Old 10-17-2013, 06:52 PM   #1
JonnyCash OP
turd polisher
Oddometer: 1,652
The homemade specialty tool thread!
I offer you my newly made trans output flange puller. Made of some 1/4" plate, 2" pipe, BMW rear axle, and threaded parts from a chinese gear puller which long ago suffered a broken leg. It worked great. That thing was super tight!
[IMG]IMG_2386[/IMG]
[IMG]IMG_2388[/IMG]
[IMG]IMG_2390[/IMG]
If anyone needs it, you're welcome to borrow it.
I really get a kick out of making up tools out of junk laying around, and would love to see ones that others have made. Post'em up!
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash screwed with this post 10-17-2013 at 07:50 PM
JonnyCash is offline   Reply With Quote
Old 10-17-2013, 07:02 PM   #2
Plaka
Brevis illi vita est
Oddometer: 4,615
Originally Posted by JonnyCash View Post
I offer you my newly made trans output flange puller. Made of some 1/4" plate, 2" pipe, BMW rear axle, and threaded parts from a chinese gear puller which long ago suffered a broke leg. It worked great. That thing was super tight!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Oh yeah? My cheapo universal puller set with 10 different threaded studs cost less than your welder.
Actually there are a lot of these in the Tips&Tricks thread.
Old 10-17-2013, 07:47 PM   #3
blaine.hale
blaine.hale's Avatar
Oddometer: 3,267
I think he gets the cool points on this one, though.
Pretty darn neat.
1974 BMW R90 /6 | 1968 Bultaco Matador MK3 | 1973 BMW R75 /5 Toaster LWB | 1966 Ducati 250 Monza | 1976 Ducati 860 GT | 1977 Moto Guzzi LeMans 850
blaine.hale is online now   Reply With Quote
Old 10-17-2013, 09:11 PM   #4
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
Some more transmission tools...
Here is what I've come up with to help with rebuilding transmissions.
Out put shaft flange puller and holder sitting on top of my disassembly/reassembly box:
Detail of puller:
Puller was made from steel plate and a castellated nut, as you can see in this pic:
Underside of the box where the shafts drop after heating the trans and tapping it down on the box frame. You can see the hole for the input shaft when I turn it over for shimming:
Kai Ju is offline   Reply With Quote
Old 10-17-2013, 09:53 PM   #5
Tin Woodman
Mike
Tin Woodman's Avatar
Oddometer: 203
Saved five bucks and made this fabulous rear main seal remover. I have no idea what else it's good for.
One measly toaster
Tin Woodman is offline   Reply With Quote
Old 10-18-2013, 09:37 AM   #6
Plaka
Oddometer: 4,615
Pretty darn neat.
True that. Most of my special tools crumble back into piles of nuts and bolts and broken bed frames as soon as I'm done with them.
Old 10-18-2013, 09:40 AM   #7
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,606
Now that's a very literal interpretation of a slide hammer. I might go make one of those.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-19-2013, 12:17 PM   #8
Kai Ju
Kai Ju's Avatar
Oddometer: 1,910
Pinching your fingers ?
I have to agree with Airhead Wrangler, it is the most literal interpretation of a slide hammer I have yet seen, kudos.
Old 10-19-2013, 02:49 PM   #9
danedg
Horizontally Opposed
Oddometer: 6,773
Case Separator Wedgie
danedg is offline   Reply With Quote
Old 10-19-2013, 05:45 PM   #10
melville
melville's Avatar
Oddometer: 1,509
Clutch centering tool:
Call me Mel. Some years ago- never mind how long precisely- having little or no money in my purse, and nothing particular to interest me at home, I thought I would ride about a little and see the other parts of the world. It is a way I have of driving off the spleen and regulating the circulation.
melville is online now   Reply With Quote
Old 10-19-2013, 06:16 PM   #11
JonnyCash OP
turd polisher
Oddometer: 1,652
Melville- I like that centering tool. I once made one up on a wood lathe out of a piece of locust, which is about as hard as woodpecker lips. Too bad I can't find it anymore, a I'll need one again soon. Kai Ju, that output flange puller looks super tidy. What did you cut the flange out with? It looks factory made. Keep 'em coming, I'm really enjoying seeing what solutions you all have come up with.
Old 10-19-2013, 09:25 PM   #12
Plaka
Oddometer: 4,615
A) /6 bearing cover pin wrench. More duties in store shortly.
B) Front bearing carrier pullers
C) Fork spring compressor
D)Telescoping high power magnet for toolkit
E) Carb setting driver
F) shop fork boot puller
G) Carb and fairing bolts set.
H)plug boot puller-toolkit
I) carb idle setting gauge
J) clutch release bolt set
K) Push rod tube press
One more is out on loan, another in progress.
Old 10-20-2013, 05:36 AM   #13
danedg
Oddometer: 6,773
Flywheel Runout Gauge
Old 10-20-2013, 05:52 PM   #14
Pokie
Just plain Pokie.
Pokie's Avatar
Oddometer: 1,069
Driveshaft coupling bell holder (to remove or torque the nut without straining the universal joint).
Holder with socket.
With socket in place.
So, you thought there was never going to be any use for those trigonometry classes. Think again!
Pokie screwed with this post 10-20-2013 at 05:57 PM
Pokie is offline   Reply With Quote
Old 10-20-2013, 06:19 PM   #15
photorider
photorider's Avatar
Oddometer: 302
Love this stuff!
photorider is offline   Reply With Quote
Times are GMT -7.   It's 04:03 PM.
