Old 10-16-2013, 04:09 PM   #1
DFWBo OP
DFWBo's Avatar
Oddometer: 275
Electrical Wiring Help Needed
Hi everyone and TIA. Hope this is in the right place I'm looking for some advice on how to use a switch I just purchased, I have no electrical know how
I'm trying to install some additional fog lights. I plan to utilize the PDM60 feature of a Ground activated circuit. From the PDM instructions, "GROUND TRIGGER - BLUE WIRE
The Ground Trigger (GT) wire responds to any ground signal. Upon detection of an electrical ground signal on the GT, any/all circuits assigned a GT activation mode will go live. This feature is great for switching high amperage loads on/off, without the use of relays. The GT can control multiple circuits simultaneously. Simply connect the blue GT wire to any switch that leads to ground, and you can easily switch all GT activated circuits on/off."
And I'd like to use this switch to activate the circuit:
Here are the instructions for the switch
Can I just use the blue wire from the white and black connectors? White side to ground and black side to the PDM60?
I appreciate any advice!
DFWBo is offline   Reply With Quote
Old 10-16-2013, 04:10 PM   #2
DFWBo OP
DFWBo's Avatar
Oddometer: 275
Fixed pic above
DFWBo screwed with this post 10-16-2013 at 06:55 PM
Old 10-17-2013, 04:38 AM   #3
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 956
Talking
*IF* you are not using the new switch for anything other than activating the ground trigger on the PDM60, I'd snip off the white connector.
Using Posi-lock connectors, connect the yellow switch wire to ground, and the blue switch wire to the PDM60's blue wire. Insulate the black wire with a piece of tape or shrink tubing. The black headlight connector and wires are unused.
Normally, the yellow wire has the bike's +12 volt power to the switch and the blue wire (which actually goes to two places) would supply power to the headlight and taillight when the switch is flipped on. In this case, you're switching ground to the PDM60 via the yellow and blue wires, rather than +12 volts.
You'll need to program the PDM60 circuits that you want to use for 'ground trigger'. I'd do this before you connect the main battery power to the PDM60.
Hope that makes sense.
=Adam=
Like us on Facebook -- Follow us on Twitter
PM us for your *personal* ADVRider discount code to use at RocketMoto.com
Autocom | TPX Radar/Laser | Sena Bluetooth
| Hi-Power LED Lights
Shorai Battery | Techmount | Powerlet | Rowe PDM60 | Skene Design
RocketMoto is offline   Reply With Quote
Old 10-17-2013, 07:05 AM   #4
DFWBo OP
DFWBo's Avatar
Oddometer: 275
Makes sense, thanks. It is one of the early PDM60s...came with a circuit configured for ground switch. Plan to use that one.
Thanks RocketMoto...I purchased it from you!
DFWBo
DFWBo screwed with this post 10-17-2013 at 07:15 AM
Old 10-19-2013, 06:34 AM   #5
RocketMoto
2 Many Motersikles
RocketMoto's Avatar
Oddometer: 956
DFWBo
=Adam=
| Hi-Power LED Lights
Times are GMT -7.   It's 11:49 PM.
