Old 12-18-2013, 01:26 PM   #31
Bluebull2007
Bluebull2007's Avatar
Oddometer: 5,261
Thats really neat stuff there Armageddon & Dave!!
Dreaming of Dakar
Everyone has a max speed, 90% of that max speed is much safer and easier, and if that 90% speed isn't fast enough at Dakar, you enter the snowball. - neduro
Bluebull2007 is offline   Reply With Quote
Old 12-19-2013, 06:46 AM   #32
Mike_MRS
Oddometer: 339
What does that weigh, D? I could make you a composite one
Moto Rally Services UK
Mike_MRS is offline   Reply With Quote
Old 12-19-2013, 07:10 AM   #33
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,597
Yeah I know... weight weight weight... Everybody is getting paranoid about it ....
May be Titanium is better in this one, you know how to make one in Ti, right?
I really do not remember the weight by heart, but there are ultralight versions in Aluminium. Almost 50% reduction in weight compared with the 'standard' versions. I am testing them and will keep doing it till the design is finalized. The sheet metal gets complex, but the reduction as a percentage makes it worth it.
Of course, if you go composite, the reduction is there, but the material is way too complex and unhealthy for my likes. Also more expensive. No?
(There is a version which is lighter than air, it will be almost indestructible and will be ready in the near future. We have solved most of the design issues we had with them. )
Till later,
D.
Aurora Rally Equipment
"Do or Do Not. There is No Try" - Yoda
640 Armageddon screwed with this post 12-19-2013 at 07:41 AM
640 Armageddon is offline   Reply With Quote
Old 12-19-2013, 07:38 AM   #34
Mike_MRS
Oddometer: 339
Yes definitely more expensive. Weaves laid at different angles etc, epoxy and bagged. Ti would be great and I could do one for you but it would be huge money
Old 12-19-2013, 03:09 PM   #35
michael1968
michael1968's Avatar
Oddometer: 771
For one part, yes an aluminium fabrication would be cheaper than composites. For 10, maybe not. It depends on how many labour hours you need to put into each piece vs the material cost. The initial set up and material cost is higher for composites but you can punch a decent volume out fairly quickly after that.
Anyway, Dimitri, those plates look 'factory', I wouldn't expect anything less from you!
Cheers,
Michael
michael1968 is online now   Reply With Quote
Old 12-20-2013, 02:29 AM   #36
Mike_MRS
Oddometer: 339
The composite plates I make are 4 layers of 600gsm carbon laid at opposing angles and 2 layers of carbon/twaron, one top one bottom. Incredibly stiff but will flex a little if required. Bagged and infused with epoxy. Yes they are more expensive than ally, I did them more to show people what can be done with composites for rally bikes than to actually sell them. Here's one just before being drilled. The blue black colour is the carob/twaron fibre. Twaron is an aramid like kevlar, just black rather than yellow
Old 12-20-2013, 02:50 AM   #37
michael1968
Oddometer: 771
Yeah, you're right it'd be cheaper for a piece like that which could be done out of a bent aluminum plate. I was thinking more of Dimitri's part with multiple pieces cut, bent, welded together and anodized or powder coated.
Edit: nice website by the way
michael1968 screwed with this post 12-20-2013 at 02:56 AM
Old 12-21-2013, 02:23 AM   #38
Mike_MRS
Oddometer: 339
Old 12-29-2013, 12:13 PM   #39
uglybassplayer
uglybassplayer's Avatar
Oddometer: 32
Planning nav gear on a shoestring budget, have a manual RB on the way which I am going to add motors to at some point, now thinking about trip meters... Either going to be bicycle speedos (I can find something with a suitably large display) or building my own powered by an arduino.... Does anyone know of any rally trip meter arduino projects I could use as inspiration? Or can anyone suggest a good bicycle speedo?
uglybassplayer is offline   Reply With Quote
Old 12-29-2013, 01:45 PM   #40
Mike_MRS
Oddometer: 339
Just bear in mind that any trip you use needs to have the ability to adjust it so you can match the roadbook. Otherwise the money saved on the kit could end up being false economy if you have to abandon an event (entry fee, fuel etc) because you can't match the instructions due to the trip being out to the roadbook, or if your roadbook reader fails in some way. For example the F2R guys have spent years on developing the roadbooks to be as resistant to vibration as possible, and the motors to handle all the banging and shock.
A bicycle tripmeter tends to have set wheel diameters (in my experience) for you to choose so that's a consideration if the max front size the device will cope with is say, 20". You'd need one which can be calibrated to your exact tyre circumference and which can be adjusted on the fly up or down in total distance.
Maybe another way of looking at is that used roadbooks and trips (assuming F2R or MD / RNS, ICO) in half decent condition will always fetch decent money because there will always be buyers so if you did buy new and you don't enjoy it the loss would be small
Old 12-29-2013, 02:51 PM   #41
uglybassplayer
Oddometer: 32
Cheers Mike, should have added that this is just to get me started practising around local roads and lanes. If I enjoy and get the knack for it ill look at some real kit.
Old 12-29-2013, 03:55 PM   #42
michael1968
Oddometer: 771
For a cheaper alternative to an ICO get a Trail Tech Striker/Vapor (http://www.trailtech.net/712-101) and the optional remote switch (http://www.trailtech.net/digital-gau...-remote-switch) so you can accesss the adjustable trip function.
It's a bunch cheaper and has all the functions of the more expensive ICO.
Old 12-29-2013, 04:20 PM   #43
Gany
Oddometer: 329
I think the Trail tech vector is the only one with adjustable odo via remote?
Gany is offline   Reply With Quote
Old 12-29-2013, 06:34 PM   #44
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
Worked in the Baja rally. Had the vector as primary and vapor secondary. The remote isn't IP rated. I found out.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 12-29-2013, 08:05 PM   #45
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,221
I was rushed to out the phone down while typing earlier. I should mention that the vector is an adequate entry computer but it will quickly be inadequate of you choose to continue. The display isn't big enough for quick looks though it is ok for slower sit down sections mostly. I was happy with its performance for the mean time. I intend on cleaning and sealing the remote. It's in "the list."
Times are GMT -7.   It's 10:01 PM.
