never seen the throat of his bike, so anything would dazzle him...
Anyone ever seen this before and figured what could be the cause of it?
690R
Gustavo.Ramos is online now   Reply With Quote
Old 10-14-2013, 05:02 PM   #2
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,880
Valve too tight?
DELTATANGO is offline   Reply With Quote
Old 10-14-2013, 09:24 PM   #3
mjskier
mjskier's Avatar
Oddometer: 486
Is the crankcase breather on the rear of the air filter?
If it is, I can see where most of the crap would get sucked in the rear inlet.
mjskier is offline   Reply With Quote
Old 10-15-2013, 12:43 AM   #4
Gustavo.Ramos OP
Oddometer: 922
Originally Posted by DELTATANGO View Post
Valve too tight?
Doesnt sound like, but worth checking
No, stock setup, breather into the front & clean throat!
Been searching about it and the closest i've found relates to bad injector, although the engine revs fine.
690R
Old 10-15-2013, 12:53 AM   #5
Sumi
Sumi's Avatar
Oddometer: 1,799
Backfiring into the TB can lead to this. Actually this is the only thing I can imagine that gets carbon buildup inside there:) Didn't your mate notice backfiring into the airbox / cutouts / farts? :)
Anyway.. check the seating of that TB (look for a torn boot) and if the vac. ports on the intakes are OK. (no torn vac. hoses for example)
Old 10-15-2013, 01:15 AM   #6
Gustavo.Ramos OP
Oddometer: 922
Did i mention the guy is dazzled with the bike? Brand new to him...
Took it for a spin and it doesn't feel like missfire, maybe with closed throttle engine braking there is some exhaust backfiring but can't really assure if there is into the TB's.
Been once on the 950 with an intake torn boot and felt it, but not this time. Taking the TB's out.
690R
Old 10-15-2013, 02:08 AM   #7
Sumi
Sumi's Avatar
Oddometer: 1,799
Well then maybe it's an old story for the bike which has been sorted out already and noone cleaned the TB since.. Poping on decel at the exhaust is normal ofcourse, and if you can't feel anything wrong while riding it / idling (a carb/tb backfire is quite noticeable), then I doubt you'll find anything out of ordinary if you pull the TBs.. But at least you can give it a good clean. Don't fix it if it ain't broken :PPPPP
Old 10-15-2013, 04:14 AM   #8
StevenD
Hmmmm, dirt!
StevenD's Avatar
Oddometer: 1,143
the cause i dont know precicely but have seen it on more than a few bikes already. I recommend using some fuell additive once in a wile to keep things clean. Dont worry about it for the rest, as long as the valves are in spec.
999 LC8 Rat-Rally custom - 500 EXC - XR666R '85
StevenD is offline   Reply With Quote
Old 10-15-2013, 04:36 AM   #9
Peanuts
Peanuts's Avatar
Oddometer: 1,660
I have seen that before. As the SAS enters at the rear of the airbox I wondered if that could be causing it?
Peanuts is offline   Reply With Quote
Old 10-15-2013, 04:44 AM   #10
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,384
A friend bought a 950 a while back and had the same thing. Bike ran great with no issues but it bugged him. Valve check showed the intakes on that cylinder were tight. Since he corrected the valve clearances the intake is staying clean. Also noticed the bike was a bit smoother.
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 10-15-2013, 05:08 AM   #11
keener
Speed changes you.
keener's Avatar
Oddometer: 944
Check the valve clearances just to be sure.
Also it could be that someone put too much oil into the engine. In that case the crack case breather spits out some of the the excess oil over the front cylinder intake. Front trumper intake sould be very oily.
04 ADV 950
keener is offline   Reply With Quote
Old 10-15-2013, 06:02 AM   #12
Gustavo.Ramos OP
Oddometer: 922
No SAS.
Front intake clean as shown in picture
taking the TB's out for clean, verify intake boots and check valve clearences. I'm pilling beer cases for these services
690R
Old 10-15-2013, 06:24 AM   #13
DELTATANGO
DELTATANGO's Avatar
Oddometer: 13,880
What about the reed valve on the smog thingy?
Old 10-15-2013, 06:51 AM   #14
Gustavo.Ramos OP
Oddometer: 922
Not sure if you're talking about the vapor canister, it's a EU model so no such device.
690R
Old 10-15-2013, 07:09 AM   #15
ADVill
Oddometer: 609
I'm kinda liking the too much oil thing right now. Easy to do if you fill it up cold.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Times are GMT -7.   It's 02:46 AM.
