Old 11-04-2013, 08:45 PM   #46
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Originally Posted by grant22 View Post
I did super plush and have been beyond happy. Literal night and day difference and the best 8 ball I've spent on that bike.
I think if you'll be offroading ANY suspension shop will improve your bike. All I know is super plush nailed mine.
I just realized konflict is in the Seattle area. I thought they were in LA only.
Might have to go with them because they will be local for me.
-BT
Brown Town is offline   Reply With Quote
Old 11-05-2013, 12:12 AM   #47
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,984
A safety issue to bear in mind
or to tackle permenently!
http://advrider.com/forums/showthread.php?t=551666
Cheers
Old 11-05-2013, 06:23 AM   #48
grant22
grant22's Avatar
Oddometer: 474
Should be good. Local is always good incase they didn't get it right and you need to take it back. S&H on forks and a shock is pricey.
Btw, if you want speed while riding offroad, suspension is the first thing you should spend money on.
Otherwise the 990 loves to bottom with a vengeance.
grant22 is offline   Reply With Quote
Old 11-05-2013, 06:27 AM   #49
grant22
grant22's Avatar
Oddometer: 474
Brown Town, what's your weight?
Old 11-05-2013, 08:13 AM   #50
Brown Town OP
Brown Town's Avatar
Oddometer: 195
200lbs
-BT
Old 11-05-2013, 08:18 AM   #51
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Skid plate, side stand relocator, 600mi break-in, suspension...that is my plan. If I make it up to Seattle sooner, suspension will be first.
-BT
Old 11-05-2013, 08:43 AM   #52
grant22
grant22's Avatar
Oddometer: 474
Good plan.
At your weight (same as mine) then you should be in the area of:
6.4 n/mm front springs
Fork revalve
Shock revalve
The shock's stock spring is good, shouldn't need replaced for your weight.
This is what they did for my bike and it's been really good.
Old 11-05-2013, 08:44 AM   #53
grant22
grant22's Avatar
Oddometer: 474
Remember to consider weight in your tank bag and the possibility of riding two up and/or luggage. Those all have weight and matter to the suspension tuner.
Old 11-05-2013, 12:36 PM   #54
Brown Town OP
Brown Town's Avatar
Oddometer: 195
And does anyone have an opinion on two-into-one exhaust besides weight and freeing up space? Downside?
-BT
Old 11-06-2013, 03:53 AM   #55
TA-Zappa
TA-Zappa's Avatar
Oddometer: 171
Originally Posted by RememberTheFallen View Post
Since this thread is already going I got an orange noob question too.
How many miles would you all consider too much on a used bike? 25k? 35k? 50k? I know Pyndon got 100k on his but I do not have the mechanical skills or extreme attention to detail he does. So what number would scare you away if you were looking at a used bike and did not want to spend a bunch on repairs in the near future? Thanks.
Joe
My 05.5 950 Adv S dialed in after about 40000km, before that I had some strange problems with it and had to replace quite a lot of stuff. But after 40000km all I've needed to do is normal service and tires (well and 1 set of steering bearings(sp?)). Rest is put on fuel and fun... :)
I would be more scared to look at a 950 with low mileage (below 35000km) then one with more then 35000km. Of course the general status of the bike is important but as others have said a well cared and documented high mileage bike is far better then a low undocumented bike which doesn't look clean.
Cheers,
Zappa
'05 950 Adv S - 73000km
'14 Beta RR 350 - 15h
'14 Beta RR 350 - 2h (Stolen)
'09 250 EXC-F SixDays - 184h (Stolen)
'98 XL600V Transalp - 86000km - SOLD
TA-Zappa is offline   Reply With Quote
Old 11-06-2013, 08:44 AM   #56
Wastedavid
Oddometer: 28
Talking Another 990 Adv Noob
Hi my friends! Some days ago I bought my bike, I did my first 1000 Km and I decided to buy this things:
-Higuer screen, I really didnt like the factory one... that noise in my helmet... really bad bad bad
-The radiator protector... Im changing the plastic one cause the bike needs more air, more than the fans can suck trhough this plastic wall
-New lights, actually the same but with a bit more power (at least that was what my mechanic said - my bike is under warranty)
-I'm thinking about getting the auxiliary light kit because I preffer riding at night (better than being behind a thousand of big trucks on the road)
By the moment I haven't taken my baby off road, but next time I have some days off I'm sure I'll do it!
Wastedavid is offline   Reply With Quote
Old 11-17-2013, 08:51 PM   #57
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Here's a pic of the footpegs
Here's a pic of the seat
This shows the high fender and the fork guards, and the lil brackets I made to make the guards work
You'll also see the roto pax here and doubletake mirrors
And like I said, with suspension and sag setup correctly (meaning head angle geometry is correct) you may find you don't need a damper. The only place I've found a damper would help is sand, but for me sand is just a 30 second at a time thing.
Grant, what rear luggage rack frame is that and how did you attach the rotopax?
-BT
Old 11-17-2013, 09:25 PM   #58
grant22
grant22's Avatar
Oddometer: 474
Orange Noob
The racks are the standard ktm/hepco Becker racks. I thought the plates from beergut and then attached the rotopax mounts to that. Pricey, for the plates + mounts + rotopax cans but worth it. Buy here: http://www.advrider.com/forums/showthread.php?t=883775
This way allows fuel or hardbags (I go back and forth). If you need baggage AND rotopax, just buy wolfman rockymountains or similar and strap them outboard of the rotopax's.
grant22 screwed with this post 11-17-2013 at 09:34 PM
Old 11-17-2013, 09:55 PM   #59
Brown Town OP
Brown Town's Avatar
Oddometer: 195
Do you have/use the added support cross bar for the KTM luggage frame that goes under the rear fender?
It doesn't look like beergut's making them anymore.
-BT
Old 11-17-2013, 09:56 PM   #60
grant22
grant22's Avatar
Oddometer: 474
Yup. Dunno if necessary but I use it
Times are GMT -7.   It's 01:32 AM.
