Old 10-28-2013, 12:24 AM   #1
GoneAgain OP
Huh?
GoneAgain's Avatar
Oddometer: 1,622
Question F800GS Spark Plug Replacement How-To..
So it was time to change my spark plugs.. searched all over the world for some 'instructions'.. couldnt find anything definative.. did find a few very usefull tips..
Is there a 'how-to' somewhere..?
(if there isnt, is one worth doing..? (i took a few pics along the way)
cheers...!
GoneAgain is offline   Reply With Quote
Old 10-28-2013, 05:27 AM   #2
chriselgui
chriselgui's Avatar
Oddometer: 154
How many miles before you decided to change them?
chriselgui is offline   Reply With Quote
Old 10-28-2013, 05:57 AM   #3
MikeMike
MikeMike's Avatar
Oddometer: 4,150
So you want to change your plugs?
Buy regular replacement plugs, the fancy ones won't make any difference.
Make absolutely sure you have the correct wall thickness on the socket you are planning to use. There is fck all space in there and you can easily jam a regular wall thickness socket and then you are seriously into some overtime to get the job done. Double check this. If you are using the tool that BMW sells it will fit, but many normal plug sockets have too thick a wall and will jam.
If you do not have the tool to pull the coil sticks, try to either buy one or borrow one. If not, you will need strong fingers and a lot of patience.
DO NOT TRY TO LIFT THE COILSTICKS BY THE CONNECTORS ON THE BACK!
They will simply snap off and then you are going to be paying out the arse end for a new one(s). They are expensive.
Use a slight amount of anti-seize on the new plug threads, DO NOT USE OIL, and use some dielectric grease on the coilsticks, small amounts here.
Make sure you have all the tools you will need before you start, if not you will be tempted to improvise and likely break something made of plastic.
Whatever it is will be expensive, too.
Think about changing your air filter at the same time if you haven't done so in a while.
Don't forget the hose connections and hose routings on the bottom of the air box chamber, it can be possible to kink these or not connect them properly and then you will have issues.
Unless you have at least 20,000 miles on the plugs, don't bother to change them. Think about doing a valve check at the same time if you haven't done so, you are half way there so you may as well think about that.
Work slowly and use a new valve cover gasket unless you really enjoy the job and can't wait to open things up a second time.
Both the Haynes and the factory disc manuals show the procedure, PM me if you need pics or something.
I did mine without the coil stick puller tool, I did not use the piece of wire method nor the pry gently with a screwdriver method, I used my fingers.
One trick is to reverse fold the rubber boot on the coil stick and avoid the back part where the connectors are. The reversed rubber boot gives you some added grip. They will come out but it takes a while and you will be tempted to go for a lift on the connector stub, resist that. I've seen some that were very difficult even with the puller tool.
Since I was not sure about the wall thickness on the socket I was using, I measured the 3 that I had and took the one with the thinnest wall thickness (notice how much I am emphasizing this). I attached it to a long T-driver and used duct tape to firmly hold it on the T-driver. I then very slowly lowered it in (the plug tunnels are fairly deep) and made sure when it just began to make contact that it had no side to side movement, meaning the socket was on the plug correctly and fully engaging it, but I also had upward movement meaning I wasn't jamming it in the tunnel.
The plug socket I used was an old one that had a decal on it. The decal was scraped off the socket, that is how narrow the tunnel is. Most normal plug sockets will be a millimeter or more too large on the wall thickness. The Craftsman sockets I had were all too thick, by the way.
If you have the coil stick puller and a known good socket, the job is very simple, don't forget to give a good cleaning of the throttle bodies while you have them exposed. It is a little monotonous, make sure you have some good music playing.
Old 10-28-2013, 06:24 AM   #4
bmwroadsterca
RadioFlyer
Oddometer: 173
Socket?
Can anyone suggest a name brand socket known to work in this application? Thanks.
mike
bmwroadsterca is offline   Reply With Quote
Old 10-28-2013, 07:45 AM   #5
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,401
mike
BMW is a name brand tool.
I bought the plastic coil stick remover tool from the Dealer. I think it was $10?? For occasional use only but we have 2 bikes and it works. The trick is to smear dielectric grease on the outside or the coil AND put a squeeze inside as well. This will make next time much much easier.
I used my Craftsman socket all greased up then went through 2 beer trying to remove it on the second plug. Lazy me really. If you have time and a grinder, remove the chrome on your socket and keep it for plugs only. Otherwise, price it out at the Dealer. My grinder is ready and my valve check is due.
Plugs are changed on the second valve check. There is NO need to do it just because. After 40K kms, they don't even look bad so think about why you want to change them.
Yes, there was a thread from a guy who's wife thought he was useless so he decided to prove her wrong by changing his own plugs. After F'ing things up real bad he posted a "Mayday" and we never heard back. I think wifey done him in.
Oh, and just check Dieselboy's Cam Chain replacement thread as it starts out with accessing the valve cover.HERE and go to post #61 to start.
Leaving it all behind 2014
Pura Vida my Ass.
Reaver screwed with this post 10-28-2013 at 08:21 AM
Reaver is online now   Reply With Quote
Old 10-28-2013, 08:03 AM   #6
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,401
Spark-plug socket, Removing/installing spark plug
Part No.
83 30 0 401 695 - Max BMW Lists $59.56
Removing ignition coil
Part No.
83 30 0 401 700 - Max lists at $61.38. This is the aluminum shop tool and not the plastic occasional use one I bought.
7 673 248 - this is part of the PN found on my stick removal tool. I need the prefix. Can't find it in my RepRom.
Pura Vida my Ass.
Reaver screwed with this post 10-28-2013 at 08:10 AM
Old 10-28-2013, 08:56 AM   #7
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,620
Run a $10 socket down to your local machinist..$10 will remove half the wall thickness..
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 10-28-2013, 09:01 AM   #8
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,401
Perhaps vegasgsa is right
Pura Vida my Ass.
Old 10-28-2013, 10:31 AM   #9
MikeMike
MikeMike's Avatar
Oddometer: 4,150
He is right.
Also, the coil stick removal tool is about $25 bucks anyplace other than from BMW.
According to some people, the plastic ones can break or spread uselessly if the coil sticks are particularly difficult to remove. The metal ones for $25 bucks won't do that.
I have a suspicion that not only Rotax have the narrow plug tunnels, a place that sells bike specific tools will likely have a thin wall socket for under $20.
The BMW one comes with the extension piece. You might be able to borrow one from a guy who has a factory tool kit from an earlier model GS.
Be worthwhile to ask around.
Whatever you do, do not break a coil stick or crack the air box chamber.
And don't get a socket stuck in there.
Old 10-28-2013, 01:30 PM   #10
dpm
Oddometer: 203
cheapo long thin-wall tubular steel 16mm plug spanner works fine.
http://www.carsparkplugs.com/tools-s...l#.Um7JYFP6T5k
dpm is offline   Reply With Quote
Old 10-28-2013, 01:47 PM   #11
bmwroadsterca
RadioFlyer
Oddometer: 173
Measurement?
Would some kind soul who has one of these BMW sockets, or any socket that actually works, please measure the outside diameter (or the outside dimension at the hex points if that is greater) and let us all know so that we can either find an equivalent or know by how much a socket needs to be machined down?
Thanks a bunch.
mike
Old 10-28-2013, 02:02 PM   #12
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,401
While not answering your question directly:
Spark plug measures 17.63 mm on the points of the flats which is the largest dimension.
My "almost" socket measures 22mm OD giving a wall thickness of 2.12mm.
So by my quantum physics calculations I'd say 21mm OD would be adequate. It's a low torque on the plugs so thinner is ok.
Pura Vida my Ass.
Old 10-28-2013, 03:00 PM   #13
itsatdm
itsatdm's Avatar
Oddometer: 5,003
It doesn't have to be a 16mm. A 5/8" will work fine. Google thin wall 16mm spark plug socket and you should find a number of sources for about $10.
Cruz Tools has them in different lengths http://www.motorcycle-superstore.com...FSdp7AodNjQAsQ as does a lot of hardware stores, such as orchard supply.
itsatdm screwed with this post 10-28-2013 at 03:06 PM
Old 10-28-2013, 03:54 PM   #14
GoneAgain OP
Huh?
GoneAgain's Avatar
Oddometer: 1,622
No... already done it... was just asking if anyone thought a 'how-to' was worth me spending my time on..
didnt know if it was viewed as 'too simple a job' to be worth the effort (writin those things up takes a lot of time/effort...! ) or if there was one already wich i didnt find and would just be duplicating..
mike
I used a Kincrome 5/8, part number ZDA26DC.. even has a magnet in it...
Thanks a bunch.
mike
its 22mm wide and was an easy fit down in there...
Old 10-28-2013, 04:09 PM   #15
MikeMike
MikeMike's Avatar
Oddometer: 4,150
And the coil stick remover of your choosing was?
Times are GMT -7.   It's 11:28 AM.
