Old 10-27-2013, 09:44 AM   #1
smitty141 OP
smitty141's Avatar
Oddometer: 662
Error code 2nd Throttle Control system malfunction help!!
After a new open air filter, sas removal, caniter removal I get this FI light and code.
I have loaded a new map with Tune Ecu. Bike seam to run okay, but I have cleared this code twice, and it comes back.
Anyone have had this trouble please chime in..
Also, has anyone removed the secondary butterflies and turned the off??
Thanks, Smitty
RIP.. Skinny Dave...RIP.. Chester
2011 Prudoe bay, Dalton Hwy. 2014 Inuvik, NWT Dempster
2013 Yamaha FJR 1300..2010 BMW 800GS..
1999 Yamaha YZ250.. 2008 Suzuki DRZ400SM
smitty141 is offline   Reply With Quote
Old 10-27-2013, 02:56 PM   #2
Defaultgateway
Oddometer: 87
Error, second throttle
What map did you load?
Look at your map you loaded, Tune-ECU, "Map Edit" tab, Parameters, Devices
Assuming you have removed the SAI valve but still are using the 2nd throttles (butterflies):
SAI No check mark
O2 Check
2nd Throttle Check
Idle Speed Control Check
EPC No Check
Is this what you have?
Do not un-check the Idle Speed Control or the Second Throttle. The only time you can un-check the 2nd throttle is if you have removed the secondary throttles from the throttle bodies.
(I'm in the camp of using the O2 sensors and 2nd throttles.)
Defaultgateway is offline   Reply With Quote
Old 10-27-2013, 03:30 PM   #3
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,042
You can also run the 2nd throttle test in tuneECU.
I'd bet the box is unchecked as above.
Max
Da oggi la strada
senza limiti
MAXVERT is offline   Reply With Quote
Old 10-27-2013, 03:35 PM   #4
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
If the box is checked, I'd take a good look at the actual linkage. With the new intake it's not impossible that wiring or the breather hose may be interfering w the actual linkage.
Sa
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 10-27-2013, 05:49 PM   #5
smitty141 OP
smitty141's Avatar
Oddometer: 662
SAI No check mark
O2 Check
2nd Throttle Check
EPC No Check
This is exactly how it is set. I'm running the CPR map.
Max
Max, how can I run that check?? I did remove the filter assm. to check wiring, linkage, ect. All looked good.
After doing a code reset, put the bike back together.. Didn't make it out of my driveway and the light was on. I did a rolling restart two blocks up the street. After the bike restarted the light never came back on. Road about 120 miles, withe several stops with the motor off.
Thanks for any help, Smitty
Old 11-24-2013, 05:20 PM   #6
srad600
srad600's Avatar
Oddometer: 670
P0638 Error
Interesting, I just got this error for the first time today. I'm hoping this does not recur, but if it does, did anything come of your issue?
It happened to me upon intial start-up. I rode for a few miles and then went down a side road, pulled in the clutch and switched the bike off and back on. The light has not come back on yet (40miles+ later). I checked the code with tuneecu and got two: P0638 - Throttle control system malfunction and P1650 - Immobilizer Malfunction.
I've gotten the P1650 before, and it seems to keep coming back. I'm going to have to get that looked at.
The P0638 is a new one. I installed a foam filter, and re-mapped the bike two weeks ago. I also removed the SAS and canister at the same time. I never received an FI error until today (I've put about 360 miles on it since the filter/emissions stuff). TuneEcu screenshots are below.
EDIT: I also did a "reset adaptation" after clearing the codes, and the light did not come back on. I'll find out tomorrow morning if it will come back on or not.
srad600 is offline   Reply With Quote
Old 04-24-2014, 10:41 AM   #7
dgjackson40
Oddometer: 263
Same Error
I have same set up with stock exhaust and am now getting this P0638 error but it will not go away after reset. Did this issue ever get resolved?
The trail is the thing, not the end of the trail. Travel too fast and you miss all you are traveling for. Louis l'Amour
2007 KTM 990 Adv; 2005 VStar 1100 Sold!; 2002 GL1800
dgjackson40 is offline   Reply With Quote
Old 04-24-2014, 11:36 AM   #8
Pistolero
W. F. O.
Pistolero's Avatar
Oddometer: 712
2nd TB linking arm is contacting the plate I bet
Very likely if it's a knock-off plate and not a CPR.
Pistolero is offline   Reply With Quote
Old 04-24-2014, 12:02 PM   #9
dgjackson40
Oddometer: 263
Yep
Yep and yep!
Old 04-24-2014, 02:06 PM   #10
renogeorge
Oddometer: 1,389
I am running the SW7 plate and have no problems with codes on my 2007.
Someone asked about the 2nd throttle removal. I tried it both ways with butterflies removed and with them installed. I could not notice any difference. As mentioned, they must be checked/turned on in Tune ECU, if butterflies are installed.
FWIW
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Times are GMT -7.   It's 02:49 AM.
