Old 11-05-2013, 08:07 PM   #1
67siia OP
67siia's Avatar
Oddometer: 161
Bike towed home...
This morning when I started the bike I hear an unusual click when I pushed the power button and started fine. Rode to work and parked. After work, I put the key in pushed the start button and I hear click click click... Head lights seemed dim. I call the Mrs. she brought my tools and a voltmeter. Battery read 12 volts, when trying to start it voltage dropped to about 9 volts. Waited 1 hrs for the tow truck. I'm towing it to the dealer tomorrow AM..... But, anything I should consider before taking the long drive there?
2012 F800GS 4500 miles
67siia - CA 91381
12 BMW F800GS - 79 BMW R65 - 13 Honda CB500X - 79 Yamaha DT175 - 07 Yamaha TTR125L
67siia is offline   Reply With Quote
Old 11-05-2013, 08:26 PM   #2
Dirt Rider
Old Adventurer
Dirt Rider's Avatar
Oddometer: 122
Easy to test. Start bike and measure votlage at battery. Should be about 13.7 - about 14. If not, charge system problem likely.
A fully charged battery will read 12.6 - 12.7 after settling down from a charge. 12.35 is 75% charged. 12.1 is 50% charged. Or it can be monitored after charging and see how far it is down in the morning. Should not go down much or there might be something loading a circuit.
Other than the drive, warranty. Maybe one cell in battery went.
Doug
WR250R
DR650S
Dirt Rider is offline   Reply With Quote
Old 11-05-2013, 08:58 PM   #3
The Island
Im lost.
The Island's Avatar
Oddometer: 219
From my little bit of knowledge gathered from the research I am doing about the same problem with my 2013, if the battery dips below 9.6V while cranking, then you have a bad cell. Apparently, it's a rule of thumb — I don't know but 9V doesn't seem like it would be enough to get that starter going. Get it load tested by your dealer or better yet, surf youtube/net to see that with just a voltmeter, one can determine much about their battery.
Damn batteries.
The Island is offline   Reply With Quote
Old 11-05-2013, 09:51 PM   #4
67siia OP
67siia's Avatar
Oddometer: 161
Update:
Doing some pocking around and trying to start it, the display now shows: EWS error which from what I gather is a bad antenna. Hopefully the dealer has one in stock for a quick replacement.
67siia - CA 91381
Old 11-06-2013, 01:46 AM   #5
dpm
Oddometer: 188
cranking with the battery too low is a recipe for corrupting ECU data. did you try push-starting it before the battery went so flat?
dpm is offline   Reply With Quote
Old 11-06-2013, 05:20 AM   #6
runnin4melife
Oddometer: 804
Man you must be a BA! I never contemplated ever trying to pop start a 500lb bike ;-)
runnin4melife is offline   Reply With Quote
Old 11-06-2013, 06:03 AM   #7
67siia OP
67siia's Avatar
Oddometer: 161
Nope
67siia - CA 91381
Old 11-06-2013, 06:08 AM   #8
ebrabaek
Oddometer: 4,758
You cannot push start the 8GS. If the battery is dead, there is not enough juice generated to get the fuel injection going.
There have been a string of bad batteries on the 8gs. Also keep in mind that the charging voltage is too low on earlier bikes, and batteries tends to oversulfate.
Erling
Old 11-06-2013, 06:21 AM   #9
67siia OP
67siia's Avatar
Oddometer: 161
So, would the battery be covered under BMW manufacturer's warranty? Or should be prepared to fork out the money in which case, what is the best recommendation for a battery?
67siia - CA 91381
Old 11-06-2013, 06:36 AM   #10
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,113
Unless you did something silly with accessory wiring, the battery is definately covered. Sounds like there is either a drain on the battery when off or the battery isn't holding it's charge. Be firm if you're innocent. A low battery will cause many errors like EWS but that's normal. Not enough juice to read your key and operate systems.
Replacing a battery under warranty is common practice, nothing funny about it.
Life is a Rollercoaster and I'm not strapped in!
Leaving it all behind 2014
Reaver is offline   Reply With Quote
Old 11-06-2013, 06:44 AM   #11
67siia OP
67siia's Avatar
Oddometer: 161
Thanks. No funny business with the electrical. What is surprising to me, if the battery is the issue and not the EWS, is that I did not experience any "fair" warning as I have experiences on my cars before the battery goes bad.
67siia - CA 91381
Old 11-06-2013, 06:59 AM   #12
ebrabaek
Oddometer: 4,758
Mine went bad inside 12 months.... ( 2009 8GS) covered under warranty. You should be ok. Unless you have a idiot dealer.
Erling
Old 11-06-2013, 09:47 AM   #13
itsatdm
itsatdm's Avatar
Oddometer: 4,904
My battery had a sudden death syndrome within 6 months of new. A shorted cell will do that. It had the same multi meter readings you got.
Think positive, the other option is a bad stator. You can do a quick check on that too next time. Jump start the bike and see what voltage input you are getting at the terminals. It should be 13.7v or better.
Batteries are covered. Stators likely will not be covered.
Old 11-06-2013, 10:11 AM   #14
Reaver
Outta Here
Reaver's Avatar
Oddometer: 4,113
Bad on BMW for not having a voltage display or warning. When the alt went on the Jeep, it told me immediately and I went straight home.
Check out the aftermarket voltmeter options in the threads here.
Old 11-06-2013, 01:47 PM   #15
67siia OP
67siia's Avatar
Oddometer: 161
Bike left at dealer. They determined it is a bad antenna and need to order it. I asked then to check the battery as well. I will post an update when I get the bike back.
67siia - CA 91381
Times are GMT -7.   It's 01:23 AM.
