Old 11-05-2013, 09:55 AM   #1
fmfpunk OP
Hooligan in training
fmfpunk's Avatar
Oddometer: 1,170
adventure not charging, VRR numbers OK?
2006 950A, 54K miles.
Not charging at all. Saw video how to test VRR. Hook leads to DVOM up 4 different combinations:
Infinity, infinity, infinity
497, 505, 501
infinity, infinity,infinity
502, 498, 494.
Does anyone know if these are correct?
Also checked stator at it tests OK (i think). Numbers even(ish) between the legs, none go to ground.
What else could it be?
Please send me any pointers.
Thx.
Marty
I'll slack you off, you fuzzy little foreigner. I'll fill your bagpipes with Wheatena!
fmfpunk is offline   Reply With Quote
Old 11-05-2013, 11:04 AM   #2
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
My boss asked if the bike had an exciter coil, or if stator uses magnets. If has exciter then i guess that's another thing that could go bad.
Old 11-05-2013, 11:12 AM   #3
dmn0507
dmn0507's Avatar
Oddometer: 352
Most motorbikes (including the LC8s) use a generator with permanent magnets (unlike cars)
What is the voltage output of the regulator? are all connections clean and tight?
dmn0507 is offline   Reply With Quote
Old 11-05-2013, 11:35 AM   #4
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
voltage when running is lower than when not running. Think when running is was 12.6ish.
Cleaned the plug for yellow wires to stator and red wires from VRR to battery.
Thx.
Old 11-05-2013, 01:22 PM   #5
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 935
Check starter solenoid, mine had a contact corroded. Or bad regulator
690R
Old 11-05-2013, 01:49 PM   #6
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
Originally Posted by gustavo.ramos View Post
check starter solenoid
+1
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 11-05-2013, 01:51 PM   #7
bikyto
bikyto's Avatar
Oddometer: 2,190
Thx.
anyway you could swap the VR for a test? With the OEM, engine running at idle with everything off (headlight too), you should get between 13.7-14.1v
Old 11-05-2013, 05:02 PM   #8
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
noticed negative battery cable loose. Seems like charging some, but not enough. Will see how it does on ride home.
Old 11-05-2013, 08:48 PM   #9
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
Not very good voltage on the way home, but it did eventually get up to 14.1. But even turning the blinkers on made voltage drop.
Came across a thread in an Aprillia forum describing how to test stator output. Tried it and one leg of stator is much lower than the others. Rats.
Maybe take cover off this weekend and see what's up.
Old 11-05-2013, 11:08 PM   #10
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,019
If you descide you need a new R/R I suggest
Get the Shindengen one. It is highly praised in here.
http://www.ebay.com/itm/SHINDENGEN-M...c15b45&vxp=mtr
Cheers
gefr is online now   Reply With Quote
Old 11-06-2013, 08:56 AM   #11
fmfpunk OP
fmfpunk's Avatar
Oddometer: 1,170
Yes, have seen the R/R, looks good.
But i think my problem is a burned stator.
Thx.
Times are GMT -7.   It's 10:42 PM.
