Old 11-01-2013, 01:34 PM   #1
drmax OP
Oddometer: 327
tail lamp
Finally fed up with intermittent rear lamp on 2002 lc4. New bulb won't even work. I've cleaned the contacts within and notta. Is there an led style lamp I can get, and simply dyke the old socket and install some time of new assy? I guess I gotta start reading. Thx for the help...dm
drmax is offline   Reply With Quote
Old 11-01-2013, 01:46 PM   #2
T3/T4 Hybrid
Lone Rider
T3/T4 Hybrid's Avatar
Oddometer: 72
I had issues in mine too but discovered that both brake light switches were bad. After replacing both of the switches I have not had any more problems.
Before discovering the switches were the actual issue I did replace the tail light assembly out to the new style connection and bulb.
http://www.advrider.com/forums/showt...php?p=18672187
It's kind of strange, how the mountains pay us no attention at ll. You laugh or cry and the wind just keeps on blowing.
T3/T4 Hybrid is offline   Reply With Quote
Old 11-01-2013, 02:03 PM   #3
drmax OP
Oddometer: 327
welp, I went to the link and I think I see 2 different type bulbs? Ok, so where is the part # for the socket and bulb? Hate to be spoon fed but do not see them listed their. (maybe time for glasses) thx, dm
Old 11-01-2013, 08:34 PM   #4
T3/T4 Hybrid
Lone Rider
Oddometer: 72
No prob I used the same set up that Dirty Sanchez used. It's actually for a GM vehicle but it can be purchased at any autozone or Advance Auto for under $10. Part number is 85881 and the socket uses the newer 3157 bulb.
Old 11-02-2013, 10:04 AM   #5
drmax OP
Oddometer: 327
Parts in hand. Sorry I did see those numbers in his listing. He mentioned their he'd let us figure out the wiring. Do you remember which bike wires went to A, B, and C?
Thx DM
drmax screwed with this post 11-02-2013 at 11:05 AM
Old 11-02-2013, 02:25 PM   #6
drmax OP
Oddometer: 327
wiring
Determined the green bike wire carries the running light 7 volts. I think I tried every configuration of wire positions and I can not get a running light. I can squeeze the handle or push pedal and get a light. The running light portion was working prior to dyking the old socket. Really nice of the GM part to not have a diagram on the damn package. I may post this over to the other thread to see if I can get help. Thx, DM
Old 11-03-2013, 05:34 AM   #7
drmax OP
Oddometer: 327
disregard
Disregard. Blown blue fuse. Also, these wires do not match up in a row, to the old lamp. It is as according....A to Blue...B to yellow...C to green
Times are GMT -7.   It's 06:49 AM.
