Old 10-29-2013, 12:15 PM   #16
schattat
schattat's Avatar
Oddometer: 1,442
A single sensor for multiple units could work, but not by directly connecting the individual units parallel to each other. The way the system work is you have 2 wires in those sensors, one is a high signal, e.g. 5V, the other is GND. The switch in the sensor does nothing but short circuit these two lines upon proximity of a magnet. The effect we saw on the Sigmas can occur when hooking up multiple units together that a high signal from unit A comes in contact with the GND signal of unit B. One would have to therefore measure which line is high and which is GND, couple them together with diodes (yes, those things yet again!) and then you could run a single sensor.
But as already mentioned by Dave, you have no backup!!!
RNS - Rallye Navigation Solutions
Yamaha WR450F Rallye Spec
schattat is offline   Reply With Quote
Old 10-30-2013, 01:58 AM   #17
Happe
Offroad Nut
Happe's Avatar
Oddometer: 681
They are everywhere ....
Happe is offline   Reply With Quote
Old 11-01-2013, 03:02 PM   #18
hardenduro
hardenduro's Avatar
Oddometer: 48
Question odo cable routing
I was wondering how the cables for the various types of rally odometers
are routed. I plan to run two,one tripmaster and one ICO and am most interested in how the cables are run to avoid damage at the bottom near
the sensor. Thanks.
hardenduro is offline   Reply With Quote
Old 11-01-2013, 03:44 PM   #19
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,358
the sensor. Thanks.
Dave has a good writeup on that particularly:
http://www.rallymanagementservices.c...upport-manuals
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 11-02-2013, 06:58 AM   #20
hardenduro
hardenduro's Avatar
Oddometer: 48
Thanks.
Old 11-02-2013, 07:38 PM   #21
SafariBerg
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,049
for ERTF GPS based events
run 2 x Speedocap V3 units atop of the MD/Roadbook, LHS one set to odo trip mode connected to remote thumb switch, RHS one set on CAP / SOG mode
all the function of the traditional ICO/RNS odos plus the benefit of auto correct of the odo trip every time you pass a waypoint
PLUS SOG is based on GPS speed not ICO speed hence reduces risk of over speeds in DZ's
PLUS trip is GPS based so no concerns if you have the correct wheel circumference set or not
PLUS no low mounted vulnerable sensor or sensor lead issues
can also have an ICO at the bottom of the MD like many already do for additional redundancy & having a sensor based odo in addition to the GPS based Speedocaps
many autos run 2 x GPS's to achieve the same approach, interestingly the only moto I have seen so far to adopt this is Alain Duclos the current factory Sherco rider.
its what we use in our T3 Polaris
with a Speedocap V3 in front of the driver
2013 Husaberg FE501
2014 Arctic Cat Wildcat Z1 1100T Rallye
SafariBerg screwed with this post 11-02-2013 at 07:54 PM
SafariBerg is offline   Reply With Quote
Old 11-03-2013, 02:55 AM   #22
JayBo1
JayBo1's Avatar
Oddometer: 2,803
How does this setup compare in cost to traditional ICO's?
Is the weight and size same?
Power consumption comparison?
How does the "auto correct at Waypoints" work if you only need to be within various distances of a Waypoint to get a trigger to the next one? It potentially puts the ODO trip out by a fair bit depending whereabouts in the circle of a Waypoint you arrive and different for the different types of Waypoints.
JayBo on Safari/Dakar
#101 Dakar 2015, Kiwi Safari Team, Perth, WA
KTM 450 Rally ... Dakar ready
KTM 530 EXC-R
Cagiva 750 Elefant - Lucky Explorer '88
JayBo1 is offline   Reply With Quote
Old 11-03-2013, 03:39 AM   #23
SafariBerg
Oz Safari Addict
SafariBerg's Avatar
Oddometer: 3,049
nearly everyone now uses a CAP repeater, or the majority of riders now the more recent Speedocap models, this approach simply adds another
every time you validate a GPS waypoint the GPS sets the odo to the correct km cumulative distance for that waypoint, given the validation radius is usually 100m or 90m depending on the event, the + - error margin is 0.1km basically the same as what the motos run with any way
this way you KNOW you have the right cumulative odo distance, not a GUESS depending on how on the ball or not you are manually re-adjusting your trip during the stage
besides with the Speedocap remote thumb switch you can still adjust the odo manually along the way between waypoints anyway should you wish to
2013 Husaberg FE501
Old 11-03-2013, 04:52 AM   #24
JayBo1
JayBo1's Avatar
Oddometer: 2,803
this way you KNOW you have the right cumulative odo distanceto within around 90m), not a GUESS depending on how on the ball or not you are manually re-adjusting your trip during the stagemanually adjust the ICO? Gave that up years ago, ecpet for if I've made a nav error.
Cheers SB. The CAP repeater is kinda essential but I'm on the fence on springing for the Speedox. More dollars down the gurgler when I already have the CAP Repeater. The speed restricted zones don't bother me, as I suspect I'm the only one that actually obeys those already anyway.
How many people use the auto calibrate function of the ICO? I was converted to that several years ago and love it. Hardly have to make manual adjustments after the first few km's or major changes of surface. I use the .01 feature rather than the .1 so down to 10 meters, not 100 meters. I can't help myself - I'm an engineer!
KTM 530 EXC-R
Old 11-03-2013, 06:59 AM   #25
schattat
schattat's Avatar
Oddometer: 1,442
Garry has a point, the automatic readjustment of the trip on the CAP readout is really slick! Apart from Alain Duclos, also Olivier Pain runs it.
I've been meaning to create a tripmaster version that (soley) runs with the ERTF trip values, but for the time being many riders still run the traditional wheel tripmeters. Plus there are also some minor regulation rules to overcome (monopoly of ERTF and all)...
BTW, many pros like to keep it as simple as can be, i.e. 100m trip readout (blackout the 10m position on their roadbook), no automatic calibration, etc..
Old 11-06-2013, 06:59 AM   #26
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,149
Thanks for starting this thread and everyone else for contributing with your valuable nav knowledge. This is literally a treasure trove for noobs like me.
'07 KTM Adv990S - Gone, to a good home , '12 KTM 990Adv, '10 KTM 530Exc-Rally
No myriad hues of laser lights, no bottles that are oozing with nectars from heaven, No beautiful body soft and warm to the touch but, i have a very small desire, Give me a dark....long....winding road, three gears to go and my Hellas on fire !!
Vicks is offline   Reply With Quote
Old 11-06-2013, 07:15 AM   #27
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,658
This.
The less you have in your mind when racing, the better...
As far as the roadbook is concerned, I will be using HDB brake and clutch lever mounted switches in parallel with a normal RB switch giving maximum ease of use and the redundancy needed. I think that the roadbook area is left on its own regarding redundancy and I don't like this at the moment. If you have either a switch failure or a fall where you damage the rb switch, then you have to go manual.... Most RB's have either transmission or motor failures. There are things you can try to increase motor life but imo I think that the user should be able to service the unit with little or no tools at all in the middle of nowhere.
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon screwed with this post 11-22-2013 at 05:48 AM
640 Armageddon is offline   Reply With Quote
Old 11-06-2013, 08:02 AM   #28
DaveRMS
DaveRMS's Avatar
Oddometer: 1,172
Manual advance is one option, but it's not as safe as spending 5 minutes to make this switch, right on the side of the trail. We've done this in a race.
Strip the wires of the broken switch, insulate the handlebar with tape, and tape the first lead down:
Then tape the second lead above it. Use more tape to create a gap between the leads. Now you just press it down with your thumb.
You only need to repair the "forward" direction. You can manually reverse on the rare occasion that you get off track.
BTW, in my experience these failures are so rare on a well-prepared bike that it's really not worth investing in redundancy on the bike. Just have a spare switch at the bivouac. K.I.S.S. is a good policy.
There are very few things that can't be fixed quickly in the field.
Dave
DaveRMS is offline   Reply With Quote
Old 11-06-2013, 08:22 AM   #29
640 Armageddon
-oo-
Oddometer: 2,658
Dave
I wanted to take off the manual knobs completely and only leave small splines for knobs to be put on when needed, but people wanted the manual advance just in case. I would not advise manual scrolling, too dangerous for me, though the fast guys do not stop for such a reason , that is why I am thinking a small switch from HDB. The buttons are almost invisible, the price is good and it saves me the trouble.
Come next week we will have a good setup and will be trying it in the field...
Old 11-06-2013, 10:53 AM   #30
Muecke
Muecke's Avatar
Oddometer: 74
Yeah, nice job! :)
Muecke is offline   Reply With Quote
Times are GMT -7.   It's 04:40 AM.
