Old 10-21-2013, 10:22 PM   #1
juansg OP
Oddometer: 2
Engine problems after oil change
I just finished changing oil and oil filter on my DRZ400SM. I've already done this a few times without any issues. However, after riding for 10 minutes after the oil change, I noticed how the engine would skip a beat from time to time at highway speeds. It's also easy to tell that there is something wrong because when trying to accelerate aggressively from low speeds, it feels jerky and is also easy to hear that the engine isn't accelerating smoothly.
When I got home (20 minutes ride), I noticed that the engine was very hot, much more than usual.
I'm not sure what's going on. I used the same oil filter and oil as usual (recommended Suzuki brand 4 stroke 10w-40 oil. The only thing I can think of is that, this time, I forgot to unscrew the oil dipstick before draining the old oil. Is it possible that because of that lack of vent (dipstick hole) I didn't drain all the oil before I added 2 quarts? would some extra oil have such a big impact?
thanks
juansg is offline   Reply With Quote
Old 10-21-2013, 10:28 PM   #2
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,977
Way too much oil can be bad. A little extra shouldn't hurt. How much does it show on the dipstick? If it's overfilled, you could drain a little, run it, and check it again. I don't know much about this particular bike. Is there any chance that the filter is installed incorrectly?
Support the AMA.
Waco is offline   Reply With Quote
Old 10-21-2013, 11:05 PM   #3
festa
out n about
festa's Avatar
Oddometer: 106
Bad plug or faulty lead
festa is offline   Reply With Quote
Old 10-22-2013, 08:01 AM   #4
troidus
Oddometer: 15,410
Or a bad oil filter. Or if it has variable valve timing, a piece of crud is lodged in the cam mechanism.
troidus is offline   Reply With Quote
Old 10-22-2013, 09:48 AM   #5
Switchblade315
Switchblade315's Avatar
Oddometer: 5,722
oil filter in backwards. seen people do it before. just not watching what they where doing picked it up and put it in the wrong way. cant flow oil to the top end.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 10-22-2013, 12:35 PM   #6
ohgood
ohgood's Avatar
Oddometer: 2,930
I wouldn't think the filter cover would fit on of or was backwards. does it really?
wow
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is online now   Reply With Quote
Old 10-22-2013, 01:40 PM   #7
baloneyskin daddy
bikaholic
Oddometer: 2,160
wow
I've seen it done on 4-wheelers a few times so it can be done and after 10 minutes it ain't gonna be pretty.
baloneyskin daddy is offline   Reply With Quote
Old 10-22-2013, 03:01 PM   #8
1P8RIOT
1P8RIOT's Avatar
Oddometer: 393
Oil filter backwards
I've seen it a few times myself on street bikes too.
A ship in a port is safe but that is not what ships are built for. - Mom
'09 F800GS YEAH BABY!!!
1P8RIOT is offline   Reply With Quote
Old 10-22-2013, 06:24 PM   #9
kartl
Oddometer: 10
I think its a dirty air filter or bad plugs. When was the last time you cleaned or replace them.
kartl is offline   Reply With Quote
Old 10-22-2013, 09:54 PM   #10
troidus
Oddometer: 15,410
That's not going to bake the top of the engine. Dry cam bearings sure would, though.
Old 10-23-2013, 04:46 AM   #11
trailer Rails
trailer Rails's Avatar
Oddometer: 4,275
thanks
It has been a while since I had a DRZ400 but I believe 2 quarts is too much. Also I seem to remember there was a pretty specific way to drain the oil from that bike, I can't remember right now. But not removing the dipstick may have held a lot of oil back.
trailer Rails is online now   Reply With Quote
Old 10-23-2013, 05:45 AM   #12
Switchblade315
Oddometer: 5,722
wow
some bikes you can because of the indention in the filter for the spring that helps hold them in place.
Old 10-23-2013, 06:19 AM   #13
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,712
The mention of those words makes me shiver
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 10-23-2013, 09:53 AM   #14
Fixnfly
Fixnfly's Avatar
Oddometer: 393
It's impossible to put the oil filter in backwards on this bike. The housing cover will not go back on. There are two drain plugs.
Was the frame AND crankcase drain plug removed?
01 DRZ400S 93 GSXR750 13 Z1000
Fixnfly is offline   Reply With Quote
Old 10-23-2013, 02:28 PM   #15
ohgood
ohgood's Avatar
Oddometer: 2,930
That's what i was thinking...
Times are GMT -7.   It's 09:54 AM.
