Old 11-27-2013, 07:41 AM   #121
AliBaba
AliBaba's Avatar
Oddometer: 372
Originally Posted by Deadly99 View Post
Anyone who says a drz fork is as a good as modern usd forks is simply wrong.
A fork like a modern Showa or Wp or whatever is soooo much better. Heck just being a usd makes the front end tighter feeling. The adjustable valving when setup properly....well there simply is no comparison.
Suspension is the key!
AliBaba is online now   Reply With Quote
Old 11-27-2013, 02:39 PM   #122
Dmaster
Dmaster's Avatar
Oddometer: 254
Spread the word so all DRZ forks are MINE
my 2 cents,
Go to a suspension guru and get information, if you like his story let him do the job.
The suspension you get should be custom build/ tweaked for you're bike not a spring or shock that "fits"
Get a pro who likes you're bike so he will do the best he can.
Dmaster is offline   Reply With Quote
Old 11-27-2013, 04:16 PM   #123
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,675
+1 and same for pretty much everthing else you said.
Here's the thing
After you deal with the front end, sort the frame and then ride your airhead hard offroad you quickly realise the rear end is the limiting factor.
Anything better than a DRZ front end dialled into close enough becomes overkill.
No amount of tuning on your Ohlins or other brand rear shock can overcome the design features of a mono or paralever rear end.
It is a masive amount of unsprung weight bouncing around even after you solve the limited travel problem.
Cheap and easy to work on is the airhead philosophy.
P.S. I run a set of Showa USDs with adjustments.
When I wear them out I will be looking of a DRZ front end
My bike is slow but the earth is patient.
Rucksta is offline   Reply With Quote
Old 11-28-2013, 02:04 AM   #124
Screaming Chicken
Screaming Chicken's Avatar
Oddometer: 461
my 2 cents,
Leave me one... ;-)
I really oughtta go talk to Bas sometime about sensible options for the front end. The purple rear end is very nice indeed, but the stock fork is a bit harsh with the prog springs. And with the stock springs it dives like Cousteau. ;-)
'92 R100GSPD
Two Bings to rule them all, Two Bings to ride them,
Two Bings to bring it all and in the twisties grind them.
In the land of Bavaria, where the boxers ride...
(Gandalf the oil-stained)
Screaming Chicken is offline   Reply With Quote
Old 11-28-2013, 07:28 AM   #125
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
USD vs Conventionals aside - IMHO these are different bikes once you upgrade the front end.
The Hyperpro Alphen guys set-up my WP50s and they are really plush. I think it helps that they ride airheads
Ras Thurlo screwed with this post 12-07-2013 at 12:42 AM
Ras Thurlo is offline   Reply With Quote
Old 11-30-2013, 12:30 PM   #126
Ras Thurlo
Desert Lion
Ras Thurlo's Avatar
Oddometer: 633
In't Rucksta ultimately right in saying that you need to view the argument from an airhead's perspective rather than what type of fork design is best in a vacuum.
I have got to believe that the unsprung weight of the shaft drive and the rubbery frame take away much of the theoretical advantage of USDs.
From my perspective, if I was solely performance focused - I would have converted a 950 Adventure into a offroad beast.
Instead I am daydreaming of DRZ forks for my ride
Old 11-30-2013, 12:47 PM   #127
Prutser
Prutser's Avatar
Oddometer: 968
The unsprung weight of the drz forks is less than that from a WP48 usd fork
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 12-06-2013, 11:18 PM   #128
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,122
OK- SO I have sprung for a set of 2007 DRZ400S forks, wheel, brakes, the whole front end. The Rooney frame is built to the DRZ specs, at 52.5mm or .25 or whatever a lot of them are.. And Mr Paul is willing to share specs, so this is where I'm going, damn the torpedos
I also sent the deposit, so I'm committed.
Also. I resigned at the theater to fuck off as a full time dad and trophy husband. No shit.
So its been an interesting couple of weeks.
Also, the GF says we can fix up her '74 R75/6 and get that out the door, and use the proceeds to buy the frame. It ran when we parked it. Needs a battery and a carb cleaning, and probably fix that under-tank master cylinder problem. That should be it.. I know the rear splines are good, and it ran smarter than the R60 back when we only the two bikes...
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 12-07-2013, 12:04 AM   #129
Padmei
enamoured
Oddometer: 3,604
Riiight - so now us other poor saps will be working while you're in the workshop playing with motorbikes all day.
You suck
Padmei is offline   Reply With Quote
Old 12-07-2013, 01:38 AM   #130
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,464
Welcome to the club. 'cept I don't have any kids or a wife. ... but I'll need to start looking for a job in the next couple of months.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 12-07-2013, 07:54 AM   #131
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,221
Wow. You're still going to be Stagehand, right?
Where's the R65 block?
Old 12-07-2013, 10:57 AM   #132
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,667
You suck
yeah what he said..
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 12-07-2013, 12:52 PM   #133
russbryant
Oddometer: 1,087
Also, the GF says we can fix up her ...
DAMN Dude!! No more work, Trophy husband, AND you get to have a GF
I can see it now...Stagehands Big Bike Offroad School
I'm so jealous!!
1989 R100GS
russbryant is offline   Reply With Quote
Old 12-07-2013, 01:22 PM   #134
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,122
I'm so jealous!!
Haha, oh man that would be the ticket, that's for sure- haha- still using GF and Wife interchangeably. Same net effect. One woman. :-)
Old 12-07-2013, 01:25 PM   #135
Stagehand OP
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,122
It would be impossible to remove the stagehand from me.. I was hard wired at the factory. The only difference is now: I don't have a steady paycheck. The other side is: I am now able to entertain creative projects in a new paradigm. My own particular idiom, to quote Monty python. Now, it gets REALLY weird
Te block is patiently awaiting the generous goodwill of the current owner to ship.
I have to get through the nutcracker but my last official day is Dec 20. That's 15.5 years in this position, with this place. Am now open for serious business.
Times are GMT -7.   It's 12:08 AM.
