Old 11-18-2013, 04:36 AM   #1
Three Dawg OP
Three Dawg's Avatar
Oddometer: 503
1100GS Gearbox oil drain plug
Just changing the fluids in my 97 1100GS and didn't notice a washer coming out with the gearbox drain plug. Is the one I have the later revised 'washerless' one, and if so, am I right in thinking that the torque setting for this type is higher (circa 30Nm rather than 23?) than the ones with a crush washer? The Haynes manual doesn't seem to mention a washerless type.
It's been suggested that the washer may still be attached to the gearbox, but if it is, I can't shift it:
Three Dawg is offline   Reply With Quote
Old 11-18-2013, 04:39 AM   #2
JimVonBaden
"Cool" Aid!
Oddometer: 53,271
Looks like the washerless type. I am not aware of a different torque value for it.
Jim
JimVonBaden is online now   Reply With Quote
Old 11-18-2013, 07:29 AM   #3
Three Dawg OP
Three Dawg's Avatar
Oddometer: 503
Cheers Jim.
Three Dawg screwed with this post 11-18-2013 at 07:46 AM
Old 11-18-2013, 08:13 AM   #4
Jim Moore
Jim Moore's Avatar
Oddometer: 13,839
Can I tell you my theory on that? My theory on that is this. They're all supposed to be 32 nm. 23 nm is a misprint. They transposed the numbers in several places in various manuals. 23 nm won't crush the washer. I've had drain plugs leak after being tightened to 23. I use 32 nm for all of them.
Jim Moore
Jax, FL
Pay the lady, PirateJohn, you thieving piece of garbage.
http://advrider.com/forums/showthread.php?t=949341
Jim Moore is online now   Reply With Quote
Old 11-18-2013, 08:22 AM   #5
Three Dawg OP
Three Dawg's Avatar
Oddometer: 503
Just done up the drive housing fill and drain bolts to 23Nm with lightly oiled threads and they felt pretty tight to me- 32 seems quite a lot on a relatively short thread.
Old 11-18-2013, 05:10 PM   #6
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,270
JimB: that plug takes a crush washer. You can see the taper and the absence of a sealing lip.
JimM: Thanks for at least saying that it's just your theory. The washerless plugs really do have a higher torque. It's described in a bulletin (listed there as 30 Nm actually).
Old 11-18-2013, 05:52 PM   #7
JimVonBaden
"Cool" Aid!
Oddometer: 53,271
Anton, do you have a photo of that plug with a crush washer on it?
Jim
Old 11-18-2013, 06:22 PM   #8
AntonLargiader
Oddometer: 4,270
This shows the two plugs types. One has a taper to center the crush washer, and the other doesn't but has extra grooves on the face to seal against the transmission (and gets the higher torque). There are several other plug configurations but the main difference is this:
The OP's drain plug has a step in it which may have mashed the crush washer outward and jammed it into the machined bore in the trans case. It's really hard to tell sometimes if there is a washer stuck in there.
Old 11-18-2013, 07:34 PM   #9
JimVonBaden
"Cool" Aid!
Oddometer: 53,271
I am pretty sure there is no crush washer stuck in here, the picture is very clear:
But, it is easy enough to figure it out.
Jim
Old 11-19-2013, 01:29 AM   #10
Three Dawg OP
Three Dawg's Avatar
Oddometer: 503
Sheesh, how many types of drain plug does one bike need?
Unless there is a washer that obviously fits that taper arriving with my other bits and pieces today I think I'll just bung it back in at 23 Nm and keep an eye on it.
Old 11-19-2013, 05:43 AM   #11
Dan Căta
Dan Căta's Avatar
Oddometer: 1,667
I suggest you change the plug to the one on the L/H side, it is a better design than the one that uses a allen key. Had to replace the gearbox oil on a friend's bike recently and the PO screwed the bolt so hard in, that I broke the 6 mm bit in the plug :|
This would not have happened if he would have used the torque wrench and the outer hex head plug...
Dan.
Dan Căta is offline   Reply With Quote
Old 11-19-2013, 05:52 AM   #12
AntonLargiader
Oddometer: 4,270
He already has that one; you can see it in the first post. But you're right, the 6mm Allen version is problematic that way. I've dealt with a few tough one, too.
Old 11-19-2013, 01:09 PM   #13
Basic_Gerd
Gerd
Basic_Gerd's Avatar
Oddometer: 253
This one was mounted without washer too. I would never omit the washer, because it protects against that seizing. Way too dangerous for the housing.
Without that grinding compound trick that screw would not have come out.
The difference between theory and practice practically is larger than the difference between theory and practice theoretically.
BMW Airhead -> www.zeebulon.de/bmw
BMW R1100GS -> www.zeebulon.de/R1100GS
XT 500 -> www.zeebulon.de/xt
Basic_Gerd is offline   Reply With Quote
Old 11-19-2013, 01:13 PM   #14
Three Dawg OP
Three Dawg's Avatar
Oddometer: 503
Put washer on plug, put plug in hole, tightened to 23Nm. Should be OK. Thanks for all replies.
Old 11-19-2013, 03:29 PM   #15
AntonLargiader
Oddometer: 4,270
If there's no centering taper, you shouldn't use the washer because it could get far enough off-center that it leaks. Better to change to a washer-type plug.
Times are GMT -7.   It's 11:19 AM.
