Old 10-18-2013, 09:11 AM   #1
jeepman256 OP
NACHO
Oddometer: 14
Vacuum Fuel pump on a 950 , yes or no
I have one now , it's filling the front cylinder with fuel , do I go bk to an electric or what?
2005.5' KTM 950 ADVENTURE ORANGE
2004' KTM 950 ADVENTURE SILVER
2009' KLR 650
2002' HARLEY LOWRIDER
2000' YAMAHA YZ 250
jeepman256 is offline   Reply With Quote
Old 10-18-2013, 10:46 AM   #2
mousitsas
mousitsas's Avatar
Oddometer: 2,752
...or install either an electric or a manual fuel shut off valve.
If you're happy with the vacuum pump otherwise, there is no reason to change the simplest approach available.
Old 10-18-2013, 11:13 AM   #3
gearheadE30
gearheadE30's Avatar
Oddometer: 874
If it only does that when sitting, then a shutoff valve should take care of you. If it's flooding while running, you probably have an issue in the carbs that needs to be addressed.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 10-18-2013, 12:14 PM   #4
Qwik
Adrenaline Addict
Oddometer: 6,706
Put the bike in top gear and roll it back and pop the clutch to get the fuel out of the cylinder. I had one on my 950 (Mikuni DFS21 IIRC) and went to a beans kitted stock pump. You need to either shut the petcock off at the end of your rides or get a vacuum shutoff.
Topes never seem to make me go any faster.
Qwik is online now   Reply With Quote
Old 10-18-2013, 09:57 PM   #5
renogeorge
Oddometer: 1,367
I always admired the simplicity of the vacuum pump. But I never got around to trying it on my 950. The Facet electric just worked too well....
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 10-18-2013, 10:55 PM   #6
Head2Wind
MotorcycleMayhem
Head2Wind's Avatar
Oddometer: 2,572
If you remember to turn off the petcock almost every time you turn the engine off. Also the location of the pump will influence if it vapor locks or if the tanks run dry they tend to have a hard time repriming. One of the other challenges with these pumps is the pressure is all over the place. The problem with this is related to the float needles not being able to hold off much pressure greater than 3-4 PSI. Stock FP is 1.5-2 from the Mitzu pump.
The modern electronic pumps that have stop check valves in them are reliable and will keep the fuel from passing by the pump when its not energized. They also maintain fuel pressure at 1.5-2.5.
Two options:
DR_Bean OEM pump upgrade. ~$60 +/- Works very well, takes some skill to install. Fits in the OEM location and doesn't require any other modification.
Facet 40171: ~$60 +/-, works very well, requires modification of mounting and plumbing, tight fit to the skid plate
“The mind is sharper and keener in seclusion and uninterrupted solitude. --- Be alone, that is the secret of invention; be alone, that is when ideas are born.” - Nikola Tesla
2006 KTM 970 frankinADVsmSD
ADVmachines™ Proven Solutions for your Worldwide Adventures...www.ADVmachines.com
Head2Wind is offline   Reply With Quote
Old 10-19-2013, 06:01 AM   #7
jeepman256 OP
NACHO
Oddometer: 14
Thanks for all of the advice , sounds like a new electric pump is in store for my bike, that remembering to turn the fuel off gets to be a pain in the ass !! Especially after u've had a few COLD BEERS!!
2009' KLR 650
2000' YAMAHA YZ 250
Times are GMT -7.   It's 08:23 PM.
