Old 10-24-2013, 05:23 PM   #1
meijer's trails OP
meijer's trails's Avatar
Oddometer: 495
my 74 husqy needs crank seals, do i need to split cases?
Is anyone familiar?
Do I need to split the cases to change crank seals in a 1974. Husqy wr250?
meijer's trails is offline   Reply With Quote
Old 10-24-2013, 07:41 PM   #2
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,280
you're splitting.. left side seal is inboard of bearing. them cases suck. i don't know why the husky cases are so goddamn tight.
current bikes
stainlesscycle is offline   Reply With Quote
Old 10-24-2013, 07:59 PM   #3
meijer's trails OP
Oddometer: 495
wouldnt you know it.
the easy to reach right side looks clean as a whistle.
and im already stuck on a kickstart case screw. the one right behind the cylinder.
im thinking of cutting it at the head so i can still grab it later and heat the case some to try to loosen it
ideas?
Old 10-24-2013, 08:00 PM   #4
meijer's trails OP
Oddometer: 495
i think ill try my 2stroke leakdown checker(fashioned from a blood pressure cuff) first
Old 10-25-2013, 11:04 AM   #5
Scootern29
Scootern29's Avatar
Oddometer: 521
ideas?
Try a small sharp chisel and try and move the screw in the loosening direction. I just had to do this the other day. Two or three good whacks with a small hammer will usually do it.
Scootern29 is offline   Reply With Quote
Old 10-25-2013, 01:04 PM   #6
meijer's trails OP
Oddometer: 495
thanks scootern,
i seeped in some pb blaster lastnight.
used a little heat, pressure back and forth.
today i hit it with an impact driver, and it did the trick!
dodged my first bullet
Old 10-28-2013, 03:23 PM   #7
stainlesscycle
Oddometer: 2,280
if the biggest problem you have splitting those is a stuck bolt, consider yourself lucky. you'll see
current bikes
Old 10-28-2013, 03:29 PM   #8
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,867
Ive split more then 8 sets of old Husky cases,the thing is opening them up and not having them be corroded around the crank area,borrowing a proper case splitter can make your life a bunch easier. Porosity in the crank area does the same thing or worse then leaking crank seals.
Ive bapped them apart with woodblocks and a 5 lb sledge but its not the preferred way to do it. Really eyeball all the center case screws with good light to be sure they are all out and accounted for.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 10-28-2013, 03:31 PM   #9
Foot dragger
singletracker
Oddometer: 12,867
If theres room just wapping the screw or bolt side with a small punch to side stretches it a little and does wonders for loosening them. Just dont want to break what ever casing the bolt is in.
Times are GMT -7.   It's 12:15 AM.
