Old 10-27-2013, 02:50 AM   #1
blakken OP
dirt napper
Oddometer: 55
Studded tires
I wounder if any off you fellows have drived with studded tires.
And what kind off tires.
I am so loaded to hit some winter roads and some snowmobile tracks.
But i need tires
Sent from my GT-I9300 using Tapatalk
http://alvsbygrusspratters.blogspot.se/
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
blakken is offline   Reply With Quote
Old 10-27-2013, 05:00 AM   #2
L21
Oddometer: 185
TKC-80 with 600+ auto studs works well for me. They are much better on ice then in deep snow. The 950 is hard on tires and studs if you don't lay off the throttle a little.
L21 is online now   Reply With Quote
Old 10-30-2013, 09:29 AM   #3
blakken OP
dirt napper
Oddometer: 55
Ok i just maby studd a dunlop d908 rr.
With studds from a iceracing car.
Lets se how it works
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 10-30-2013, 11:30 AM   #4
Masa
Masa's Avatar
Oddometer: 300
In front I've a Kings and the rear is (Mitas) Trelleborg Winter Friction, both have enduro spikes on them. Some use rally car studs in the middle and spikes on sides for better ride on ice and occasional tarmac.
Rear tire is only 120 wide, but good enough for me on the stock rim.
Masa is offline   Reply With Quote
Old 10-31-2013, 09:43 AM   #5
randel
randel's Avatar
Oddometer: 316
Don't use ice spikes - they will fail as soon as you left ice. Enduro studded tires are what you need. Trelleborg is great advice (now called Mitas). Both 18 and 21 are available, don't pay attention to width, you will probably not find wider tires than 120, but they will work ok.
950SuperEnduroR
Beyond clouds 2011
Beyond arctic circle 2010
randel is offline   Reply With Quote
Old 11-29-2013, 09:43 PM   #6
blakken OP
dirt napper
Oddometer: 55
Now i have found me a tyre!!!
Pirelli MT21....140/80-18
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 11-29-2013, 09:44 PM   #7
blakken OP
dirt napper
Oddometer: 55
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 11-30-2013, 07:25 AM   #8
smj
smj's Avatar
Oddometer: 207
I can find tires... Where does one find the studs?
Faint is the heart that runs from a fight, but it's a sorry set of legs 'let a man take a beating.
smj is offline   Reply With Quote
Old 11-30-2013, 07:48 AM   #9
种.
Ajaa kuin mummo
种.'s Avatar
Oddometer: 280
http://www.satapiikki.fi
http://www.kisarengas.fi
These are in Finland. I don't know if they speak English or are willing to ship abroad but you can try. If you need help you can pm me.
Pics and vids
种. is offline   Reply With Quote
Old 11-30-2013, 08:57 AM   #10
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,341
Depending on what you aim to do, this thread may help: http://www.advrider.com/forums/showthread.php?t=932734
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 12-03-2013, 12:38 AM   #11
iluha_adv
Oddometer: 15
Post more your ride reports with studs.
I'm thinking of installing studs on IRC TIRE BR99 (140/80-18 Rear, 90/90-21 front). Going to use http://www.best-grip.com/eng/ studs.
1500 series for rear (4mm out) and 1600 series for front(3.6mm out). What do you think about the setup? Will it let me drive gently across the winter pavement to the forest/ice/snow?
One more sad thing - studs are expensive. 500 of them cost about $500.
iluha_adv is offline   Reply With Quote
Old 12-03-2013, 04:05 AM   #12
L21
Oddometer: 185
Tire studs are available from www.brunowessel.com. You will need a stud insertion tool, drill stop and bits all available from them. I use light truck studs in TKC 80 tires about 500 to 600 for front and rear works well for mixed road conditions. Rally studs are available to but do not work well on dry roads. The stud insertion tool is the big expense, studs last year were about $60 US for a box of 1000. If you are going to ride a lot it is worth the investment in the tools to do it your self.
Old 12-03-2013, 07:08 AM   #13
Balsta
Oddometer: 400
other studs
http://www.best-grip.se/Shop/Index.php?sLang=LangEng
I use these studs which you can install without any costly special tools. Plenty different lengths and styles to choose from, for your shoes too!. Don't know if this kind of studs are available in North America.
950 SE -06 with 2009 SDR 130 hp motor (but carbed...120 hp?)
Balsta is offline   Reply With Quote
Old 12-03-2013, 08:44 AM   #14
blakken OP
dirt napper
Oddometer: 55
I have now test driven the tyre..
Ind its has very god traction.
On road its litle funny to drive.
But if its are litle ice or snow its works...
On snowmobile tracks its awsome...:)
2013 350 freeride
2011 990 adv r
2011 690 enduro r
2010 990 adv abs
Old 12-03-2013, 09:35 AM   #15
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,976
Tyre chains
This is what I've found:
They are produced in 150/70/18.
Times are GMT -7.   It's 04:01 AM.
