Old 10-23-2013, 06:57 PM   #1
Decepticon OP
Decepticon's Avatar
Oddometer: 113
Eek Standard MAP without O2 sensors and SAS
Hi
I wonder if I can load in my 990 ADV the standard map without these items to return to a lower consumption performance, using tuneECU.
The goal is to increase mileage, Any suggestions?
2007 KTM 990 Adventure ABS
A lot of bad things have been said about me, all of them are true
Decepticon is offline   Reply With Quote
Old 10-23-2013, 07:07 PM   #2
smitty141
smitty141's Avatar
Oddometer: 600
I just started using Tune ECU. There is a box located on the left side to turn off O2, SAI=(SAS) and more. So, I say yes.. Not sure how it would perform..
Smitty
2011 Prudoe bay, Dalton Hwy.
2014 Inuvik, NWT. Demster Hwy. D2D, Yukon
2013 Yamaha FJR1300...2010 BMW F800GS..
1999 Yamaha YZ250.. 2008 Suzuki DRZ400SM
smitty141 is offline   Reply With Quote
Old 10-23-2013, 07:10 PM   #3
Two Moto Kiwis
Homeless Somewhere
Two Moto Kiwis's Avatar
Oddometer: 3,730
Originally Posted by Decepticon View Post
Hi
Heya dude, great meeting you in Medellin the other day and a nice scoot you have too
Totally doable with tune ECU, you can put your factory map back in providing you saved it, if you didn't I am sure someone on here will have it.
A few seem to have found the map runs rich through the cruising band so you might be able to look at leaning it through there, there are plenty who have played and come up with good map on here.
Andi (oveja negra) & Ellen (chica amarilla)...Two Moto Kiwi Grüvers .....riding Maya somewhere ..Una Chimba
Two Moto Kiwis Home Page ..Danger Is Real ... Fear Is Optional
For More Of Two Moto Kiwis Photos
....Where The Hell Are We .. Spot Us
Two Moto Kiwis is offline   Reply With Quote
Old 10-23-2013, 07:35 PM   #4
Decepticon OP
Decepticon's Avatar
Oddometer: 113
Thanks. I´ll try
Joe Andi!
Nice meeting you and Helen too.
In tuneECU website is the standard map. David in R2R loaded an aftermarket slip ons MAP, so she is drinking gas happily.
Hope you return to Medellin and meet again.
If you want to do another trip through Colombia, from Bogotá maybe to Ibagué, or somewhere else, maybe a little trip in ferry, I can recommend you a route to investigate if you want...
Old 10-23-2013, 07:47 PM   #5
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,113
Hi
You want O2 sensors ON for fuel mileage. Turning them on , in the ack map will increase mileage (they are off by default). Turning them off in the stock map will reduce mileage (they are on by default).
Many find the happy medium to be the ack map with O2 turned on, there is a huge thread about it in this forum, take the time to read it.
SAS has nothing to do with fuel mileage.
Sheep Shagger is online now   Reply With Quote
Old 10-23-2013, 07:59 PM   #6
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,730
The ackra map is the worst for biffing in fuel when it is not needed so if that what David put in then yeap it will drink.
As SS said have a good read of the thread, the o2's off will help with snatchy throttle coupled with other addition like throttle cam but turning them off will only use minimally more fuel, the main area that the ackra map seem overly rich is in the mid range at crusing so you are unnecessarily using gas.
We are heading south now mate, in El Espinal tonight hitting the desert tomorrow and into Neiva then down to San Augustin to play tourist for a coupla days
Old 10-23-2013, 07:59 PM   #7
Decepticon OP
Decepticon's Avatar
Oddometer: 113
Roger that.
SAS is one of the things people here complain a lot of. So I was thinking that without SAS the bike would ride better
Thanks, anything else I should do to increase mileage without damaging the engine?
Old 10-23-2013, 08:37 PM   #8
Decepticon OP
Decepticon's Avatar
Oddometer: 113
What about the Secondary butterflies?
If I disable them, would I get better mileage?
Old 10-23-2013, 08:40 PM   #9
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,730
The SAS inducts air into your headers to superheat your catalytic converters but what this does to aftermarket pipes is burn the packing out so bad news really, it does not make a difference to how your bike runs other than it taxes your airbox which does not need taxing.
Best thing to make it run better is o2's off, G400 throttle cam, open filter and pipes and a tuneecu map to suit, no quick fixes anywhere.
If you have the factory airbox you can open up the two side triangles to allow more air and add a DNA or similar filter if you haven't already got one.
These are our triangles with a kitchen scrubby as a prefilter, cheap and easy to replace
What setup do you currently have
Quick question, we are looking to go over to Ibague from El Espinal, worth going?, heading down to Neiva after that so local suggestions welcomed
Cheers dude
Old 10-23-2013, 08:43 PM   #10
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,730
No, they only have a smoothing effect on the throttle, on my 990 SMR I ended up putting them back in as the low action throttle was better with them in.
Ditch them if you want top end accel, some people have had trouble with the stepper motors but if they are working fine leave the second flies in place.
Old 10-23-2013, 09:09 PM   #11
Decepticon OP
Decepticon's Avatar
Oddometer: 113
Puke I was there...
Cheers dude
I was there when you made it and installed, pretty cool cheapy filter!!!
Summing up, just turn on the O2 sensor and do 15 min idle
Old 10-23-2013, 09:26 PM   #12
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,730
Gezz ya were too .... make sure you don't get as old as me
Yeah cheapy Kiwis know how ta roll the $$$ out, specially on a RTW trip.
O2's won't make a huge difference to overall economy though but yeap everything adds up if you want optimal mileage, never a free lunch with everything, unfortunately if you want HP you pay for that, if you want economy you will give back some HP.
You won't need to do the 15 min idle with the o2's but do it anyway so you have a fresh start and you know where you are at.
Pick a cold day, early morning is best.
BTW, what problem do you have that you wonna cure? (apart from personal ones )
Old 10-23-2013, 09:33 PM   #13
Decepticon OP
Decepticon's Avatar
Oddometer: 113
Pissed mileage
Before David changed the map, she was doing 60 km per gallon. I want that mileage back because I don't feel the horsepower increasing with the money xpense increase
Old 10-24-2013, 07:54 AM   #14
Two Moto Kiwis
Homeless Somewhere
Oddometer: 3,730
Ok, see where you are going with that, yeap factory map or modded tune ecu map and give her a little more air.
Old 10-24-2013, 08:00 AM   #15
Decepticon OP
Decepticon's Avatar
Oddometer: 113
metal grid
Youp Andi!
Who has the metal grid you used to make your ultra high tech side air intakes?
I want to do it myself.
Good ride, fellas!
Times are GMT -7.   It's 10:33 PM.
