Old 11-18-2013, 09:44 AM   #1
genka OP
SUV hater
genka's Avatar
Oddometer: 1,599
Jesse Safari clearance.
I installed a set of Jessi Safari 115 on my 07GS. On my first ride in the mountains my pannier touched the ground in a turn. Is it just how these boxes are or I can do something about it?
My bike is the standard height with OEM shocks. The total load was probably around 250lbs.
Форум мотоциклистов в США http://www.xytopok.net/mvnforum/listthreads?forum=31
genka is offline   Reply With Quote
Old 11-18-2013, 10:42 AM   #2
coach03860
coach03860's Avatar
Oddometer: 288
11" Safaris on regular height R1200GS's
I was all HOT to buy a set of practically new 11" Jesse Safari bags for my new 2012 GS (reg height) off another inmate on here but one call to Al Jesse (very nice man to talk with) dissuaded me. He advised that what you experienced would happen to me with even semi-spirited riding. Jesse does make a 9" Safari and the Odyssey bags for our bikes, so perhaps you should give him a call too. A GSA would probably be OK, but being "vertically challenged", riding an Adventure everyday is out of the question for me. This a potentially dangerous set-up you have mounted up, so be careful laying that GS of yours over much into turns as a little more than what you describe above would have been a low side get off story instead of your casual inquiry when your rear tire came off the ground and you were riding the pannier instead . Conduisez prudemment avec ces sacs mon ami. Cheers coach
'12 BMW R1200GS
'11 Triumph Tiger 800-ABS (sold)
'10 Triumph Tiger 1050SE & '07 Triumph Tiger & '05 R1200GS (all sold)
And well over a dozen other bikes bought and sold that I lose track of...but my wife constantly reminds me of
coach03860 is offline   Reply With Quote
Old 11-18-2013, 10:53 AM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,696
Gene, IIRC you are a little heavier than the regular 185 pound BMW ideal. Did you have your shock preload all the way maxed?
Jim
JimVonBaden is online now   Reply With Quote
Old 11-18-2013, 11:42 AM   #4
Emoto
Sure, why not?
Emoto's Avatar
Oddometer: 18,009
I have Safaris on my 2005 R12GS and have touched down footpegs but never bags.
Old 11-18-2013, 12:47 PM   #5
genka OP
SUV hater
genka's Avatar
Oddometer: 1,599
Jim, I'm under 210lbs- not that heavy to warrant maximum preload! Probably I should crank it up a little more, but not all the way.
It was a deep lean, my peg is not only touched the ground, it folded quite a bit. I have aftermarket pegs however, they probably touch touch earlier than stock.
Old 11-18-2013, 12:49 PM   #6
steveWFL
steveWFL's Avatar
Oddometer: 1,344
Fab some knee pucks on 'em
KTM EXC - in 530 flavor
'10 Concours14 with >85,000 miles and ticking'
'99 ZX9R Ninja - rolling retro style
'99 ZX9R - because I like the other one so much
'08 ZZR600 minty
steveWFL is offline   Reply With Quote
Old 11-18-2013, 03:04 PM   #7
ThirdBestFriend
Explorer
ThirdBestFriend's Avatar
Oddometer: 119
Wow, definitely no chicken strips on your tires.
ThirdBestFriend is offline   Reply With Quote
Old 11-18-2013, 10:32 PM   #8
oz97tj
oz97tj's Avatar
Oddometer: 819
Time to start learning to lean your body more into corners?
I come from sport bikes so I'm used to moving my upper body into the turn, which in turns keeps the bike more upright. I've ridden this exact setup (those bags were purchased from me) quite aggressively without having this issue and I'm heavier.
'13 BMW 1200 GSW
'05 Honda ST1300
oz97tj is offline   Reply With Quote
Old 11-18-2013, 10:41 PM   #9
Girthy Knobkers
Girthy Knobkers's Avatar
Oddometer: 455
mmmhmmm
Girthy Knobkers is offline   Reply With Quote
Old 11-18-2013, 11:50 PM   #10
oz97tj
oz97tj's Avatar
Oddometer: 819
Originally Posted by Girthy Knobkers View Post
mmmhmmm
'13 BMW 1200 GSW
'05 Honda ST1300
Old 11-19-2013, 06:35 AM   #11
JimVonBaden
"Cool" Aid!
Oddometer: 51,696
mmmhmmm
He was agreeing with you.
Jim
Old 11-19-2013, 06:41 AM   #12
NoVa Rider
Oddometer: 2,815
And getting on the gas. If you don't have maintenance or increasing throttle after you set the lean, your suspension will be unbalanced, possibly the reason your peg ground and bag touched. . .. But this is the internets, and YMMV.
NoVa Rider is online now   Reply With Quote
Old 11-19-2013, 07:22 AM   #13
genka OP
SUV hater
genka's Avatar
Oddometer: 1,599
Thanks for answers. I practice leaning my body into the turn and staying on the throttle. Sometimes it can be difficult- the friction in the GS seat prevents an easy slide across. I'm not sure how giving more gas would help in this particular case- it transfers more load on the rear wheel and further compresses the rear suspension. IIRC, that turn was going uphill, also contributing to the rear load bias.
Old 11-19-2013, 07:58 AM   #14
oz97tj
oz97tj's Avatar
Oddometer: 819
Jim
Lol. It was late and I tired. Lol
Genka, sounds like it may have been a semi isolated incident then due to the road surface? If that is the case, why sweat it? Just know its an issue and plan corners accordingly maybe. I did have my preload maxed out on my bike, but due to my increased weight I doubt my bike sat any taller than yours. Then again, even at your weight you are beyond what the stock spring is set up for so it wouldnt hurt to crank it up anyway. Depending on where yours is set at, your bike could be sitting lower than it should.
'13 BMW 1200 GSW
'05 Honda ST1300
Old 11-19-2013, 08:03 AM   #15
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,527
You sport bike guys always say that but I see this from the fast pros.
[IMG]http://a0.img.mobypicture.com
/fc9708dd7442e9caa55590417b04bb0a_large.jpg[/IMG]
GS riders are cocks (confirmed) Aprila forum GS bashing.
scooteraug02 is offline   Reply With Quote
Times are GMT -7.   It's 07:40 PM.
