Go Back   ADVrider > Riding > Regional forums > West California, the desert southwest and whatever is left
Old 03-04-2014, 09:46 AM   #1786
markrmark
Oddometer: 51
Originally Posted by itnanti View Post
What bike are you riding? Last year I had those same tires on my Klx. D606 did good but the mt21 washed out on almost every corner. I switched to the Perelli xcmh front and loved it in the dirt. Good good mileage on pavement as well. I would switch it at the rally so you have fresh tread for the dirt though. My 2 cents, hope it helps
Hmm.. yeah, it's a KLX250S..
the tires are almost new (couple hundred miles + some dirt)
markrmark is offline   Reply With Quote
Old 03-04-2014, 09:53 AM   #1787
itnanti
aka "cautious cotta"
itnanti's Avatar
Oddometer: 435
I went to Scott's performance last year after the rally and told them what was happening. The guy said to try out a more aggressive dirt tire that he had the same experience with the mt21 tire washing out. Everyone has different opinions about tires and I can only speak from experience that I noticed a huge difference with the Perelli XCMH. My buddy had mt 16 on his Klx and had good things to say about it. The rally is only once a year so bring a fresh pair and don't worry about burning them up at DV, it will be me less thing to worry about out there.
itnanti is offline   Reply With Quote
Old 03-04-2014, 10:28 AM   #1788
markrmark
Oddometer: 51
Originally Posted by isaac004 View Post
I have been happy with that combo, as I used to run MT21 front and MT43 rear on my WR250R. I would get 3k to 4k mi out of the front MT21, and around 2.5k mi on the rear MT43. I have run a set of DR606 for 5k miles on my DR650 before (about 2k of pavement and 3k of dirt, a 3 week CDT ride). The D606 setup is a good one too for DV.
Carrying spare tires on the bike is a royal PITA, guaranteed. You could run them to Pahrump, do DV, and ride back. Just air them up to 25-30 psi for pavement. Recommend pressures in DV are usually no lower then 18-20 psi, as people the pressures higher to avoid flats/rim dents from hidden rocks.
Those that run the MT43, highest recommended pressure for dirt AND road is 10 psi...it's a DOT trials tire, so it's different, but 10 psi will get you almost 3k miles of mixed used. Higher then that and it will wear quicker.
Hmm, thanks... maybe I will just skip the PITA and just ride the MT21/606s right to DV... they are almost new now so...
Old 03-04-2014, 10:56 AM   #1789
missadventure
n00bie d00bie d00
missadventure's Avatar
Oddometer: 284
144 MOLLYMARTIAN MOLLY TR3-D2
not MOLLYMARTIAN - MISSADVENTURE
also I didn't see Super Suz on the list. ???
missadventure is offline   Reply With Quote
Old 03-04-2014, 11:12 AM   #1790
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,310
... and I can only speak from experience that I noticed a huge difference with the Perelli XCMH.
+1
The XCMH is one of the very best for cornering grip!
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is online now   Reply With Quote
Old 03-04-2014, 11:41 AM   #1791
Nowwhat
I'll Go Second...
Nowwhat's Avatar
Oddometer: 4,992
Death Valley has exactly zero hill climbs so the rear tire is just not that important....
Small bike XCMH front
Medium Bike 908 front
Big Bike 606 front
'14 1190R...Adventure Beast
'13 690 Quest...Rally Beast
'15 Husqvarna 501...Trail Beast
950SE......Desert Beast
Nowwhat is offline   Reply With Quote
Old 03-04-2014, 11:57 AM   #1792
bigtodd
Hi, wanna ride?
bigtodd's Avatar
Oddometer: 1,551
tires and opinions ...
might as well jump in here. I put the new Scorpion Pro's on my 525 as a test pilot and rode the Desert Dash a couple of weeks ago. I was very impressed in all conditions; rocks, hard pack, sand, gravel. Might be a little soft for most of the DV terrain but they worked for me at 18-20 psi. One of the better biting front tires I've tried so far on my little girls bike.
Life is an adventure that requires the correct equipment
SPOT - bigtodd - where I at now?
bigtodd.whereamiriding.com
bigtodd is offline   Reply With Quote
Old 03-04-2014, 12:00 PM   #1793
Suzuki Phil
Oddometer: 645
Ersin,
I'd take site #72 if possible, sent you a PM also.
Thanks,
SP
Originally Posted by airborndad View Post
campsite confusion
I am by no means in charge of any of this
just being observant
in post #4 ( the first part of it)
it appears to me that Ersin has already started a list of which campsite people will be in using #1 through # 73
I will advise ignoring that there are 71 campsites in the photo of the campsite and 73 campsites in the other campsite layout diagram
also note that there is not a campsite #13 but there is #14 #14A #14B #14C ( just to add more confusion)
here is the list
copied from post #4:
Here is the campground list. Please check your name and let me know what spot you want. If I dont get your request, I'll just assign you a random spot.
#1 hotmama, hotmamaandme, rjnutt
#2 sandplow, mrs. sanplow, laddysdirtbomb, mrs. laddysdirtbomb
#3 Dunerat
#4 lifeofreilly, goodonyam8
#5 elifino, elifino guest, alyssag, alyssag guest, fhammond, ixab, ixab's bro
#6 the brazilian
#7 Don125, Don125's guest
#8 avejoe
#9 Browneye, Browneye's wife, Browneye's son
#10 CrankyTony
#11 Beatsworkin'
#12 jkstehn, jkstehn's guest #1, jkstehn's guest #2, jkstehn's guest #3
#14 tbarstow, heirhead, heirhead's guest
#14A Perkio, Jimerhart
#14B
#14C
#15 tonyj, PastRedLine
#16 Tdsurf, PukaWai
#17 Motopsychoman
#18 gunz11
#19
#20
#21 vpannepacker, macadamia, ZenRiding
#22 Spafxer, Deliverator
#23
#24 itnanti, Illking
#25 PERRO-FROM-HELL, ohpyramids, Spaniard990
#26 Nubs, Nubs' guest, ThirdBestFriend, GMC327
#27 m1jeep, m1jeep's son, KLRrob
#28
#29 ravnx, NotSoFar
#30 Easyrider Jay, Easyrider Jay's guest #1, Easyrider Jay's guest #2
#31 sierrasommets
#32 isaac004, michael.brat
#33 mikey113, headstaller
#34 Eggroll, Xiao858, Tortillaland
#35 Letsgetdirty, Philipp
#36 Sombrero, Toddsci
#37
#38
#39 super suz, missadventure
#40 Z-asshurts, Pcfly, Pcfly's guest
#41 Dirt Mechanic, Dirt Mechanic's wife, Dirt Mechanic's guest
#42 Sfcootz
#43 Off Road Ryder, Off Road Ryder's guest #1, Off Road Ryder's guest #2
#44
#45 aiMhi, Mac
#46
#47
#48
#49 nicomama, Paul, airborndad, THRASHED, JustinBustin
#50 1224R, Unkgd
#51 Blaise W
#52 r3r3r, joefromsf
#53 jeepdude65, trknBIGtrailer
#54
#55 Fzcruzer, Fzcruzer's wife
#56
#57 GREGTHEADVENTURER
#58 raultheadventurer, CalGSer
#59 tomscj6, tomscj6's guest
#60 nwemerys, soupknotzee
#61 slugdad, slugdad's guest #1, slugdad's guest #2, slugdad's guest #3, slugdad's guest #4
#62 JAB, jasonfb123, Ahamayjoe
#63
#64
#65 jeepinbanditrider
#66 AdventureDave82
#67 Shooby, Stoke
#68 TSJA, Kenpokid, Oldman7
#69 dzrtracin
#70
#71
#72
#73 RED05, RED05 guest #1, RED05 guest #2
I do recall Joel saying that sites #46 #47 #54 #55 were reserved for volunteers and those sites will also be all or part of party central
AKA dinner/raffle/main campfire sites
so if you have a fear of loud noises or drunkin giants I would try choosing a site that is approprietly distanced from those previously mentioned sites
1916 Ford Model T
1996 DR350SE
Suzuki Phil is offline   Reply With Quote
Old 03-04-2014, 02:51 PM   #1794
rensho
Oddometer: 180
Originally Posted by Nubs View Post
How does one actually sign up for the group rides? I went to the http://ridelist.robgapps.com, registered, clicked on a ride and can see who is attending the ride but no way to actually get on the list. What am I missing?
Seems to work for me, now.
When I signed up, once you register, you had to re-sign in. Then clicking on rides that still have spots, you'll see the 'join' button.
rensho is offline   Reply With Quote
Old 03-04-2014, 03:21 PM   #1795
FYYFF
Forever young...
FYYFF's Avatar
Oddometer: 2,036
Stop this mayhem!!!
Finally I am back. Sorry for my absence but it was a much needed break. I'll work on my RR soon. Hopefully will be done before DVNR.
Originally Posted by M1Jeep View Post
Ersin will sort everything out when he returns in the next few days.
Thanks for believing in me Rich.
campsite confusion
You are right Keith. I deleted that 4 spots from the list to prevent more confusion. Also moved Mr. & Mrs. Fzcruiser to next door camp spot. Hope that's OK with you Rob?
I updated all the requests that I was able to see here on the post and my message box. Please take a look at this list and find yourself. If you don't have a spot yet, let me know or else I'll be assigning random spots starting this week.
Thank you for your understanding.
#3 Dunerat
#6 the brazilian
#8 avejoe
#10 CrankyTony
#11 Beatsworkin'
#14B FTL900, Ricorider
#14C markrmark,
#16 Tdsurf, PukaWai
#17 Motopsychoman
#18 gunz11
#19
#20 Rotex, Mrs. Rotex
#23 dantroop
#27 m1jeep, m1jeep's son, KLRrob, rider914
#28
#29 ravnx, NotSoFar
#31 sierrasommets
#37 B&S 5HP, GooseRider
#38
#42 Sfcootz
#44
#45 aiMhi, Mac
#48
#50 1224R, Unkgd
#51 Blaise W
#56 Fzcruzer, Fzcruzer's wife
#63
#64
#66 AdventureDave82
#67 Shooby, Stoke
#69
#70
#71
#72 Suzuki Phil
- 2010 KTM 990 Adv. -
My Smugmug
Follow me with SPOT
My YouTube
FYYFF is offline   Reply With Quote
Old 03-04-2014, 03:35 PM   #1796
Belkar
Oddometer: 24
I'd like to revise my request to spot #48.
Belkar is offline   Reply With Quote
Old 03-04-2014, 03:37 PM   #1797
sarathmenon
Oddometer: 1,010
Hi Ersin, since you put this up, can you assign my tent spot in 17 or 18? I foresee plenty of drinking in the evenings, and I am trying to be strategically close to the rest rooms
sarathmenon is offline   Reply With Quote
Old 03-04-2014, 03:43 PM   #1798
FYYFF
Forever young...
FYYFF's Avatar
Oddometer: 2,036
Done.
And done.
My Smugmug
Follow me with SPOT
My YouTube
Old 03-04-2014, 04:00 PM   #1799
itnanti
itnanti's Avatar
Oddometer: 435
Forget fixing the camp sites let's see pictures of the Costa Rica ride :)
Old 03-04-2014, 04:15 PM   #1800
FYYFF
Forever young...
FYYFF's Avatar
Oddometer: 2,036
Brian, Costa Rica was something else... Riding a WR250 on those jungles were amazing. I have lots of pictures but mostly GoPro footage because there was no way for me to take my hand of the handlebar for a picture. I consider myself lucky for surviving this ride.
This was my first time on a small bike (other than couple miles on Bigtodd's 525 in Baja) and I am telling you, the terrain was brutal...
Anyways. First thing first, it is time to take care of the Noobs now.
Guys, if for any reason there is a problem with your camp spot, please find Jim (Spafxer) at the campground. He is the camp host and will have a list of everyone's name and space.
My Smugmug
Follow me with SPOT
My YouTube
Times are GMT -7.   It's 05:42 PM.
