Old 10-28-2013, 12:26 PM   #1
Baja Designs OP
Baja Designs
Baja Designs's Avatar
Oddometer: 560
CopperDrive form Baja Designs, A cut above the rest
Copper circuit boards transmit heat from LED's 60% more efficiently than Aluminum boards - a technology that allows Baja Designs to be one of the only companies that can safely run high powered LEDs at full power and brightness. Baja Designs' CopperDrive™ boards are combined with an aircraft grade, computer designed aluminum heatsink. Next, a thermal gap pad is added to efficiently transfer heat to the heatsink and provide vibration dampening. Lastly, computer controlled thermistors constantly monitor the temperature at the LED to ensure brightness and longevity.
www.bajadesigns.com
Call me to get your forum discount !!!
1-800-422-5292 ext. 114
-Bailey
Baja Designs is offline   Reply With Quote
Times are GMT -7.   It's 04:13 PM.
