Old 10-15-2013, 09:15 AM   #16
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,541
This will probably only add to the mystery, but I bought a low mileage 990 that had weird deposits in the intake tracts.
I never did see the throttle bodies of the bike it came out of, but the intakes looked like this:
I brushed it out as well as I could, then ran it several thousand miles with carburetors. When I pulled it apart for my first valve adjustment, the intakes were clean as could be.
I have seen similar pics posted, and often the condition is blamed on ethanol fuel. But, almost all of the fuel I use is E10. so I doubt that theory.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 10-15-2013, 09:49 AM   #17
Gustavo.Ramos OP
Gustavo.Ramos's Avatar
Oddometer: 962
that would be my guess (fuel+ethanol) based also on previous issues seen around OC, but i'm not affected to that kind of fuel cocktail so can't add much.
This one clearly (or darkerly) seem to be oil/soot deposits from missed combustion...
Wether is a ongoing problem, or remnants of something fixed before, it's unknown..
690R
Old 10-15-2013, 10:30 AM   #18
MortimerSickle
Semi-Adventurer
Oddometer: 12,541
I guess I didn't make clear that the deposits in my intakes went away while using ethanol fuel.
G.H.W.S. 1878-1962
Old 10-15-2013, 10:33 AM   #19
pdxmotorhead
pdxmotorhead's Avatar
Oddometer: 823
I've seen that same stuff many times on alcohol powered dirt cars injection and intake and anything aluminum that gets near methanol, and it is then left to sit.
A good alky fuel stabilizer will help. Most Sprint car owners "pickle" their Hillborn style injection with Wd40/Marvel Mystery Oil/inser fav oil here... after races, the Methanol attracts water and will badly pit aluminum in a very very short period of time, like a week!
Remember E10 is a min value, I've measured E10 at 18% several times..
Easy way to a dq at the track is un checked pump gas.. IN fuel limited race classes..
Cheers
Dave
Freedom is a delicate thing.
More easily lost than gained.
pdxmotorhead is offline   Reply With Quote
Old 10-17-2013, 04:19 AM   #20
Gustavo.Ramos OP
Oddometer: 962
New developments, after a longer and carefull ride finally noticed something not right.
Engine idles fine, but with very small throttle openings when starting to move it will occasionally backfire into the intake. Once it stalled the engine though.
Interesting how different riding styles can mask symptoms.
Either air leak through intake boot of something wrong with the injector..
690R
Old 10-17-2013, 04:57 AM   #21
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,535
Tight intake valves
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 10-17-2013, 08:23 AM   #22
Gustavo.Ramos OP
Oddometer: 962
Originally Posted by Boatman View Post
Tight intake valves
will check it too.
start to think that work more on friends bikes than my own......
690R
Old 02-19-2014, 02:12 PM   #23
Gustavo.Ramos OP
Oddometer: 962
digging a bit of a thread.
No tight valves, checked them and only one in front cylinder was a bit tight but still within range.
While riding occasionally it feels a bit of a fart into the airbox, especially at low revs. Spark plugs are ok with good color. Thinking about injector operation... related to random incorrect spray time, a fraction of a second off the valve opening time, perhaps...
690R
Old 02-19-2014, 11:08 PM   #24
srad600
srad600's Avatar
Oddometer: 688
Interesting, I have a 2011 990 with the exact same symptoms. Bike runs perfectly under power, on decel, overrun, etc. But every once in a while, if stopped at a light with the clutch pulled in, when rolling on the gas the bike will pop/fart and then stall. It'll start right back up and run like mad, but the occasional stalling thing has me stumped.
I've :
Sync'd the Throttle bodies
Set the TPS
Checked the Map (Powertripp)
I will be:
Checking the valves this next service (but they were fine at the last check)
Replacing the plugs
I'm running a foam filter now, but the issue occurred prior to the new filter. I've just started rolling on the gas harder/earlier from a stop. It's a band-aid, but I haven't a clue what else to check.
srad600 is offline   Reply With Quote
Old 02-20-2014, 03:40 AM   #25
Bowber
Oddometer: 184
Never seen that before and I raced speedway and grasstrack bikes for 30 years running pure methanol. On carbs though.
The carbs would get gunked up if left (but took a while, like a month or more) and some parts would corrode badly but nothing in the inlet.
Steve
Bowber is offline   Reply With Quote
Old 04-03-2015, 06:26 PM   #26
cejnys
Oddometer: 186
hey Gustavo,
Just wondering whether you found out what was the problem. I have 2012 990 Avd and it runs well under power but when I start it after like 5-10 seconds engine stops when rear cylinder back fires into the intake. Also when I am starting to rev the engine up it does not feel right until it reaches about 4000 revs, then is feels good.
I looked into the airbox and this is what I found. Rear intake is pretty smoked and front is little bit oiled. Last valve check was all good.
I am riding around south america right now; last 3 weeks with adding more kilometers it got worse. At this moment it is pretty challenging to go slowly with the bike. I have to keep revs up and ride it through clutch.
Any advise will help! Cheers, Rad
affirm it, visualize it, believe it, aim for it, and RIDE
www.aroundsouthamerica.info
cejnys is offline   Reply With Quote
Old 04-04-2015, 04:11 AM   #27
Gustavo.Ramos OP
Oddometer: 962
Hello CEJNYS,
swapped rear injector from another TB set that i had in my spare parts, cleaned the intake area and for about a month nothing was found. Original injectors were sent for cleaning and the issue was solved.
But from your description yours seem to be alot worse and before going the injector way i'd check that rear spark plug. some plugs when get randomly faulty their effects are felt at lower revs because at higher revs the firing cadence is much faster and it masks the symptoms.
And if you have such condition, the missfire will cause the very same buildup goo that you see.
690R
Old 04-04-2015, 04:14 AM   #28
Gustavo.Ramos OP
Oddometer: 962
This picture resembles now a lot of the early cases of dust ingress in the 1190 Adv airbox
690R
Old 04-04-2015, 08:05 AM   #29
MortimerSickle
Semi-Adventurer
Oddometer: 12,541
Same engine after 36000 miles on ethanol gas.
G.H.W.S. 1878-1962
Old 04-04-2015, 08:43 PM   #30
Gustavo.Ramos OP
Oddometer: 962
does it feel and runs healthy? if so, thats what matters
690R
Times are GMT -7.   It's 02:18 AM.
