Old 10-31-2013, 08:56 PM   #1
eddyturn OP
Wannabe
Oddometer: 2,040
Elka or the new Touratech rear shock...
Thinking hard about upgrading that rear shock now. Just not sure which one to get. Ohlins... heard they don't hold up long and I don't want to have to mess with rebuilding too often. Rookie with mechanical skills but assisting Dan installing the Indy kit helped my fears. That Indy kit sure did make a difference because the stocker was pretty much frozen there. Anyway - pros/cons of either one of those? Price will be high no matter but bonus time is coming. Thanks to the collective.
All things being equal... fat people use more soap
eddyturn is online now   Reply With Quote
Old 10-31-2013, 09:09 PM   #2
Bill-66
Hencho in Kansas
Bill-66's Avatar
Oddometer: 7,385
Had ELKA on my '05 GS..good kit but coming from Canada, shipping sux..keep this in mind when sending back for yearly rebuilds..
No experience with the TT stuff..looks like every other aftermarket shock out there..in general..TT has a reputation of being backordered or broken..that being said..I don't personally have alot of their stuff..a riding buddy does and wouldn't even consider their shock recently...
I run Hyper Pros now..very pleased, service is excellent..
Have you looked at Race Tech, Yacguar...?
"Ignorance is a powerful tool when applied at just the right time..sometimes even surpassing knowledge.." EJ Potter
Bill-66 is offline   Reply With Quote
Old 11-01-2013, 06:14 AM   #3
Indy Unlimited
Indy Unlimited's Avatar
Oddometer: 1,370
I would get the Elka 3 way with hydraulic preload and adjustable length.
Elka has an awesome adjustment range and high quality construction.
You can use my shock mount kit with a new bearing on the Elka.
Current Stable:
2013 Ducati Hypermotard SP, 2011 Husaberg FE570S, 2011 BMW S1000RR, 2010 BMW F800GS
2007 Husqvarna TE610 , 2003 KTM 525 MXC
Indy Unlimited is offline   Reply With Quote
Old 11-01-2013, 12:22 PM   #4
jengel451
1 Cool MotherF#$cker
Oddometer: 799
I don't think you can go wrong with any of the 3-way adjustable rears. Anything less than 3 way and you're wasting your money.
Elka
Wilbers
Hyperpro/Yacugar (Same shock, different colors and name)
Personally, i'd stay away from Ohlins, I have seen way too many issues. I'd need a compelling argument backed by facts and data to sway me.
jengel451 is offline   Reply With Quote
Old 11-01-2013, 12:32 PM   #5
sturgeon
sturgeon's Avatar
Oddometer: 941
Pretty sure the Elka for F800GS is NOT length-adjustable.
Dyslexics untie!
Dyslexics Untie!
sturgeon is offline   Reply With Quote
Old 11-02-2013, 06:46 AM   #6
Indy Unlimited
Oddometer: 1,370
Elka will make what ever you want from their base design I had them make me a custom shock for a Versys with a resultant 8" of travel and my spring sleection and dampening choices. All braided cable lengths and angles I specified for hydraulic preload and gas reservoir.
You don't want to make a $1,500 mistake so I only recommend full customs for suspension gurus.
Current Stable:
Old 11-02-2013, 06:55 AM   #7
Tork
Pinsetter
Tork's Avatar
Oddometer: 3,510
I would send Alex an email Alex@konflictmotorsports.com and get his take on the TT shock , he has worked with TT shocks since they first cama out .
Tork is offline   Reply With Quote
Old 11-02-2013, 07:12 AM   #8
sturgeon
sturgeon's Avatar
Oddometer: 941
Originally Posted by Indy Unlimited View Post
Elka will make what ever you want from their base design...
So you have an Elka for F800GS with built-in height adjustment? They told me there was insufficient room to add that to mine.
Dyslexics Untie!
Old 11-02-2013, 09:11 PM   #9
Indy Unlimited
Oddometer: 1,370
Elka options specified for BMWF800GS shows a 4 stage options on page 3:
http://www.elkasuspension.com/downlo...Motorcycle.pdf
note: it shows RDH for a stage 4 set up option. RDH stands for ride height adjustment see last page.
Current Stable:
Old 11-02-2013, 09:52 PM   #10
eddyturn OP
Wannabe
Oddometer: 2,040
Thanks guys for the lively discussion.
Old 11-03-2013, 03:18 AM   #11
runnin4melife
Oddometer: 804
I see many negative statements about ohlins with one saying they need data to change their mind, I am along the same thought about data but I would need it to prove that they are bad or not comparable to the other system. I have an ohlins rear with minimal issues on it. All suspensions require maintenance. Be wary as a consumer about anecdotal advice, both good and bad. I think the best advice given so far is that all of the upgrades are good systems, and unless you did a direct side by side it would be hard to know what fits your needs the best.
I do not have a piggy back for mine so I pop the seat to adjust it. This saved me a couple hundred but it isn't as convenient. It does reduce maintenance though and the likelihood of additional parts failure. To each is own. If money isn't and option I do like the tractive kits as I have ridden a few bikes with them but I have no exp with Elka.
runnin4melife is offline   Reply With Quote
Old 11-03-2013, 04:20 AM   #12
Indy Unlimited
Oddometer: 1,370
Ohlins is good stuff if you have a shop set it up for you and your bike.
It just that us old school guys were used to Ohlins being superior many years ago and now they are just overrated and many companies make a superior product.
Current Stable:
Old 11-03-2013, 05:15 AM   #13
FredRydr
Danger: Keep Back 500 Ft.
FredRydr's Avatar
Oddometer: 2,460
Originally Posted by runnin4melife View Post
...Be wary as a consumer about anecdotal advice, both good and bad....
This is one of the biggest downsides of internet forums like this. Furthermore, "I heard that" lacks credibility doubly so because it's hearsay anecdotes! Alas, the motorcycle consumer doesn't have much in the way of Consumer Reports or Which?, so we are left with the task of sorting the empirical wheat from the bullshit chaff.
Fred
FredRydr is offline   Reply With Quote
Old 11-03-2013, 07:00 AM   #14
sturgeon
sturgeon's Avatar
Oddometer: 941
Guess they've changed it then. Wasn't available a year ago (as you can see from my photo). I do recall some discussion back then about errors in the Elka promo material. All I can say is, if you plan to buy one, verify it with Elka if it matters to you (it didn't to me).
Dyslexics Untie!
Old 11-03-2013, 07:20 AM   #15
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,712
I'm loving the TT Highend on my bike. Offroad/Onroad they hold up pretty well and even jumping the bike a couple of times never managed to bottom it out. I know that in US they are a heck more expensive then here in europe so I'd go with another brand over there but here the price is just the same as the other 3way suspensions
Keep the smile on your face!
Originally Posted by Reaver View Post
You can be imitated but not replaced. You're such a special blend the recipe is guarded like KFC's 11 herbs and spices.
Homeless Otter on the road One month to find the rising sun
Loutre is offline   Reply With Quote
Times are GMT -7.   It's 11:04 AM.
