Old 11-05-2013, 02:24 PM   #46
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,577
Originally Posted by Stagehand View Post
All this is dependent on Paul getting back to me soon with some kind of number i can work towards. Otherwise, we look at bracing a regular frame.
I thought that roonie's frames were only for monolever swingarms. All of his bikes that I've seen with 11xx swingarms have used reinforced stock frames. ???
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 11-05-2013, 04:12 PM   #47
photomd
photomd's Avatar
Oddometer: 743
Build it! Build it! Build it! You gotta bring it down to the Sandblast Rally for a shake down. My garage is open (about 45 minutes away) for any help you need. I wanna see this thing with back end hanging out and a roost pouring off the rear tire.
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
photomd is offline   Reply With Quote
Old 11-05-2013, 04:36 PM   #48
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,985
Check out that pic back on the front page!
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 11-05-2013, 04:40 PM   #49
Airhead Wrangler
Adios Mexico
Oddometer: 6,577
Which one? I didn't see any of roonie's bikes there. ???
Old 11-05-2013, 05:29 PM   #50
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,584
Took me a second...
Old 11-05-2013, 06:09 PM   #51
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,985
And it looks like an 18" rear on the R100 FD, with no shock mount movement.
2 wierd things I'm just noticing are the rear brake arrangemnet and the clutch cablepath. Its run like there was still a frame tube there :lol
Old 11-05-2013, 06:24 PM   #52
Airhead Wrangler
Adios Mexico
Oddometer: 6,577
Oh.
The clutch cable kind of needs to go under the cylinder. Otherwise it'd make too sharp a turn and maybe need a roller or something. The rear brake looks like the standard way of flipping the rear brake arm on a paralever.
Old 11-05-2013, 06:25 PM   #53
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,985
Oh.
Yeah- they just look like the leftovers.. the things not quite thought through completely, but close enough for practical use
Old 11-05-2013, 08:29 PM   #54
LoJack
LoJack's Avatar
Oddometer: 1,609
What is it about the 1100 swing arm that works and not one more recent?
LoJack is offline   Reply With Quote
Old 11-05-2013, 11:24 PM   #55
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 687
a few reasons for not putting 1200 swing arms
Originally Posted by CrazyIvan View Post
A few reasons:
  • The swingarm bolts are not in the center of the gearbox anymore, but offset.
  • The final drives are more likely to fail, where the 11XX ones are basically the same design as the paralever ones. (bearing wise).
  • There's also only very tall gear ratio's with the 1200 final drives. The R850's and early R1100RS bikes have got the same ratio as the R80GS and R100GS.
Ras Thurlo is offline   Reply With Quote
Old 11-06-2013, 05:19 AM   #56
hardwaregrrl
ignore list
Oddometer: 7,584
Oh.
Am I blind, but I'm seeing the clutch cable going under the right cylinder......
Old 11-06-2013, 05:38 AM   #57
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,985
Yeah I think he's saying there is not really a choice of where it goes.
I just noticed it hanging out in front of hte cylinder. THat kind of free wire is the kind of thing that gets snatched by the wait-a-minute- bush
Old 11-06-2013, 05:55 AM   #58
hardwaregrrl
ignore list
Oddometer: 7,584
Gotcha....assuming because there is no frame there to protect it. I've met that "wait-a-minute-bush"......she was a pill. Discuss.....
Old 11-06-2013, 05:57 AM   #59
Stagehand OP
Imperfectionist
Stagehand's Avatar
Oddometer: 26,985
Old 11-06-2013, 07:31 AM   #60
LoJack
LoJack's Avatar
Oddometer: 1,609
Gotcha, thanks.
Times are GMT -7.   It's 03:57 PM.
