Old 10-28-2013, 04:26 PM   #16
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Originally Posted by itsatdm View Post
It doesn't have to be a 16mm. A 5/8" will work fine.
Serves me right for not thinking outside the metric box. My 5/8 Mastercraft spark plug socket is 21.25mm. Bet it works just fine.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 10-28-2013, 05:06 PM   #17
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Canadian Tire aux go go!
Old 10-28-2013, 07:08 PM   #18
GoneAgain OP
Huh?
GoneAgain's Avatar
Oddometer: 1,597
Originally Posted by MikeMike View Post
And the coil stick remover of your choosing was?
i went the good ol' fingers route..
first one came out easy... second was a lot harder..
but yeah, got a firm grip on the top with one hand and pulled, while holding that little 'careful you dont break it off electrical socket' with the other and turning it from side to side (only about 5mm each way...)
did the trick..
its only 3 rubber ridges that is holding it in, once i had one out and saw this i wasnt so worried about breaking it...
GoneAgain is offline   Reply With Quote
Old 10-29-2013, 05:05 AM   #19
JRWooden
Oddometer: 4,287
... Make sure you have all the tools you will need before you start, if not you will be tempted to improvise and likely break something made of plastic. Whatever it is will be expensive, too ...
That's a lesson I've "learned" more than once ...
Old 11-07-2013, 02:17 PM   #20
bmwroadsterca
RadioFlyer
Oddometer: 166
Another socket
My thanks to those who posted information about the outside diameter of sockets that will fit down the tunnel.
I spotted a 16mm spark plug socket by EMGO at a local dealership and picked it up for the princely sum of $7.20 Cdn. This socket has a maximum diameter of 21.0 mm so it should work nicely. It has the rubber insert to hold the head of the plug and interestingly it has a hex shaft that can be driven with a 10mm socket. The EMGO number is 84-04116. It is said to be a replacement for the Honda tool #89216-KYZ-700.
On page 76 of the EMGO catalog found here:
http://www.emgo.com/images/pdf/2013_Filter_Mirror.pdf
mike
bmwroadsterca is online now   Reply With Quote
Old 11-07-2013, 08:45 PM   #21
Snowy
Oddometer: 1,880
I bought a pair of dual electrode irridiums, because I find they last longest and give least trouble.
Just opened her up and changed them. Didn't really put any thought into it.
That was about 40,000kms ago if the texta writing on the beer fridge is accurate.
Running sweet as.
Might check them in another 40,000.
Or I might not. Irridium, trust me, don't shell out on Platinum. Don't waste time with the standard plugs.
Snowy is offline   Reply With Quote
Old 11-08-2013, 09:04 AM   #22
Tor
Native Viking
Tor's Avatar
Oddometer: 805
Perhaps vegasgsa is right
or if you have your own bench grinder you can fix one in 5 minutes.
"Be Always Sure You Are Right - Then Go Ahead"
2005 Honda ST1300 / 2010 BMW F800 Gelände-Straße
Tor is offline   Reply With Quote
Old 11-08-2013, 12:52 PM   #23
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Do I hear an echo???
PS......I was poking at Vegas but now that he's changed his sig line it's not funny anymore.
Old 11-09-2013, 12:35 PM   #24
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,254
Found the PN for the occassional use coil stick remover:
12137673248
A&S says $4.
Old 11-09-2013, 01:36 PM   #25
MikeMike
MikeMike's Avatar
Oddometer: 4,150
Buy the metal one, the plastic ones either break or slip on tight coil sticks. The metal one will remove even the most difficult.
BMW doesn't make tools available at dealers in some parts of the world, so depending on where you are, even the plastic one can be N/A which makes you SOL.
Old 08-06-2014, 07:45 PM   #26
mischief
misadventurer
mischief's Avatar
Oddometer: 612
What plug # did you use?
NGK's website doesn't seem to list an iridium plug for an F800
Thx
Christi
Running sweet as.
"I have this moment and no idea when it will end" - Andrea Gibson
"The adventure begins when the plan turns to shit." I don't know who said that first but I like it 'cause my plan turned to shit a long time ago
mischief is offline   Reply With Quote
Old 08-06-2014, 11:36 PM   #27
Hamish71
Hamish71's Avatar
Oddometer: 414
Thx
Christi
Don't know which NGK site you are looking at then.
The NGK Recommended Iridium for F800GS is a DCPR8EIX
Now: 13 F800GS, Kalamata Olive, with all the fruit!
Previous: 08 F800GS, 09 KTM 300EXC, 05 KTM 450EXC
Hamish71 is offline   Reply With Quote
Old 04-19-2015, 07:07 PM   #28
vanbc
Oddometer: 13
Thanks for the thread. Me and bro in law (mostly him) successfully changed plugs (stock) and air filter. After spending a lot of time on pulling the first coil out by hand, he used a tie down strap and wrapped it around but under the boot of the second coilstick. Came right out. To us, it seems the suction from the plug itself is what is making it so hard to pull out. Happy we still have our 26 year old filter queen vacuum. Fits like a glove for cleaning out any debris from the chambers.
vanbc is offline   Reply With Quote
Times are GMT -7.   It's 08:15 AM.
